iSCSI session details
PDF of this doc site
Manage storage with Element software
- Protect your data
Creating your file...
You can view information about the iSCSI sessions that are connected to the cluster.
The following list describes the information that you can find about the iSCSI sessions:
Node
The node hosting the primary metadata partition for the volume.
Account
The name of the account that owns the volume. If value is blank, a dash (-) is displayed.
Volume
The volume name identified on the node.
Volume ID
ID of the volume associated with the Target IQN.
Initiator ID
A system-generated ID for the initiator.
Initiator Alias
An optional name for the initiator that makes finding the initiator easier when in a long list.
Initator IP
The IP address of the endpoint that initiates the session.
Initiator IQN
The IQN of the endpoint that initiates the session.
Target IP
The IP address of the node hosting the volume.
Target IQN
The IQN of the volume.
Created On
Date the session was established.
