Element Software
iSCSI session details
Contributors netapp-pcarriga
You can view information about the iSCSI sessions that are connected to the cluster.
The following list describes the information that you can find about the iSCSI sessions:
  • Node
    The node hosting the primary metadata partition for the volume.
  • Account
    The name of the account that owns the volume. If value is blank, a dash (-) is displayed.
  • Volume
    The volume name identified on the node.
  • Volume ID
    ID of the volume associated with the Target IQN.
  • Initiator ID
    A system-generated ID for the initiator.
  • Initiator Alias
    An optional name for the initiator that makes finding the initiator easier when in a long list.
  • Initator IP
    The IP address of the endpoint that initiates the session.
  • Initiator IQN
    The IQN of the endpoint that initiates the session.
  • Target IP
    The IP address of the node hosting the volume.
  • Target IQN
    The IQN of the volume.
  • CHAP
    The CHAP algorithm for an iSCSI session. If a CHAP algorithm is not being used, a dash (-) is displayed. Available beginning with Element 12.8.
  • Created On
    Date the session was established.
