Configure SolidFire system options after deployment
PDF of this doc site
Manage storage with Element software
Creating your file...
Your file is ready
After you set up your SolidFire system, you might want to perform some optional tasks.
If you change credentials in the system, you might want to know the impact on other components.
Additionally, you can configure settings for multi-factor authentication, external key management, and Federal Information Processing Standards (FIPS) security. You should also look at updating passwords when needed.
