Pair volumes using a pairing key
If you do not have cluster admin credentials for a remote cluster, you can pair a volume with another volume on a remote cluster using a pairing key.
Ensure that the clusters containing the volumes are paired.
Ensure that there is a volume on the remote cluster to use for the pairing.
You can assign a replication source and target after the pairing process. A replication source or target can be either volume in a volume pair. You should create a target volume that contains no data and has the exact characteristics of the source volume, such as size, block size setting for the volumes (either 512e or 4k), and QoS configuration. If you assign an existing volume as the replication target, the data on that volume will be overwritten. The target volume can be greater or equal in size to the source volume, but it cannot be smaller.
Select Management > Volumes.
Click Actions icon for the volume you want to pair.
Click Pair.
In the Pair Volume dialog box, select Start Pairing.
Select I Do Not to indicate that you do not have access to the remote cluster.
Select a Replication Mode from the list:
Real-time (Asynchronous): Writes are acknowledged to the client after they are committed on the source cluster.
Real-time (Synchronous): Writes are acknowledged to the client after they are committed on both the source and target clusters.
Snapshots Only: Only snapshots created on the source cluster are replicated. Active writes from the source volume are not replicated.
Click Generate Key.
This action generates a text key for pairing and creates an unconfigured volume pair on the local cluster. If you do not complete the procedure, you will need to manually delete the volume pair. -
Copy the pairing key to your computer's clipboard.
Make the pairing key accessible to the cluster admin at the remote cluster site.
The volume pairing key should be treated in a secure manner and not used in a way that would allow accidental or unsecured access. Do not modify any of the characters in the pairing key. The key becomes invalid if it is modified. -
In the remote cluster Element UI, select Management > Volumes.
Click the Actions icon for the volume you want to pair.
Click Pair.
In the Pair Volume dialog box, select Complete Pairing.
Paste the pairing key from the other cluster into the Pairing Key box.
Click Complete Pairing.
After you confirm the pairing, the two clusters begin the process of connecting the volumes for pairing. During the pairing process, you can see messages in the Volume Status column of the Volume Pairs window. The volume pair displays
PausedMisconfigureduntil the volume pair source and target are assigned.After you successfully complete the pairing, you should refresh the Volumes table to remove the Pair option from the Actions list for the paired volume. If you do not refresh the table, the Pair option remains available for selection. If you select the Pair option again, a new tab opens and because the volume is already paired, the system reports a
StartVolumePairing Failed: xVolumeAlreadyPairederror message in the Pair Volume window of the Element UI page.
