Delete a virtual network
PDF of this doc site
Manage storage with Element software
Creating your file...
Your file is ready
You can remove a virtual network object. You must add the address blocks to another virtual network before you remove a virtual network.
Click Cluster > Network.
Click the Actions icon for the VLAN you want to delete.
Click Delete.
Confirm the message.
