Element Software
Manage the Terms of Use banner
You can enable, edit, or configure a banner that contains a message for the user.
Enable the Terms of Use banner
You can enable a Terms of Use banner that appears when a user logs in to the Element UI. When the user clicks on the banner, a text dialog box appears containing the message you have configured for the cluster. The banner can be dismissed at any time.
You must have cluster administrator privileges to enable Terms of Use functionality.
  1. Click Users > Terms of Use.
  2. In the Terms of Use form, enter the text to be displayed for the Terms of Use dialog box.
    Note Do not exceed 4096 characters.
  3. Click Enable.
Edit the Terms of Use banner
You can edit the text that a user sees when they select the Terms of Use login banner.
What you'll need
  • You must have cluster administrator privileges to configure Terms of Use.
  • Ensure that the Terms of Use feature is enabled.
Steps
  2. In the Terms of Use dialog box, edit the text that you want to appear.
  3. Click Save Changes.
Disable the Terms of Use banner
You can disable the Terms of Use banner. With the banner disabled, the user is no longer requested to accept the terms of use when using the Element UI.
What you'll need
  • Ensure that Terms of Use is enabled.
Steps
  2. Click Disable.
