Identify whether nodes are ready for the FIPS drives feature
You should check to see if all nodes in the storage cluster are ready to support FIPS drives by using the NetApp Element software GetFipsReport API method.
The resulting report shows one of the following statuses:
None: Node is not capable of supporting the FIPS drives feature.
Partial: Node is FIPS capable, but not all drives are FIPS drives.
Ready: Node is FIPS capable and all drives are FIPS drives or no drives are present.
Using the Element API, check to see if the nodes and drives in the storage cluster are capable of FIPS drives by entering:
GetFipsReport
Review the results, noting any nodes that did not display a status of Ready.
For any nodes that did not display a Ready status, check to see if the drive is capable of supporting the FIPS drives feature:
Using the Element API, enter:
GetHardwareList
Note the value of the DriveEncryptionCapabilityType. If it is "fips," the hardware can support the FIPS drives feature.
See details about
GetFipsReport
orListDriveHardware
in the Element API Reference.
If the drive cannot support the FIPS drives feature, replace the hardware with FIPS hardware (either node or drives).
