Configure the cluster to listen for NTP broadcasts
PDF of this doc site
Manage storage with Element software
Creating your file...
Your file is ready
By using the broadcast mode, you can instruct each node in a cluster to listen on the network for Network Time Protocol (NTP) broadcast messages from a particular server.
What you'll need
You must have cluster administrator privileges to configure this setting.
You must configure an NTP server on your network as a broadcast server.
Steps
Click Cluster > Settings.
Enter the NTP server or servers that are using broadcast mode into the server list.
Under Network Time Protocol Settings, select Yes to use a broadcast client.
To set the broadcast client, in the Server field, enter the NTP server you configured in broadcast mode.
Click Save Changes.
