The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
View managed object data using management information base files
PDF of this doc site
Manage storage with Element software
Creating your file...
Your file is ready
You can view and download the management information base (MIB) files used to define each of the managed objects. The SNMP feature supports read-only access to those objects defined in the SolidFire-StorageCluster-MIB.
The statistical data provided in the MIB shows system activity for the following:
Cluster statistics
Volume statistics
Volumes by account statistics
Node statistics
Other data such as reports, errors, and system events
The system also supports access to the MIB file containing the upper level access points (OIDS) to SF-Series products.
Steps
Click Cluster > SNMP.
Under SNMP MIBs, click the MIB file you want to download.
In the resulting download window, open or save the MIB file.
