Element Software
View managed object data using management information base files
Contributors netapp-pcarriga
You can view and download the management information base (MIB) files used to define each of the managed objects. The SNMP feature supports read-only access to those objects defined in the SolidFire-StorageCluster-MIB.
The statistical data provided in the MIB shows system activity for the following:
  • Cluster statistics
  • Volume statistics
  • Volumes by account statistics
  • Node statistics
  • Other data such as reports, errors, and system events
The system also supports access to the MIB file containing the upper level access points (OIDS) to SF-Series products.
Steps
  1. Click Cluster > SNMP.
  2. Under SNMP MIBs, click the MIB file you want to download.
  3. In the resulting download window, open or save the MIB file.
