Element Software
Network port requirements
Contributors netapp-pcarriga netapp-dbagwell
You might need to allow the following TCP and UDP ports through your data center's edge firewall so that you can manage the system remotely and allow clients outside of your data center to connect to resources. Some of these ports might not be required, depending on how you use the system.
All ports are TCP unless stated otherwise, and all TCP ports must support three-way handshake communication between the NetApp Support Server, management node, and nodes running Element software. For example, the host on a management node source communicates with the host on a storage cluster MVIP destination through TCP port 443, and the destination host communicates back to the source host through any port.
Tip Enable ICMP between the management node, nodes running Element software, and cluster MVIP.
The following abbreviations are used in the table:
  • MIP: Management IP address, a per-node address
  • SIP: Storage IP address, a per-node address
  • MVIP: Management virtual IP address
  • SVIP: Storage virtual IP address
Source Destination Port Description
iSCSI clients
Storage cluster MVIP
443
(Optional) UI and API access
iSCSI clients
Storage cluster SVIP
3260
Client iSCSI communications
iSCSI clients
Storage node SIP
3260
Management node
sfsupport.solidfire.com
22
Reverse SSH tunnel for support access
Management node
Storage node MIP
22
SSH access for support
Management node
DNS servers
53 TCP/UDP
DNS lookup
Management node
Storage node MIP
442
UI and API access to storage node and Element software upgrades
Management node
442
Management node
monitoring.solidfire.com
443
Storage cluster reporting to Active IQ
Management node
443
Management node
repo.netapp.com
443
Provides access to components necessary to install/update on-premises deployment.
Management node
Storage node BMC/IPMI
623 UDP
RMCP port. This is required to manage IPMI-enabled systems.
Management node
Witness Node
9442
Per-node configuration API service
Management node
vCenter Server
9443
vCenter Plug-in registration. The port can be closed after registration is complete.
SNMP server
161 UDP
SNMP polling
SNMP server
Storage node MIP
161 UDP
SNMP polling
Management node
623 UDP
Storage node MIP
DNS servers
53 TCP/UDP
DNS lookup
Storage node MIP
Management node
80
Storage node MIP
S3/Swift endpoint
80
(Optional) HTTP communication to S3/Swift endpoint for backup and recovery
Storage node MIP
NTP server
123 UDP
NTP
Storage node MIP
Management node
162 UDP
(Optional) SNMP traps
Storage node MIP
SNMP server
162 UDP
Storage node MIP
LDAP server
389 TCP/UDP
(Optional) LDAP lookup
Storage node MIP
Management node
443
Element storage upgrades
Storage node MIP
Remote storage cluster MVIP
443
Remote replication cluster pairing communication
Storage node MIP
Remote storage node MIP
443
Storage node MIP
S3/Swift endpoint
443
(Optional) HTTPS communication to S3/Swift endpoint for backup and recovery
Storage node MIP
Management node
514 TCP/UDP
10514 TCP/UDP
Syslog forwarding
Storage node MIP
Syslog server
514 TCP/UDP
10514 TCP/UDP
Syslog forwarding
Storage node MIP
LDAPS server
636 TCP/UDP
LDAPS lookup
Storage node MIP
2181
Intercluster communication for remote replication
Storage node SIP
Remote storage node SIP
2181
Storage node SIP
Storage node SIP
3260
Internode iSCSI
Storage node SIP
4000 through 4020
Remote replication node-to-node data transfer
System administrator PC
Management node
442
HTTPS UI access to management node
Storage node MIP
442
HTTPS UI and API access to storage node
Management node
443
HTTPS UI and API access to management node
443
HTTPS UI and API access to storage cluster
Storage node baseboard management controller (BMC)/Intelligent Platform Management Interface (IPMI) H410 and H600 series
443
HTTPS UI and API access to node remote control
Storage node MIP
443
HTTPS storage cluster creation, post-deployment UI access to storage cluster
Storage node BMC/IPMI H410 and H600 series
623 UDP
Remote Management Control Protocol port. This is required to manage IPMI-enabled systems.
Witness Node
8080
Witness Node per-node web UI
vCenter Server
443
vCenter Plug-in API access
vCenter Server
Remote plug-in
8333
Remote vCenter Plug-in service
vCenter Server
Management node
8443
(Optional) vCenter Plug-in QoSSIOC service.
vCenter Server
8444
vCenter VASA provider access (VVols only)
vCenter Server
Management node
9443
