Network port requirements
You might need to allow the following TCP and UDP ports through your data center's edge firewall so that you can manage the system remotely and allow clients outside of your data center to connect to resources. Some of these ports might not be required, depending on how you use the system.
All ports are TCP unless stated otherwise, and all TCP ports must support three-way handshake communication between the NetApp Support Server, management node, and nodes running Element software. For example, the host on a management node source communicates with the host on a storage cluster MVIP destination through TCP port 443, and the destination host communicates back to the source host through any port.
Enable ICMP between the management node, nodes running Element software, and cluster MVIP. |
The following abbreviations are used in the table:
MIP: Management IP address, a per-node address
SIP: Storage IP address, a per-node address
MVIP: Management virtual IP address
SVIP: Storage virtual IP address
| Source | Destination | Port | Description |
iSCSI clients |
Storage cluster MVIP |
443 |
(Optional) UI and API access |
iSCSI clients |
Storage cluster SVIP |
3260 |
Client iSCSI communications |
iSCSI clients |
Storage node SIP |
3260 |
Management node |
22 |
Reverse SSH tunnel for support access |
Management node |
Storage node MIP |
22 |
SSH access for support |
Management node |
DNS servers |
53 TCP/UDP |
DNS lookup |
Management node |
Storage node MIP |
442 |
UI and API access to storage node and Element software upgrades |
Management node |
442 |
Management node |
443 |
Storage cluster reporting to Active IQ |
Management node |
443 |
Management node |
repo.netapp.com |
443 |
Provides access to components necessary to install/update on-premises deployment. |
Management node |
Storage node BMC/IPMI |
623 UDP |
RMCP port. This is required to manage IPMI-enabled systems. |
Management node |
Witness Node |
9442 |
Per-node configuration API service |
Management node |
vCenter Server |
9443 |
vCenter Plug-in registration. The port can be closed after registration is complete. |
SNMP server |
161 UDP |
SNMP polling |
SNMP server |
Storage node MIP |
161 UDP |
SNMP polling |
Management node |
623 UDP |
Storage node MIP |
DNS servers |
53 TCP/UDP |
DNS lookup |
Storage node MIP |
Management node |
80 |
Storage node MIP |
S3/Swift endpoint |
80 |
(Optional) HTTP communication to S3/Swift endpoint for backup and recovery |
Storage node MIP |
NTP server |
123 UDP |
NTP |
Storage node MIP |
Management node |
162 UDP |
(Optional) SNMP traps |
Storage node MIP |
SNMP server |
162 UDP |
Storage node MIP |
LDAP server |
389 TCP/UDP |
(Optional) LDAP lookup |
Storage node MIP |
Management node |
443 |
Element storage upgrades |
Storage node MIP |
Remote storage cluster MVIP |
443 |
Remote replication cluster pairing communication |
Storage node MIP |
Remote storage node MIP |
443 |
Storage node MIP |
S3/Swift endpoint |
443 |
(Optional) HTTPS communication to S3/Swift endpoint for backup and recovery |
Storage node MIP |
Management node |
514 TCP/UDP 10514 TCP/UDP |
Syslog forwarding |
Storage node MIP |
Syslog server |
Syslog forwarding |
Storage node MIP |
LDAPS server |
636 TCP/UDP |
LDAPS lookup |
Storage node MIP |
2181 |
Intercluster communication for remote replication |
Storage node SIP |
Remote storage node SIP |
2181 |
Storage node SIP |
Storage node SIP |
3260 |
Internode iSCSI |
Storage node SIP |
4000 through 4020 |
Remote replication node-to-node data transfer |
System administrator PC |
Management node |
442 |
HTTPS UI access to management node |
Storage node MIP |
442 |
HTTPS UI and API access to storage node |
Management node |
443 |
HTTPS UI and API access to management node |
443 |
HTTPS UI and API access to storage cluster |
Storage node baseboard management controller (BMC)/Intelligent Platform Management Interface (IPMI) H410 and H600 series |
443 |
HTTPS UI and API access to node remote control |
Storage node MIP |
443 |
HTTPS storage cluster creation, post-deployment UI access to storage cluster |
Storage node BMC/IPMI H410 and H600 series |
623 UDP |
Remote Management Control Protocol port. This is required to manage IPMI-enabled systems. |
Witness Node |
8080 |
Witness Node per-node web UI |
vCenter Server |
443 |
vCenter Plug-in API access |
vCenter Server |
Remote plug-in |
8333 |
Remote vCenter Plug-in service |
vCenter Server |
Management node |
8443 |
(Optional) vCenter Plug-in QoSSIOC service. |
vCenter Server |
8444 |
vCenter VASA provider access (VVols only) |
vCenter Server |
Management node |
9443 |
