Run Element storage health checks prior to upgrading storage
You must run health checks prior to upgrading Element storage to ensure all storage nodes in your cluster are ready for the next Element storage upgrade.
Management services: You have updated to the latest management services bundle (2.10.27 or later).
You must upgrade to the latest management services bundle before upgrading your Element software. -
Management node:You are running management node 11.3 or later.
Element software: Your cluster version is running NetApp Element software 11.3 or later.
End User License Agreement (EULA): Beginning with management services 2.20.69, you must accept and save the EULA before using the NetApp Hybrid Cloud Control UI or API to run Element storage health checks:
Open the IP address of the management node in a web browser:
https://<ManagementNodeIP>
Log in to NetApp Hybrid Cloud Control by providing the storage cluster administrator credentials.
Select Upgrade near the top right of the interface.
The EULA pops up. Scroll down, select I accept for current and all future updates, and select Save.
You can run health checks using the NetApp Hybrid Cloud Control UI, the NetApp Hybrid Cloud Control API, or the HealthTools suite:
You can also find out more about storage health checks that are run by the service:
Use NetApp Hybrid Cloud Control to run Element storage health checks prior to upgrading storage
Using NetApp Hybrid Cloud Control, you can verify that a storage cluster is ready to be upgraded.
On the Upgrades page, select the Storage tab.
Select the health check
for the cluster you want to check for upgrade readiness. -
On the Storage Health Check page, select Run Health Check.
If there are issues, do the following:
Go to the specific KB article listed for each issue or perform the specified remedy.
If a KB is specified, complete the process described in the relevant KB article.
After you have resolved cluster issues, select Re-Run Health Check.
After the health check completes without errors, the storage cluster is ready to upgrade. See storage node upgrade instructions to proceed.
Use API to run Element storage health checks prior to upgrading storage
You can use REST API to verify that a storage cluster is ready to be upgraded. The health check verifies that there are no obstacles to upgrading, such as pending nodes, disk space issues, and cluster faults.
Locate the storage cluster ID:
Open the management node REST API UI on the management node:
https://<ManagementNodeIP>/mnode
Select Authorize and complete the following:
Enter the cluster user name and password.
Enter the client ID as
mnode-clientif the value is not already populated. -
Select Authorize to begin a session.
Close the authorization window.
From the REST API UI, select
GET /assets. -
Select Try it out.
Select Execute.
From the response, copy the
"id"from the"storage"section of the cluster you intend to check for upgrade readiness.Do not use the "parent"value in this section because this is the management node’s ID, not the storage cluster’s ID."config": {}, "credentialid": "12bbb2b2-f1be-123b-1234-12c3d4bc123e", "host_name": "SF_DEMO", "id": "12cc3a45-e6e7-8d91-a2bb-0bdb3456b789", "ip": "10.123.12.12", "parent": "d123ec42-456e-8912-ad3e-4bd56f4a789a", "sshcredentialid": null, "ssl_certificate": null
Run health checks on the storage cluster:
Open the storage REST API UI on the management node:
https://<ManagementNodeIP>/storage/1/
Select POST /health-checks.
Select Try it out.
In the parameter field, enter the storage cluster ID obtained in Step 1.
{ "config": {}, "storageId": "123a45b6-1a2b-12a3-1234-1a2b34c567d8" } -
Select Execute to run a health check on the specified storage cluster.
The response should indicate state as
initializing:{ "_links": { "collection": "https://10.117.149.231/storage/1/health-checks", "log": "https://10.117.149.231/storage/1/health-checks/358f073f-896e-4751-ab7b-ccbb5f61f9fc/log", "self": "https://10.117.149.231/storage/1/health-checks/358f073f-896e-4751-ab7b-ccbb5f61f9fc" }, "config": {}, "dateCompleted": null, "dateCreated": "2020-02-21T22:11:15.476937+00:00", "healthCheckId": "358f073f-896e-4751-ab7b-ccbb5f61f9fc", "state": "initializing", "status": null, "storageId": "c6d124b2-396a-4417-8a47-df10d647f4ab", "taskId": "73f4df64-bda5-42c1-9074-b4e7843dbb77" } -
Copy the
healthCheckIDthat is part of response.
Verify the results of the health checks:
Select GET /health-checks/{healthCheckId}.
Select Try it out.
Enter the health check ID in the parameter field.
Select Execute.
Scroll to the bottom of the response body.
If all health checks are successful, the return is similar to the following example:
"message": "All checks completed successfully.", "percent": 100, "timestamp": "2020-03-06T00:03:16.321621Z"
If the
messagereturn indicates that there were problems regarding cluster health, do the following:-
Select GET /health-checks/{healthCheckId}/log
Select Try it out.
Select Execute.
Review any specific errors and obtain their associated KB article links.
After you have resolved cluster issues, run GET /health-checks/{healthCheckId}/log again.
Use HealthTools to run Element storage health checks prior to upgrading storage
You can verify that the storage cluster is ready to be upgraded by using the sfupgradecheck command. This command verifies information such as pending nodes, disk space, and cluster faults.
If your management node is at a dark site without external connectivity, the upgrade readiness check needs the metadata.json file you downloaded during HealthTools upgrades to run successfully.
This procedure describes how to address upgrade checks that yield one of the following results:
Running the
sfupgradecheckcommand runs successfully. Your cluster is upgrade ready. -
Checks within the
sfupgradechecktool fail with an error message. Your cluster is not upgrade ready and additional steps are required. -
Your upgrade check fails with an error message that HealthTools is out-of-date.
Your upgrade check fails because your management node is on a dark site.
Run the
sfupgradecheckcommand:sfupgradecheck -u <cluster-user-name> MVIP
For passwords that contain special characters, add a backslash ( \) before each special character. For example,mypass!@1should be entered asmypass\!\@.Sample input command with sample output in which no errors appear and you are ready to upgrade:
sfupgradecheck -u admin 10.117.78.244
check_pending_nodes: Test Description: Verify no pending nodes in cluster More information: https://kb.netapp.com/support/s/article/ka11A0000008ltOQAQ/pendingnodes check_cluster_faults: Test Description: Report any cluster faults check_root_disk_space: Test Description: Verify node root directory has at least 12 GBs of available disk space Passed node IDs: 1, 2, 3 More information: https://kb.netapp.com/support/s/article/ka11A0000008ltTQAQ/ SolidFire-Disk-space-error check_mnode_connectivity: Test Description: Verify storage nodes can communicate with management node Passed node IDs: 1, 2, 3 More information: https://kb.netapp.com/support/s/article/ka11A0000008ltYQAQ/mNodeconnectivity check_files: Test Description: Verify options file exists Passed node IDs: 1, 2, 3 check_cores: Test Description: Verify no core or dump files exists Passed node IDs: 1, 2, 3 check_upload_speed: Test Description: Measure the upload speed between the storage node and the management node Node ID: 1 Upload speed: 90063.90 KBs/sec Node ID: 3 Upload speed: 106511.44 KBs/sec Node ID: 2 Upload speed: 85038.75 KBs/sec
If there are errors, additional actions are required. See the following sub-sections for details.
If you see an error message related to one of the health checks, follow these steps:
Review the
sfupgradecheckerror message.Sample response:
The following tests failed: check_root_disk_space: Test Description: Verify node root directory has at least 12 GBs of available disk space Severity: ERROR Failed node IDs: 2 Remedy: Remove unneeded files from root drive More information: https://kb.netapp.com/support/s/article/ka11A0000008ltTQAQ/SolidFire- Disk-space-error check_pending_nodes: Test Description: Verify no pending nodes in cluster More information: https://kb.netapp.com/support/s/article/ka11A0000008ltOQAQ/pendingnodes check_cluster_faults: Test Description: Report any cluster faults check_root_disk_space: Test Description: Verify node root directory has at least 12 GBs of available disk space Passed node IDs: 1, 3 More information: https://kb.netapp.com/support/s/article/ka11A0000008ltTQAQ/SolidFire- Disk-space-error check_mnode_connectivity: Test Description: Verify storage nodes can communicate with management node Passed node IDs: 1, 2, 3 More information: https://kb.netapp.com/support/s/article/ka11A0000008ltYQAQ/mNodeconnectivity check_files: Test Description: Verify options file exists Passed node IDs: 1, 2, 3 check_cores: Test Description: Verify no core or dump files exists Passed node IDs: 1, 2, 3 check_upload_speed: Test Description: Measure the upload speed between the storage node and the management node Node ID: 1 Upload speed: 86518.82 KBs/sec Node ID: 3 Upload speed: 84112.79 KBs/sec Node ID: 2 Upload speed: 93498.94 KBs/sec
In this example, node 1 is low on disk space. You can find more information in the knowledge base (KB) article listed in the error message.
HealthTools is out of date
If you see an error message indicating that HealthTools is not the latest version, follow these instructions:
Review the error message and note that the upgrade check fails.
Sample response:
sfupgradecheck failed: HealthTools is out of date: installed version: 2018.02.01.200 latest version: 2020.03.01.09. The latest version of the HealthTools can be downloaded from: https://mysupport.netapp.com/NOW/cgi-bin/software/ Or rerun with the -n option
Follow the instructions described in the response.
Your management node is on a dark site
Review the message and note that the upgrade check fails:
Sample response:
sfupgradecheck failed: Unable to verify latest available version of healthtools.
Download a JSON file from the NetApp Support Site on a computer that is not the management node and rename it to
metadata.json. -
Run the following command:
sfupgradecheck -l --metadata=<path-to-metadata-json>
For details, see additional HealthTools upgrades information for dark sites.
Verify that the HealthTools suite is up-to-date by running the following command:
sfupgradecheck -u <cluster-user-name> -p <cluster-password> MVIP
Storage health checks made by the service
Storage health checks make the following checks per cluster.
| Check Name | Node/Cluster | Description |
check_async_results |
Cluster |
Verifies that the number of asynchronous results in the database is below a threshold number. |
check_cluster_faults |
Cluster |
Verifies that there are no upgrade blocking cluster faults (as defined in Element source). |
check_upload_speed |
Node |
Measures the upload speed between the storage node and the management node. |
connection_speed_check |
Node |
Verifies that nodes have connectivity to the management node serving upgrade packages and estimates connection speed. |
check_cores |
Node |
Checks for kernel crash dump and core files on the node. The check fails for any crashes in a recent time period (threshold 7 days). |
check_root_disk_space |
Node |
Verifies the root file system has sufficient free space to perform an upgrade. |
check_var_log_disk_space |
Node |
Verifies that |
check_pending_nodes |
Cluster |
Verifies that there are no pending nodes on the cluster. |
