Configure SNMP traps
PDF of this doc site
Manage storage with Element software
Creating your file...
System administrators can use SNMP traps, also referred to as notifications, to monitor the health of the SolidFire cluster.
When SNMP traps are enabled, the SolidFire cluster generates traps associated with event log entries and system alerts. To receive SNMP notifications, you need to choose the traps that should be generated and identify the recipients of the trap information. By default, no traps are generated.
Click Cluster > SNMP.
Select one or more types of traps in the SNMP Trap Settings section that the system should generate:
Cluster Fault Traps
Cluster Resolved Fault Traps
Cluster Event Traps
In the Trap Recipients section, enter the host, port, and community string information for a recipient.
Optional: To add another trap recipient, click Add a Trap Recipient and enter host, port, and community string information.
Click Save Changes.
