The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Delete a virtual network
PDF of this doc site
Manage storage with Element software
Protect your data
Perform replication between NetApp Element software and ONTAP (ONTAP CLI)
Creating your file...
Your file is ready
You can remove a virtual network object. You must add the address blocks to another virtual network before you remove a virtual network.
Click Cluster > Network.
Click the Actions icon for the VLAN you want to delete.
Click Delete.
Confirm the message.
