Troubleshoot the FIPS drive feature
Using the NetApp Element software UI, you can view alerts for information about cluster faults or errors in the system related to the FIPS drives feature.
Using the Element UI, select Reporting > Alerts.
Look for cluster faults including:
FIPS drives mismatched
FIPS drives out of compliance
For resolution suggestions, see Cluster Fault code information.
