The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Troubleshoot the FIPS drive feature
PDF of this doc site
Manage storage with Element software
Protect your data
Replication between NetApp Element software and ONTAP (ONTAP CLI)
Creating your file...
Your file is ready
Using the NetApp Element software UI, you can view alerts for information about cluster faults or errors in the system related to the FIPS drives feature.
Using the Element UI, select Reporting > Alerts.
Look for cluster faults including:
FIPS drives mismatched
FIPS drives out of compliance
For resolution suggestions, see Cluster Fault code information.
