Element Software
Troubleshoot the FIPS drive feature
Contributors netapp-pcarriga
Using the NetApp Element software UI, you can view alerts for information about cluster faults or errors in the system related to the FIPS drives feature.
  1. Using the Element UI, select Reporting > Alerts.
  2. Look for cluster faults including:
    • FIPS drives mismatched
    • FIPS drives out of compliance
  3. For resolution suggestions, see Cluster Fault code information.
