Create a relationship from an ONTAP source to an Element destination
PDF of this doc site
Manage storage with Element software
Protect your data
Perform replication between NetApp Element software and ONTAP (ONTAP CLI)
Creating your file...
Beginning with ONTAP 9.4, you can use SnapMirror to replicate snapshot copies of a LUN created on an ONTAP source back to an Element destination. You might be using the LUN to migrate data from ONTAP to Element software.
The Element destination node must have been made accessible to ONTAP.
The Element volume must have been enabled for SnapMirror replication.
You must specify the Element destination path in the form <hostip:>/lun/<name>
, where “lun” is the actual string “lun” and name
is the name of the Element volume.
Replication rules are as follows:
The replication relationship must have a policy of type “async-mirror”.
You can use a default or custom policy.
Only iSCSI LUNs are supported.
You cannot replicate more than one LUN from an ONTAP volume to an Element volume.
You cannot replicate a LUN from an ONTAP volume to multiple Element volumes.
Create a replication relationship from an ONTAP source to an Element destination:
snapmirror create -source-path <SVM:volume>|<cluster://SVM/volume> -destination-path <hostip:>/lun/<name> -type XDP -schedule schedule -policy <policy>
For complete command syntax, see the man page.
The following example creates a SnapMirror DR relationship using the default
MirrorLatest
policy:cluster_dst::> snapmirror create -source-path svm_1:volA_dst -destination-path 10.0.0.11:/lun/0005 -type XDP -schedule my_daily -policy MirrorLatest
The following example creates a SnapMirror DR relationship using the custom
my_mirror
policy:cluster_dst::> snapmirror create -source-path svm_1:volA_dst -destination-path 10.0.0.11:/lun/0005 -type XDP -schedule my_daily -policy my_mirror
Use the snapmirror show
command to verify that the SnapMirror relationship was created. For complete command syntax, see the man page.
