Element Software
View or edit existing controller assets
Contributors netapp-pcarriga
You can view information about and edit existing VMware vCenter controllers in the management node configuration using the REST API. Controllers are VMware vCenter instances registered to the management node for your NetApp SolidFire installation.
Before you begin
  • Ensure that your cluster version is running NetApp Element software 11.3 or later.
  • Ensure that you have deployed a management node running version 11.3 or later.
Access the management services REST API
Steps
  1. Access the REST API UI for management services by entering the management node IP address followed by /vcenter/1/:
    https://<ManagementNodeIP>/vcenter/1/
  2. Select Authorize or any lock icon and complete the following:
    1. Enter the cluster user name and password.
    2. Enter the client ID as mnode-client.
    3. Select Authorize to begin a session.
    4. Close the window.
View stored information about existing controllers
You can list existing vCenter controllers that are registered with the management node and view stored information about them using the REST API.
Steps
  1. Select GET /compute/controllers.
  2. Select Try it out.
  3. Select Execute.
    The API returns a list of all known vCenter controllers, along with the IP address, controller ID, hostname, and user ID used to communicate with each controller.
  4. If you want the connection status of a particular controller, copy the controller ID from the id field of that controller to your clipboard and see View the status of an existing controller.
You can view the status of any of the existing vCenter controllers registered with the management node. The API returns a status indicating whether NetApp Hybrid Cloud Control can connect with the vCenter controller as well as the reason for that status.
Steps
  1. Select GET /compute/controllers/{controller_id}/status.
  3. Enter the controller ID you copied earlier in the controller_id parameter.
  4. Select Execute.
    The API returns a status of this particular vCenter controller, along with a reason for that status.
Edit the stored properties of a controller
You can edit the stored user name or password for any of the existing vCenter controllers registered with the management node. You cannot edit the stored IP address of an existing vCenter controller.
Steps
  1. Select PUT /compute/controllers/{controller_id}.
  2. Enter the controller ID of a vCenter controller in the controller_id parameter.
  3. Select Try it out.
  4. Change either of the following parameters in the Request body field:
    Parameter Type Description
    userId
    string
    Change the user ID used to communicate with the vCenter controller (the user must have administrator privileges).
    password
    string
    Change the password used to communicate with the vCenter controller.
  5. Select Execute.
    The API returns updated controller information.
Find more information
