Element Software
Accessing storage nodes using SSH for basic troubleshooting
Contributors netapp-pcarriga
Beginning with Element 12.5, you can use the sfreadonly system account on the storage nodes for basic troubleshooting. You can also enable and open remote support tunnel access for NetApp Support for advanced troubleshooting.
The sfreadonly system account enables access to run basic Linux system and network troubleshooting commands, including ping.
Warning Unless advised by NetApp Support, any alterations to this system are unsupported, voiding your support contract, and might result in instability or inaccessibility of data.
Before you begin
  • Write permissions: Verify that you have write permissions to the current working directory.
  • (Optional) Generate your own key pair: Run ssh-keygen from Windows 10, MacOS, or Linux distribution. This is a one-time action to create a user key pair and can be reused for future troubleshooting sessions. You might want to use certificates associated with employee accounts, which would also work in this model.
  • Enable SSH capability on the management node: To enable remote access functionality on the management mode, see this topic. For management services 2.18 and later, the capability for remote access is disabled on the management node by default.
  • Enable SSH capability on the storage cluster: To enable remote access functionality on the storage cluster nodes, see this topic.
  • Firewall configuration: If your management node is behind a proxy server, the following TCP ports are required in the sshd.config file:
    TCP port Description Connection direction
    443
    API calls/HTTPS for reverse port forwarding via open support tunnel to the web UI
    Management node to storage nodes
    22
    SSH login access
    Management node to storage nodes or from storage nodes to management node
Troubleshoot a cluster node
You can perform basic troubleshooting using the sfreadonly system account:
Steps
  1. SSH to the management node using your account login credentials you selected when installing the management node VM.
  2. On the management node, go to /sf/bin.
  3. Find the appropriate script for your system:
    • SignSshKeys.ps1
    • SignSshKeys.py
    • SignSshKeys.sh
      Note
      SignSshKeys.ps1 is dependent on PowerShell 7 or later and SignSshKeys.py is dependent on Python 3.6.0 or later and the requests module.
      The SignSshKeys script writes user, user.pub, and user-cert.pub files into the current working directory, which are later used by the ssh command. However, when a public key file is provided to the script, only a <public_key> file (with <public_key> replaced with the prefix of the public key file passed into the script) is written out to the directory.
  4. Run the script on the management node to generate the SSH keychain. The script enables SSH access using the sfreadonly system account across all nodes in the cluster.
    SignSshKeys --ip [ip address] --user [username] --duration [hours] --publickey [public key path]
    1. Replace the value in [ ] brackets (including the brackets) for each of the following parameters:
      Note You can use either the abbreviated or full form parameter.
      • --ip | -i [ip address]: IP address of the target node for the API to run against.
      • --user | -u [username]: Cluster user used to run the API call.
      • (Optional) --duration | -d [hours]: The duration a signed key should remain valid as an integer in hours. The default is 24 hours.
      • (Optional) --publickey | -k [public key path]: The path to a public key, if the user chooses to provide one.
    2. Compare your input against the following sample command. In this example, 10.116.139.195 is the IP of the storage node, admin is the cluster username, and the duration of key validity is two hours:
      sh /sf/bin/SignSshKeys.sh --ip 10.116.139.195 --user admin --duration 2
    3. Run the command.
  5. SSH to the node IPs:
    ssh -i user sfreadonly@[node_ip]
    You will be able to run basic Linux system and network troubleshooting commands, such as ping, and other read-only commands.
  6. (Optional) Disable remote access functionality again after troubleshooting is complete.
    Note SSH remains enabled on the management node if you do not disable it. SSH enabled configuration persists on the management node through updates and upgrades until it is manually disabled.
Troubleshoot a cluster node with NetApp Support
NetApp Support can perform advanced troubleshooting with a system account that allows a technician to run deeper Element diagnostics.
Steps
  2. Run the rst command with the port number sent by NetApp Support to open the support tunnel:
    rst -r sfsupport.solidfire.com -u element -p <port_number>
    NetApp Support will log in to your management node using the support tunnel.
  3. On the management node, go to /sf/bin.
  4. Find the appropriate script for your system:
    • SignSshKeys.ps1
    • SignSshKeys.py
    • SignSshKeys.sh
      Note
  5. Run the script to generate the SSH keychain with the --sfadmin flag. The script enables SSH across all nodes.
    SignSshKeys --ip [ip address] --user [username] --duration [hours] --sfadmin
    Note
    To SSH as --sfadmin to a clustered node, you must generate the SSH keychain using a --user with supportAdmin access on the cluster.
    To configure supportAdmin access for cluster administrator accounts, you can use the Element UI or APIs:
    To add supportAdmin access, you must have cluster administrator or administrator privileges.
    2. Compare your input against the following sample command. In this example, 192.168.0.1 is the IP of the storage node, admin is the cluster username, duration of key validity is two hours, and --sfadmin allows NetApp Support node access for troubleshooting:
      sh /sf/bin/SignSshKeys.sh --ip 192.168.0.1 --user admin --duration 2 --sfadmin
    3. Run the command.
  6. SSH to the node IPs:
    ssh -i user sfadmin@[node_ip]
  7. To close the remote support tunnel, enter the following:
    rst --killall
  8. (Optional) Disable remote access functionality again after troubleshooting is complete.
Troubleshoot a node that is not part of cluster
You can perform basic troubleshooting of a node that has not yet been added to a cluster. You can use the sfreadonly system account for this purpose with or without the help of NetApp Support. If you have a management node set up, you can use it for SSH and run the script provided for this task.
  1. From a Windows, Linux, or Mac machine that has an SSH client installed, run the appropriate script for your system provided by NetApp Support.
  2. SSH to the node IP:
  3. (Optional) Disable remote access functionality again after troubleshooting is complete.
Find more information
