Element Software
Manage drives
Contributors netapp-pcarriga
Each node contains one or more physical drives that are used to store a portion of the data for the cluster. The cluster utilizes the capacity and performance of the drive after the drive has been successfully added to a cluster. You can use the Element UI to manage drives.
Drives details
The Drives page on the Cluster tab provides a list of the active drives in the cluster. You can filter the page by selecting from the Active, Available, Removing, Erasing, and Failed tabs.
When you first initialize a cluster, the active drives list is empty. You can add drives that are unassigned to a cluster and listed in the Available tab after a new SolidFire cluster is created.
The following elements appear in the list of active drives.
  • Drive ID
    The sequential number assigned to the drive.
  • Node ID
    The node number assigned when the node is added to the cluster.
  • Node Name
    The name of the node that houses the drive.
  • Slot
    The slot number where the drive is physically located.
  • Capacity
    The size of the drive, in GB.
  • Serial
    The serial number of the drive.
  • Wear Remaining
    The wear level indicator.
    The storage system reports the approximate amount of wear available on each solid-state drive (SSD) for writing and erasing data. A drive that has consumed 5 percent of its designed write and erase cycles reports 95 percent wear remaining. The system does not refresh drive wear information automatically; you can refresh or close and reload the page to refresh the information.
  • Type
    The type of drive. The type can be either block or metadata.
