Element Software
Protocol endpoints details
Contributors netapp-pcarriga
The Protocol Endpoints page on the VVols tab provides protocol endpoint information.
  • Primary Provider ID
    The ID of the primary protocol endpoint provider.
  • Secondary Provider ID
    The ID of the secondary protocol endpoint provider.
  • Protocol Endpoint ID
    The UUID of the protocol endpoint.
  • Protocol Endpoint State
    The status of the protocol endpoint. Possible values are as follows:
    • Active: The protocol endpoint is in use.
    • Start: The protocol endpoint is starting.
    • Failover: The protocol endpoint has failed over.
    • Reserved: The protocol endpoint is reserved.
  • Provider Type
    The type of the protocol endpoint's provider. Possible values are as follows:
    • Primary
    • Secondary
  • SCSI NAA Device ID
    The globally unique SCSI device identifier for the protocol endpoint in NAA IEEE Registered Extended Format.
