View information about system events
You can view information about various events detected in the system. The system refreshes the event messages every 30 seconds. The event log displays key events for the cluster.
In the Element UI, select Reporting > Event Log.
For every event, you see the following information:
Item
ID
Unique ID associated with each event.
Event Type
The type of event being logged, for example, API events or clone events.
Message
Message associated with the event.
Details
Information that helps identify why the event occurred.
Service ID
The service that reported the event (if applicable).
Node
The node that reported the event (if applicable).
Drive ID
The drive that reported the event (if applicable).
Event Time
The time the event occurred.
