Element Software
Configure an SNMP requestor
Contributors amgrissino netapp-pcarriga netapp-yvonneo
When SNMP version 2 is enabled, you can enable or disable a requestor, and configure requestors to receive authorized SNMP requests.
  1. Click Cluster › SNMP.
  2. Under General SNMP Settings, click Yes to enable SNMP.
  3. From the Version list, select Version 2.
  4. In the Requestors section, enter the Community String and Network information.
    Note By default, the community string is public, and the network is localhost. You can change these default settings.
  5. Optional: To add another requestor, click Add a Requestor and enter the Community String and Network information.
  6. Click Save Changes.
