Architecture
Solution Technology
This solution is designed with a NetApp HCI system that contains the following components:
Two H615c compute nodes with NVIDIA T4 GPUs
Two H410c compute nodes
Two H410s storage nodes
Two Mellanox SN2010 10GbE/25GbE switches
Architectural Diagram
The following diagram illustrates the solution architecture for the NetApp HCI AI inferencing solution.
The following diagram illustrates the virtual and physical elements of this solution.
A VMware infrastructure is used to host the management services required by this inferencing solution. These services do not need to be deployed on a dedicated infrastructure; they can coexist with any existing workloads. The NetApp Deployment Engine (NDE) uses the H410c and H410s nodes to deploy the VMware infrastructure.
After NDE has completed the configuration, the following components are deployed as VMs in the virtual infrastructure:
Deployment Jump VM. Used to automate the deployment of NVIDIA DeepOps. See NVIDIA DeepOps and storage management using NetApp Trident.
ONTAP Select. An instance of ONTAP Select is deployed to provide NFS file services and persistent storage to the AI workload running on Kubernetes.
Kubernetes Masters. During deployment, three VMs are installed and configured with a supported Linux distribution and configured as Kubernetes master nodes. After the management services have been set up, two H615c compute nodes with NVIDIA T4 GPUs are installed with a supported Linux distribution. These two nodes function as the Kubernetes worker nodes and provide the infrastructure for the inferencing platform.
Hardware Requirements
The following table lists the hardware components that are required to implement the solution. The hardware components that are used in any particular implementation of the solution might vary based on customer requirements.
| Layer | Product Family | Quantity | Details |
Compute |
H615c |
2 |
3 NVIDIA Tesla T4 GPUs per node |
H410c |
2 |
Compute nodes for management infrastructure |
Storage |
H410s |
2 |
Storage for OS and workload |
Network |
Mellanox SN2010 |
2 |
10G/25G switches |
Software Requirements
The following table lists the software components that are required to implement the solution. The software components that are used in any particular implementation of the solution might vary based on customer requirements.
| Layer | Software | Version |
Storage |
NetApp Element software |
12.0.0.333 |
ONTAP Select |
9.7 |
NetApp Trident |
20.07 |
NetApp HCI engine |
NDE |
1.8 |
Hypervisor |
Hypervisor |
VMware vSphere ESXi 6.7U1 |
Hypervisor Management System |
VMware vCenter Server 6.7U1 |
Inferencing Platform |
NVIDIA DeepOps |
20.08 |
NVIDIA GPU Operator |
1.1.7 |
Ansible |
2.9.5 |
Kubernetes |
1.17.9 |
Docker |
Docker CE 18.09.7 |
CUDA Version |
10.2 |
GPU Device Plugin |
0.6.0 |
Helm |
3.1.2 |
NVIDIA Tesla Driver |
440.64.00 |
NVIDIA Triton Inference Server |
2.1.0 – NGC Container v20.07 |
K8 Master VMs |
Linux |
Any supported distribution across NetApp IMT, NVIDIA DeepOps, and GPUOperator |
Host OS/ K8 Worker Nodes |
Linux |
