NetApp HCI
NetApp HCI product overview
Contributors netapp-pcarriga netapp-yvonneo netapp-revathid
NetApp HCI is an enterprise-scale hybrid cloud infrastructure design that combines storage, compute, networking, and hypervisor—and adds capabilities that span public and private clouds.
NetApp’s disaggregated hybrid cloud infrastructure allows independent scaling of compute and storage, adapting to workloads with guaranteed performance.
  • Meets hybrid multicloud demand
  • Scales compute and storage independently
  • Simplifies data services orchestration across hybrid multiclouds
Components of NetApp HCI
Here is an overview of the various components of the NetApp HCI environment:
The image shows the various components in the NetApp HCI environment
  • NetApp HCI provides both storage and compute resources. You use the NetApp Deployment Engine wizard to deploy NetApp HCI. After successful deployment, compute nodes appear as ESXi hosts and you can manage them in VMware vSphere Web Client.
  • Management services or microservices include the Active IQ collector, QoSSIOC for the vCenter Plug-in, and mNode service; they are updated frequently as service bundles. As of the Element 11.3 release, management services are hosted on the management node, allowing for quicker updates of select software services outside of major releases. The management node (mNode) is a virtual machine that runs in parallel with one or more Element software-based storage clusters. It is used to upgrade and provide system services including monitoring and telemetry, manage cluster assets and settings, run system tests and utilities, and enable NetApp Support access for troubleshooting.
    Tip Learn more about management services releases.
  • NetApp Hybrid Cloud Control enables you to manage NetApp HCI. You can upgrade management services, expand your system, collect logs, and monitor your installation by using NetApp SolidFire Active IQ. You log in to NetApp Hybrid Cloud Control by browsing to the IP address of the management node.
  • The NetApp Element Plug-in for vCenter Server is a web-based tool integrated with the vSphere user interface (UI). The plug-in is an extension and scalable, user-friendly interface for VMware vSphere that can manage and monitor storage clusters running NetApp Element software. The plug-in provides an alternative to the Element UI. You can use the plug-in user interface to discover and configure clusters, and to manage, monitor, and allocate storage from cluster capacity to configure datastores and virtual datastores (for virtual volumes). A cluster appears on the network as a single local group that is represented to hosts and administrators by virtual IP addresses. You can also monitor cluster activity with real-time reporting, including error and alert messaging for any event that might occur while performing various operations.
  • By default, NetApp HCI sends performance and alert statistics to the NetApp SolidFire Active IQ service. As part of your normal support contract, NetApp Support monitors this data and alerts you to any performance bottlenecks or potential system issues. You need to create a NetApp Support account if you do not already have one (even if you have an existing SolidFire Active IQ account) so that you can take advantage of this service.
    Tip Learn more about NetApp SolidFire Active IQ.
NetApp HCI URLs
Here are the common URLs you use with NetApp HCI:
URL Description
https://[IPv4 address of Bond1G interface on a storage node]
Access the NetApp Deployment Engine wizard to install and configure NetApp HCI. Learn more.
https://<ManagementNodeIP>;
Access NetApp Hybrid Cloud Control to upgrade, expand, and monitor your NetApp HCI installation, and update management services. Learn more.
https://[IP address]:442
From the per-node UI, access network and cluster settings and utilize system tests and utilities. Learn more.
https://<ManagementNodeIP>:9443
Register the vCenter Plug-in package in the vSphere Web Client.
https://activeiq.solidfire.com
Monitor data and receive alerts to any performance bottlenecks or potential system issues.
https://<ManagementNodeIP>/mnode
Manually update management services using the REST API UI from the management node.
https://[storage cluster MVIP address]
Access the NetApp Element software UI.
Find more information
