NetApp HCI
Compute Firmware Bundle 2.27 Release Notes
Contributors netapp-pcarriga netapp-yvonneo netapp-nkatie
The downloadable compute firmware bundle contains the latest BIOS and BMC feature enhancements, bugfixes, and hardware support for all supported NetApp HCI compute nodes.
What's New
Version 2.27 contains general bugfixes.
Updated firmware components
This firmware package contains the following firmware versions for hardware components, with updated versions in bold:
Component H300E, H500E, H700E H410C H610C H615C
BIOS
NA2.1
NA3.7
3B03
3B08.CO
BMC
6.84.00
6.71.18
4.00.07
4.68.07
NIC / Mellanox
14.25.1020
14.25.1020
14.25.1020
14.24.1000
Changes in firmware components
Here are the details of the improvements and changes included in each new firmware component:
Node and firmware component Improvements and changes
H300E, H500E, H700E BMC 6.84.00
Disabled TLS 1.0 and 1.1 support (this BMC version was delivered in Compute Firmware Bundle 12.2.109 as well.)
H610C BIOS 3B03
  • Improved handling of memory failures
  • Added the latest Intel NVM firmware updates
  • Updated the RC version to 602.D02 (IPU 2020.1)
  • Updated the microcode version to MCU x6906
  • Updated the SPS ME version to 04.01.04.381.0
  • Removed the Restore on AC Power Loss and Current Restore on AC Power Loss BIOS setup options
H615C BIOS 3B08.CO
  • Updated the microcode version to MCU x2F01
  • Changed the option Attempt Fast Cold Boot default value to disable
  • Changed the option Allow Correctables default value to enable
H410C BMC 6.71.18
Add BMC reporting for ePPR memory SEL events
H610C BMC 4.00.07
Add remote syslog support
H615C BMC 4.68.07
Mellanox NIC firmware driver compatibility
The updated Mellanox firmware versions 14.25.1020 and 14.24.1000 are compatible only with the following versions of the VMware ESXi driver:
  • ESXi 7.0: H300E/H500E/H700E/H410C: Version 4.19.16.1
  • ESXi 7.0: H610C/H615C: Version 4.17.15.16
  • ESXi 6.7: Version 4.17.15.16
  • ESXi 6.5: Version 4.16.13.5
Note Before upgrading to version 2.27, make sure you check the current ESXi driver version. If the driver is out of date, upgrade the driver first. Then upgrade the compute firmware to version 2.27 for your compute nodes. Visit Update compute node drivers for instructions on updating your compute node drivers, which include the ESXi driver.
While NetApp Deployment Engine 1.8P1 does not deploy ESXi version 7.0, ESXi 7.0 is supported as a self-install or manual upgrade option. When you manually install or upgrade host OSes, NetApp cannot control the drivers and firmware for these OSes.
Download Compute Firmware Bundle 2.27
To download the Compute Firmware Bundle, go to the NetApp HCI Compute Firmware Bundle page.
Visit Update compute node firmware for instructions on updating your compute node firmware.
Resolved issues
The following are issues that have been resolved in this release.
Issue Description
CSD-3321 / CSESF-129
The BMC can hang and become inaccessible with the error BMC Self Test Failed. This is resolved in H610C BMC 4.00.07 and H615C BMC 4.68.07.
CSESF-234
The H610C BMC web UI inventory API returns the wrong memory serial number format. This is resolved in H610C BMC 4.00.07.
PE-6708
The Bonded NIC pair does not fail over to secondary when the NIC goes down or the port is disabled. This is resolved in Mellanox firmware 14.24.1000.
Known issues
The following are known issues in this release that might affect daily operation in some environments.
Issue Description Workaround
CSESF-295
The compute node firmware update process fails with a BIOS update error when you update the firmware on a H410C node using the downloadable firmware package.
Manually update the BIOS to version NA3.7 on the H410C node:
  1. Browse to the NetApp HCI Downloads page.
  2. Enter H410C_BIOS_3.7 in the drop down list text field.
  3. Select Go.
    Instructions for updating are available in PDF format on the download page.
After you update the BIOS and BMC, update the H410C node firmware using the compute firmware bundle 2.27 package.
CSESF-328
On H410C and H300E/H500E/H700E nodes, one NIC sensor for the Mellanox NIC in the BMC reports status as "NA" and reads "not present".
None
CSESF-309
H410C and H300E/H500E/H700E nodes are unable to bring the Mellanox NIC port up after manually bringing the port down when running VMware EXSi 6.7u1.
Run the following command to recover the ports: esxcli network nic set -n vmnic2 -a
CSESF-303
Network statistics errors are seen for the Mellanox NIC on H410C nodes.
None
CSESF-293 / PE-10130
Mellanox NIC firmware can be downgraded by Bootstrap OS after you upgrade to the Compute Firmware Bundle version 2.27.
Reinstall Compute Firmware Bundle version 2.27.
PE-11033
Under heavy loads, the expected vmnic0 link message is sometimes missing from H615C node log files.
None
PE-11032
Under heavy loads, transmit errors sometimes occur for the Mellanox NIC on H610C nodes.
None
PE-10954
H610C nodes sometimes reflect the incorrect MTU setting after you set the MTU using the Element software Terminal User Interface (TUI).
None
Find more information
