Compute Firmware Bundle 2.146 Release Notes
The downloadable compute firmware bundle contains the latest BIOS and BMC feature enhancements, bugfixes, and hardware support for all supported NetApp HCI compute nodes.
What's New
Version 2.146 contains general bugfixes.
Updated firmware components
This firmware package contains the following firmware versions for hardware components, with updated versions in bold:
| Component | H300E, H500E, H700E | H410C | H610C | H615C |
BIOS |
NAT3.4 |
NATP3.10 |
3B07 |
3B12.CO |
BMC |
6.98.00 |
6.71.20 |
4.04.07 |
4.72.07 |
NIC / Mellanox |
14.25.10.20 |
14.25.10.20 |
14.25.10.20 |
14.25.10.20 |
Changes in firmware components
Here are the details of the improvements and changes included in each new firmware component:
| Node and firmware component | Improvements and changes |
H300E/H500E/H700E NA3.4 |
H410C NATP3.10 |
H610C 3B07 |
H615C 3B12.CO |
H300E/H500E/H700E 6.98.00 |
H610C 4.04.07 |
H615C 4.72.07 |
Mellanox NIC firmware driver compatibility
The updated Mellanox firmware versions 14.25.1020 and 14.24.1000 are compatible only with the following versions of the VMware ESXi driver:
ESXi 7.0: H300E/H500E/H700E/H410C: Version 4.19.16.1
ESXi 7.0: H610C/H615C: Version 4.17.15.16
ESXi 6.7: Version 4.17.15.16
ESXi 6.5: Version 4.16.13.5
Before upgrading to version 2.146, make sure you check the current ESXi driver version. If the driver is out of date, upgrade the driver first. Then upgrade the compute firmware to version 2.146 for your compute nodes. Visit Update compute node drivers for instructions on updating your compute node drivers, which include the ESXi driver. |
While NetApp Deployment Engine 1.8P1 does not deploy ESXi version 7.0, ESXi 7.0 is supported as a self-install or manual upgrade option. When you manually install or upgrade host OSes, NetApp cannot control the drivers and firmware for these OSes.
Download Compute Firmware Bundle 2.146
To download the Compute Firmware Bundle:
Choose Compute_Firmware_Bundle from the drop down list.
Click Go.
Visit Update compute node firmware for instructions on updating your compute node firmware.
Resolved security vulnerabilities
The following are security vulnerabilities that have been resolved in this release:
CVE-2019-20636
CVE-2019-11599, CVE-2020-12826, CVE-2020-12464, CVE-2020-12114
CVE-2019-0151, CVE-2019-0123, CVE-2019-0117
CVE-2016-3706, CVE-2011-5320, CVE-2015-8984, CVE-2015-8983, CVE-2015-8982, CVE-2006-7254, CVE-2005-3590
CVE-2020-20811, CVE-2020-20812
CVE-2020-25641
CVE-2020-14386, CVE-2020-14314, CVE-2020-25641, CVE-2020-1438, CVE-2020-14314, CVE-2020-25641
CVE-2020-8738, CVE-2020-8764, CVE-2020-0590, CVE-2020-8705
CVE-2020-0587, CVE-2020-0591, CVE-2020-0592, CVE-2020-8740
CVE-2020-0592, CVE-2020-0588, CVE-2020-8696
Resolved and known issues
See the Bugs Online tool for details of issues that have been resolved and for any new issues.
Accessing the BOL tool
Navigate to the BOL tool and select Element Software from the drop-down list:
In the keyword search field, type “Compute Firmware Bundle” and click New Search:
A list of resolved or open bugs is displayed. You can further refine the results as shown:
