NetApp HCI
Storage Firmware Bundle 2.27 Release Notes
Contributors netapp-pcarriga netapp-yvonneo netapp-dbagwell
Starting with Element 12.0 and management services version 2.14, you can perform firmware-only upgrades on your storage nodes using the NetApp Hybrid Cloud Control UI and REST API. This procedure does not upgrade Element software and enables you to upgrade storage firmware outside of a major Element release.
Important For H610S storage nodes running Element software version 12.0, you should apply D-patch SUST-909 before you upgrade to storage firmware bundle 2.27. Contact NetApp Support to obtain the D-patch before you upgrade.
What's New
The storage firmware bundle version 2.27 contains various bug fixes and new features, including security vulnerability fixes. You can upgrade the storage firmware using the instructions in Upgrade storage firmware.
Updated firmware components
This firmware package contains the following firmware versions for hardware components, with updated versions in bold:
Component Dell R630 H410S H610S
BIOS
N/A
NA2.1
3B03
BMC
N/A
6.84.00
3.84.07
NIC / Mellanox
14.21.1000
14.22.1002
RMS200
ae3b8cc
7d8422bc
RMS300
7d8422bc
7d8422bc
NVDIMM, Smart
3.1
BPM, Smart
2.16
NVDIMM, Micron Gen1
26.2c
NVDIMM, Micron Gen2
25.3c
PGEM, Micron
1.40
PM863, SED
GXT5404Q
GXT5404Q
PM863, NSED
GXT5103Q
GXT5103Q
PM883, SED
HXT7104Q
HXT7104Q
Hawk-4, SED
8ENP7101
8ENP7101
Hawk-4, NSED
8ENP6101
8ENP6101
PM963, SED
CXV8202Q
PM963, NSED
CXV8501Q
PM983, SED
EDA5302Q
PM983, NSED
EDA5600Q
CD5, SED
0108
CD5, NSED
0108
CD5, FIPS
0108
New BMC features
The following are the new BMC features and changes included in this release:
  • (H610S) Enabled INITRD support, for loading an initial ramdisk at boot time
  • (H610S) Updated SSL help message about X.509 certificates
  • (H610S) Disabled TLS 1.0 and 1.1 support to resolve security vulnerabilities
  • (H610S, H410S) Added the ability to mount remote media using Redfish APIs
  • (H610S) Added support for HTML5 web browser BMC management
  • (H610S) Added remote syslog support, to help with remote data center monitoring and management
Resolved issues
The following are issues that have been resolved in this release:
Issue Description
N/A
The debug user sysadmin can log in using SSH after resetting the BMC.
N/A
When you use the console to ping the BMC IP address, the BMC does not respond.
N/A
During an AC power cycle stress test, the access permissions of the SOLSSH config file are lost.
CSESF-116
During an AC power cycle stress test, "PROCHOT" CPU thermal warnings appear in the BMC logs.
CSESF-121
The create and update service account API takes longer than expected.
CSD-3321 / CSESF-129
The H610S BMC can hang and become inaccessible with the error "BMC Self Test Failed".
CSESF-197
The BMC web UI inventory API returns the wrong memory serial number format.
Resolved security vulnerabilities
The following are security vulnerabilities that have been resolved in this release:
H410S BMC 6.84.00
  • CVE-2019-16649
  • CVE-2019-16650
  • CVE-2019-6260
H610S BMC 3.84.07
  • CVE-2019-1552
  • CVE-2019-1547, CVE-2019-1563
  • CVE-2019-5482
  • CVE-2019-15903
  • CVE-2018-20843
  • CVE-2019-14821, CVE-2019-15916, CVE-2019-16413
  • CVE-2019-10638, CVE-2019-10639
  • CVE-2019-11478, CVE-2019-11479, CVE-2019-11477
  • CVE-2019-12819
  • CVE-2019-14835, CVE-2019-14814, CVE-2019-14816, CVE-2019-16746
  • CVE-2019-19062
  • CVE-2019-19922, CVE-2019-20054
  • CVE-2019-19447, CVE-2019-19767, CVE-2019-10220
Known issues
There are no known issues in this release.
