Storage Firmware Bundle 2.27 Release Notes
Starting with Element 12.0 and management services version 2.14, you can perform firmware-only upgrades on your H-series storage nodes using the NetApp Hybrid Cloud Control UI and REST API. This procedure does not upgrade Element software and enables you to upgrade storage firmware outside of a major Element release.
For H610S storage nodes running Element software version 12.0, you should apply D-patch SUST-909 before you upgrade to storage firmware bundle 2.27. Contact NetApp Support to obtain the D-patch before you upgrade. |
What's New
The storage firmware bundle version 2.27 contains various bug fixes and new features, including security vulnerability fixes. You can upgrade the storage firmware using the instructions in Upgrade storage firmware.
Updated firmware components
This firmware package contains the following firmware versions for hardware components, with updated versions in bold:
| Component | Dell R630 | H410S | H610S |
BIOS |
N/A |
NA2.1 |
3B03 |
BMC |
N/A |
6.84.00 |
3.84.07 |
NIC / Mellanox |
14.21.1000 |
14.22.1002 |
RMS200 |
ae3b8cc |
7d8422bc |
RMS300 |
7d8422bc |
7d8422bc |
NVDIMM, Smart |
3.1 |
BPM, Smart |
2.16 |
NVDIMM, Micron Gen1 |
26.2c |
NVDIMM, Micron Gen2 |
25.3c |
PGEM, Micron |
1.40 |
PM863, SED |
GXT5404Q |
GXT5404Q |
PM863, NSED |
GXT5103Q |
GXT5103Q |
PM883, SED |
HXT7104Q |
HXT7104Q |
Hawk-4, SED |
8ENP7101 |
8ENP7101 |
Hawk-4, NSED |
8ENP6101 |
8ENP6101 |
PM963, SED |
CXV8202Q |
PM963, NSED |
CXV8501Q |
PM983, SED |
EDA5302Q |
PM983, NSED |
EDA5600Q |
CD5, SED |
0108 |
CD5, NSED |
0108 |
CD5, FIPS |
0108 |
New BMC features
The following are the new BMC features and changes included in this release:
(H610S) Enabled INITRD support, for loading an initial ramdisk at boot time
(H610S) Updated SSL help message about X.509 certificates
(H610S) Disabled TLS 1.0 and 1.1 support to resolve security vulnerabilities
(H610S, H410S) Added the ability to mount remote media using Redfish APIs
(H610S) Added support for HTML5 web browser BMC management
(H610S) Added remote syslog support, to help with remote data center monitoring and management
Resolved issues
The following are issues that have been resolved in this release:
| Issue | Description |
N/A |
The debug user sysadmin can log in using SSH after resetting the BMC. |
N/A |
When you use the console to ping the BMC IP address, the BMC does not respond. |
N/A |
During an AC power cycle stress test, the access permissions of the SOLSSH config file are lost. |
CSESF-116 |
During an AC power cycle stress test, "PROCHOT" CPU thermal warnings appear in the BMC logs. |
CSESF-121 |
The create and update service account API takes longer than expected. |
CSD-3321 / CSESF-129 |
The H610S BMC can hang and become inaccessible with the error "BMC Self Test Failed". |
CSESF-197 |
The BMC web UI inventory API returns the wrong memory serial number format. |
Resolved security vulnerabilities
The following are security vulnerabilities that have been resolved in this release:
H410S BMC 6.84.00
CVE-2019-16649
CVE-2019-16650
CVE-2019-6260
H610S BMC 3.84.07
CVE-2019-1552
CVE-2019-1547, CVE-2019-1563
CVE-2019-5482
CVE-2019-15903
CVE-2018-20843
CVE-2019-14821, CVE-2019-15916, CVE-2019-16413
CVE-2019-10638, CVE-2019-10639
CVE-2019-11478, CVE-2019-11479, CVE-2019-11477
CVE-2019-12819
CVE-2019-14835, CVE-2019-14814, CVE-2019-14816, CVE-2019-16746
CVE-2019-19062
CVE-2019-19922, CVE-2019-20054
CVE-2019-19447, CVE-2019-19767, CVE-2019-10220
Known issues
There are no known issues in this release.
