Storage capacity types for Keystone STaaS
The NetApp Keystone STaaS service supports several types of storage capacities. Understanding these different capacity terms can help as you use Keystone.
Logical capacity
This is the amount of storage capacity required to store user data before any data efficiencies provided by the storage array are applied.
Committed capacity
The minimum logical capacity billed each month during the subscription:
Capacity is committed to each performance service level.
Committed capacity and additional service levels can be added during the term.
Changes to committed capacity
During the tenure of a subscription, you can change the committed capacities. However, there are certain preconditions:
The committed capacity can be decreased based on certain conditions. For information, see Capacity reduction.
The committed capacity cannot be increased 90 days prior to the expiry of your subscription, unless the subscription is to be renewed for an additional 12-month term.
You can request changes to committed capacity through the Console or from your Keystone Success Manager (KSM).
For information about requesting changes, see NetApp Keystone support.
Consumed capacity
Consumed capacity refers to the capacity (in TiB of storage) currently being consumed on the service. It is calculated differently based on the data storage type:
Unified or block-optimized storage: Consumed capacity is calculated based on the type of capacity (either logical or physical) selected during the ordering process. The calculation is performed per performance service level instance.
Logical capacity: It is the sum of:
Metered logical capacity, before storage array data efficiencies, to store all instances and types of customer data, such as copies, mirrored copies, versions, and clones.
Physical capacity used to store metadata and differential data of snapshots and certain clones.
Any thick-provisioned physical capacity.
Physical capacity: It is the sum of:
Metered physical capacity, after storage array data efficiencies, to store all instances and types of customer data, such as copies, mirrored copies, versions, and clones.
Physical capacity used to store metadata and differential data of snapshots.
Object storage: Consumed capacity is calculated as the amount of metered physical capacity used to store all instances and types of customer data across all nodes. This calculation is based on the information lifecycle management (ILM) policies configured.
Cloud Volumes ONTAP: Consumed capacity is calculated as the amount of metered provisioned logical capacity of all Cloud Volumes ONTAP volumes.
Burst capacity
The NetApp Keystone service enables you to use additional capacity on top of the committed capacity for a service level. This is referred to as the burst capacity usage.
Note these points:
Burst capacity is agreed upon in the Keystone agreement. It is usually set up to 20% above the committed capacity, and is charged at the same rate as the committed capacity.
Burst capacity can be consumed on an elastic basis and is charged on a daily basis for the consumed average.
Billed capacity
Monthly bill = (committed capacity [TiB] * committed rate [$/TiB]) + (daily average provisioned burst capacity [TiB] * burst rate [$/TiB]). The monthly bill contains a minimum charge based on the committed capacity.
The monthly bill varies beyond the minimum charge based on daily average burst capacity consumption.
