Keystone
2.0
Virtual infrastructure requirements for Keystone Collector
Contributors netapp-shwetav
Your VMware vSphere system must meet several requirements before you can install Keystone Collector.
Prerequisites for the Keystone Collector server VM:
  • Operating system: VMware vCentre server and ESXi 8.0 or later
  • Core: 1 CPU
  • RAM: 2 GB RAM
  • Disk space: 20 GB vDisk
Other requirements
Ensure that the following generic requirements are met:
Networking Requirements
The networking requirements of Keystone Collector are listed in the following table.
Note Keystone Collector requires internet connectivity. You can provide internet connectivity by direct routing through default Gateway (via NAT), or through HTTP Proxy. Both variants are described here.
Source
Destination
Service
Protocol and Ports
Category
Purpose
Keystone Collector (for Keystone ONTAP)
Active IQ Unified Manager (Unified Manager)
HTTPS
TCP 443
Mandatory (if using Keystone ONTAP)
Keystone Collector usage metrics collection for ONTAP
Keystone Collector (for Keystone StorageGRID)
StorageGRID Admin Nodes
HTTPS
TCP 443
Mandatory (if using Keystone StorageGRID)
Keystone Collector usage metrics collection for StorageGRID
Keystone Collector (generic)
Internet (as per URL requirements given later)
HTTPS
TCP 443
Mandatory (internet connectivity)
Keystone Collector software, OS updates, and metrics upload
Customer HTTP Proxy
HTTP Proxy
Customer Proxy Port
Customer DNS Servers
DNS
TCP/UDP 53
Mandatory
DNS resolution
Customer NTP Servers
NTP
UDP 123
Mandatory
Time synchronization
Unified Manager
MYSQL
TCP 3306
Optional Functionality
Performance metrics collection for Keystone Collector
Customer Monitoring System
HTTPS
TCP 7777
Keystone Collector health reporting
Customer's Operations Workstations
Keystone Collector
SSH
TCP 22
Management
Access to the Keystone Collector Management
NetApp ONTAP Cluster and Node Management Addresses
Keystone Collector
HTTP_8000, PING
TCP 8000, ICMP Echo Request/Reply
Webserver for ONTAP firmware updates
Note The default port for MySQL, 3306, is restricted only to localhost during a fresh installation of Unified Manager, which prevents the collection of performance metrics for Keystone Collector. For more information, see ONTAP requirements.
URL access
Keystone Collector needs access to the following internet hosts:
Address
Reason
Keystone Collector software updates and usage reporting
NetApp HQ for billing information and AutoSupport delivery
