Virtual infrastructure requirements for Keystone Collector
Your VMware vSphere system must meet several requirements before you can install Keystone Collector.
Operating system: VMware vCentre server and ESXi 8.0 or later
Core: 1 CPU
RAM: 2 GB RAM
Disk space: 20 GB vDisk
Other requirements
Ensure that the following generic requirements are met:
Networking Requirements
The networking requirements of Keystone Collector are listed in the following table.
Keystone Collector requires internet connectivity. You can provide internet connectivity by direct routing through default Gateway (via NAT), or through HTTP Proxy. Both variants are described here. |
Source |
Destination |
Service |
Protocol and Ports |
Category |
Purpose |
Keystone Collector (for Keystone ONTAP) |
Active IQ Unified Manager (Unified Manager) |
HTTPS |
TCP 443 |
Mandatory (if using Keystone ONTAP) |
Keystone Collector usage metrics collection for ONTAP |
Keystone Collector (for Keystone StorageGRID) |
StorageGRID Admin Nodes |
HTTPS |
TCP 443 |
Mandatory (if using Keystone StorageGRID) |
Keystone Collector usage metrics collection for StorageGRID |
Keystone Collector (generic) |
Internet (as per URL requirements given later) |
HTTPS |
TCP 443 |
Mandatory (internet connectivity) |
Keystone Collector software, OS updates, and metrics upload |
Customer HTTP Proxy |
HTTP Proxy |
Customer Proxy Port |
Customer DNS Servers |
DNS |
TCP/UDP 53 |
Mandatory |
DNS resolution |
Customer NTP Servers |
NTP |
UDP 123 |
Mandatory |
Time synchronization |
Unified Manager |
MYSQL |
TCP 3306 |
Optional Functionality |
Performance metrics collection for Keystone Collector |
Customer Monitoring System |
HTTPS |
TCP 7777 |
Keystone Collector health reporting |
Customer's Operations Workstations |
SSH |
TCP 22 |
Management |
Access to the Keystone Collector Management |
NetApp ONTAP Cluster and Node Management Addresses |
HTTP_8000, PING |
TCP 8000, ICMP Echo Request/Reply |
Webserver for ONTAP firmware updates |
The default port for MySQL, 3306, is restricted only to localhost during a fresh installation of Unified Manager, which prevents the collection of performance metrics for Keystone Collector. For more information, see ONTAP requirements. |
URL access
Keystone Collector needs access to the following internet hosts:
Address |
Reason |
Keystone Collector software updates and usage reporting |
NetApp HQ for billing information and AutoSupport delivery |
