TR-5003: High Throughput Oracle VLDB Implementation on ANF
The solution provides an overview and details for configuring a high-throughput Oracle Very Large Database (VLDB) on Microsoft Azure NetApp Files (ANF) with Oracle Data Guard in the Azure cloud.
Purpose
High throughput and mission-critical Oracle VLDB put a heavy demand on backend database storage. To meet service level agreement (SLA), the database storage must deliver the required capacity and high input/output operations per second (IOPS) while maintaining sub milliseconds latency performance. This is particularly challenging when deploying such a database workload in the public cloud with a shared storage resources environment. Not all storage platforms are created equal. Premium Azure NetApp Files storage in combination with Azure infrastructure can meet the needs of such a highly demanding Oracle workload. In a validated performance benchmark (Oracle database performance on Azure NetApp Files multiple volumes), ANF delivered 2.5 million read IOPS with 700 microseconds latency in a synthetic 100% random select workload via the SLOB tool. With a standard 8k block size, this translates to about 20 GiB/s throughput.
In this documentation, we demonstrate how to set up an Oracle VLDB with Data Guard configuration on ANF storage with multiple NFS volumes and Oracle ASM for storage load balancing. The standby database can be quickly (mins) backed up via snapshot and cloned for read/write access for use cases as desired. NetApp Solutions Engineering team provides an automation toolkit to create and refresh clones with ease at an user defined schedule.
This solution addresses the following use cases:
Implementation of Oracle VLDB in a Data Guard setting on Microsoft Azure NetApp Files storage across Azure regions.
Snapshot backup and clone the physical standby database to serve use cases such as reporting, dev, test, etc. via automation.
Audience
This solution is intended for the following people:
A DBA who sets up Oracle VLDB with Data Guard in Azure cloud for high availability, data protection, and disaster recovery.
A database solution architect interested in Oracle VLDB with Data Guard configuration in the Azure cloud.
A storage administrator who manages Azure NetApp Files storage that supports Oracle database.
An application owner who likes to stand up Oracle VLDB with Data Guard in an Azure cloud environment.
Solution test and validation environment
The testing and validation of this solution was performed in an Azure cloud lab setting that might not match the actual user deployment environment. For more information, see the section Key factors for deployment consideration.
Architecture
Hardware and software components
Hardware |
Azure NetApp Files |
Current version offered by Microsoft |
Two 4 TiB Capacity Pools, Premium Service Level, Auto QoS |
Azure VMs for DB Servers |
Standard B4ms (4 vcpus, 16 GiB memory) |
Three DB VMs, one as the primary DB server, one as the standby DB server, and the third as a clone DB server |
Software |
RedHat Linux |
Red Hat Enterprise Linux 8.6 (LVM) - x64 Gen2 |
Deployed RedHat subscription for testing |
Oracle Grid Infrastructure |
Version 19.18 |
Applied RU patch p34762026_190000_Linux-x86-64.zip |
Oracle Database |
Version 19.18 |
Applied RU patch p34765931_190000_Linux-x86-64.zip |
dNFS OneOff Patch |
p32931941_190000_Linux-x86-64.zip |
Applied to both grid and database |
Oracle OPatch |
Version 12.2.0.1.36 |
Latest patch p6880880_190000_Linux-x86-64.zip |
Ansible |
Version core 2.16.2 |
python version - 3.10.13 |
NFS |
Version 3.0 |
dNFS enabled for Oracle |
Oracle VLDB Data Guard configuration with a simulated NY to LA DR setup
Database |
DB_UNIQUE_NAME |
Oracle Net Service Name |
Primary |
NTAP_NY |
NTAP_NY.internal.cloudapp.net |
Standby |
NTAP_LA |
NTAP_LA.internal.cloudapp.net |
Azure NetApp Files Configuration. Azure NetApp Files are allocated in the Azure NetApp storage account as
Capacity Pools. In these tests and validations, we deployed a 2 TiB capacity pool to host Oracle primary at the East region and a 4 TiB capacity pool to host standby database and DB clone at the West 2 region. ANF capacity pool has three service levels: Standard, Premium, and Ultra. The IO capacity of ANF capacity pool is based on the size of the capacity pool and its service level. At a capacity pool creation, you can set QoS to Auto or Manual and data encryption at rest Single or Double. -
Sizing the Database Volumes. For production deployment, NetApp recommends taking a full assessment of your Oracle database throughput requirement from Oracle AWR report. Take into consideration both the database size as well as the throughput requirements when sizing ANF volumes for database. With auto QoS configuration for ANF, the bandwidth is guaranteed at 128 MiB/s per TiB volume capacity allocated with Ultra Service Level. Higher throughput may need larger volume sizing to meet the requirement.
Single Volume or Multiple Volumes. A single large volume can provide similar performance level as multiple volumes with same aggregate size as the QoS is strictly enforced based on the volume sizing and capacity pool service level. It is recommended to implement multiple volumes (multiple NFS mount points) for Oracle VLDB to better utilize shared backend ANF storage resource pool. Implement Oracle ASM for IO load balancing on multiple NFS volumes.
Application Volume Group. Deploy Application Volume Group (AVG) for Oracle for performance optimization. Volumes deployed by application volume group are placed in the regional or zonal infrastructure to achieve optimized latency and throughput for the application VMs.
Azure VM Consideration. In these tests and validations, we used an Azure VM - Standard_B4ms with 4 vCPUs and16 GiB memory. You need to choose the Azure DB VM appropriately for Oracle VLDB with high throughput requirement. Besides the number of vCPUs and the amount of RAM, the VM network bandwidth (ingress and egress or NIC throughput limit) can become a bottleneck before database storage capacity is reached.
dNFS Configuration. By using dNFS, an Oracle database running on an Azure Virtual Machine with ANF storage can drive significantly more I/O than the native NFS client. Ensure that Oracle dNFS patch p32931941 is applied to address potential bugs.
Solution deployment
It is assumed that you already have your primary Oracle database deployed in an Azure cloud environment within a VNet as the starting point for setting up the Oracle Data Guard. Ideally, the primary database is deployed on ANF storage with NFS mount. Your primary Oracle database can also be running on a NetApp ONTAP storage or any other storage of choices either within the Azure ecosystem or a private data center. The following section demonstrates the configuration for Oracle VLDB on ANF in an Oracle Data Guard setting between a primary Oracle DB in Azure with ANF storage to a physical standby Oracle DB in Azure with ANF storage.
Prerequisites for deployment
Details
Deployment requires the following prerequisites.
An Azure cloud account has been set up, and the necessary VNet and network subnets have been created within your Azure account.
From the Azure cloud portal console, you need to deploy minimum three Azure Linux VMs, one as the primary Oracle DB server, one as the standby Oracle DB server, and a clone target DB server for reporting, dev, and test etc. See the architecture diagram in the previous section for more details about the environment setup. Also review the Microsoft Azure Virtual Machines for more information.
The primary Oracle database should have been installed and configured in the primary Oracle DB server. On the other hand, in the standby Oracle DB server or the clone Oracle DB server, only Oracle software is installed and no Oracle databases are created. Ideally, the Oracle files directories layout should be exactly matching on all Oracle DB servers. For details on NetApp recommendation for automated Oracle deployment in the Azure cloud and ANF, please refer to the following technical reports for help.
TR-4987: Simplified, Automated Oracle Deployment on Azure NetApp Files with NFS
Ensure that you have allocated at least 128G in the Azure VMs root volume in order to have sufficient space to stage Oracle installation files.
From the Azure cloud portal console, deploy two ANF storage capacity pools to host Oracle database volumes. The ANF storage capacity pools should be situated in different regions to mimic a true DataGuard configuration. If you are not familiar with the deployment of ANF storage, see the documentation Quickstart: Set up Azure NetApp Files and create an NFS volume for step-by-step instructions.
When the primary Oracle database and the standby Oracle database are situated in two different regions, a VPN gateway should be configured to allow data traffic flow between two separate VNets. Detailed networking configuration in Azure is beyond the scope of this document. Following screen shots provides some reference on how the VPN gateways are configured, connected, and the data traffics flow are confirmed in the lab.
Lab VPN gateways:
The primary vnet gateway:
Vnet gateway connection status:
Validate that the traffic flows are established (click on three dots to open the page):
Refer to this documentation Deploy application volume group for Oracle to deploy Application Volume Group for Oracle.
Primary Oracle VLDB configuration for Data Guard
Details
In this demonstration, we have setup a primary Oracle database called NTAP on the primary Azure DB server with six NFS mount points: /u01 for the Oracle binary, /u02, /u04, /u05, /u06 for the Oracle data files, and an Oracle control file, /u03 for the Oracle active logs, archived log files, and a redundant Oracle control file. This setup serves as a reference configuration. Your actual deployment should take into consideration of your specific needs and requirements in terms of the capacity pool sizing, the service level, the number of database volumes and the sizing of each volume.
For detailed step by step procedures for setting up Oracle Data Guard on NFS with ASM, please refer to TR-5002- Oracle Active Data Guard Cost Reduction with Azure NetApp Files and TR-4974- Oracle 19c in Standalone Restart on AWS FSx/EC2 with NFS/ASM relevant sections. Although the procedures in TR-4974 were validated on Amazon FSx ONTAP, they are equally applicable to ANF. Following illustrates the details of a primary Oracle VLDB in a Data Guard configuration.
The primary database NTAP on the primary Azure DB server orap.internal.cloudapp.net is initially deployed as a standalone database with the ANF on NFS and ASM as database storage.
orap.internal.cloudapp.net: resource group: ANFAVSRG Location: East US size: Standard B4ms (4 vcpus, 16 GiB memory) OS: Linux (redhat 8.6) pub_ip: 172.190.207.231 pri_ip: 10.0.0.4 [oracle@orap ~]$ df -h Filesystem Size Used Avail Use% Mounted on devtmpfs 7.7G 0 7.7G 0% /dev tmpfs 7.8G 1.1G 6.7G 15% /dev/shm tmpfs 7.8G 17M 7.7G 1% /run tmpfs 7.8G 0 7.8G 0% /sys/fs/cgroup /dev/mapper/rootvg-rootlv 22G 20G 2.1G 91% / /dev/mapper/rootvg-usrlv 10G 2.3G 7.8G 23% /usr /dev/sda1 496M 181M 315M 37% /boot /dev/mapper/rootvg-varlv 8.0G 1.1G 7.0G 13% /var /dev/sda15 495M 5.8M 489M 2% /boot/efi /dev/mapper/rootvg-homelv 2.0G 47M 2.0G 3% /home /dev/mapper/rootvg-tmplv 12G 11G 1.9G 85% /tmp /dev/sdb1 32G 49M 30G 1% /mnt 10.0.2.38:/orap-u06 300G 282G 19G 94% /u06 10.0.2.38:/orap-u04 300G 282G 19G 94% /u04 10.0.2.36:/orap-u01 400G 21G 380G 6% /u01 10.0.2.37:/orap-u02 300G 282G 19G 94% /u02 10.0.2.36:/orap-u03 400G 282G 119G 71% /u03 10.0.2.39:/orap-u05 300G 282G 19G 94% /u05 [oracle@orap ~]$ cat /etc/oratab # # This file is used by ORACLE utilities. It is created by root.sh # and updated by either Database Configuration Assistant while creating # a database or ASM Configuration Assistant while creating ASM instance. # A colon, ':', is used as the field terminator. A new line terminates # the entry. Lines beginning with a pound sign, '#', are comments. # # Entries are of the form: # $ORACLE_SID:$ORACLE_HOME:<N|Y>: # # The first and second fields are the system identifier and home # directory of the database respectively. The third field indicates # to the dbstart utility that the database should , "Y", or should not, # "N", be brought up at system boot time. # # Multiple entries with the same $ORACLE_SID are not allowed. # # +ASM:/u01/app/oracle/product/19.0.0/grid:N NTAP:/u01/app/oracle/product/19.0.0/NTAP:N
Login to primary DB server as the oracle user. Validate grid configuration.
$GRID_HOME/bin/crsctl stat res -t[oracle@orap ~]$ $GRID_HOME/bin/crsctl stat res -t -------------------------------------------------------------------------------- Name Target State Server State details -------------------------------------------------------------------------------- Local Resources -------------------------------------------------------------------------------- ora.DATA.dg ONLINE ONLINE orap STABLE ora.LISTENER.lsnr ONLINE ONLINE orap STABLE ora.LOGS.dg ONLINE ONLINE orap STABLE ora.asm ONLINE ONLINE orap Started,STABLE ora.ons OFFLINE OFFLINE orap STABLE -------------------------------------------------------------------------------- Cluster Resources -------------------------------------------------------------------------------- ora.cssd 1 ONLINE ONLINE orap STABLE ora.diskmon 1 OFFLINE OFFLINE STABLE ora.evmd 1 ONLINE ONLINE orap STABLE ora.ntap.db 1 OFFLINE OFFLINE Instance Shutdown,ST ABLE -------------------------------------------------------------------------------- [oracle@orap ~]$ -
ASM disk group configuration.
asmcmd[oracle@orap ~]$ asmcmd ASMCMD> lsdg State Type Rebal Sector Logical_Sector Block AU Total_MB Free_MB Req_mir_free_MB Usable_file_MB Offline_disks Voting_files Name MOUNTED EXTERN N 512 512 4096 4194304 1146880 1136944 0 1136944 0 N DATA/ MOUNTED EXTERN N 512 512 4096 4194304 286720 283312 0 283312 0 N LOGS/ ASMCMD> lsdsk Path /u02/oradata/asm/orap_data_disk_01 /u02/oradata/asm/orap_data_disk_02 /u02/oradata/asm/orap_data_disk_03 /u02/oradata/asm/orap_data_disk_04 /u03/oralogs/asm/orap_logs_disk_01 /u03/oralogs/asm/orap_logs_disk_02 /u03/oralogs/asm/orap_logs_disk_03 /u03/oralogs/asm/orap_logs_disk_04 /u04/oradata/asm/orap_data_disk_05 /u04/oradata/asm/orap_data_disk_06 /u04/oradata/asm/orap_data_disk_07 /u04/oradata/asm/orap_data_disk_08 /u05/oradata/asm/orap_data_disk_09 /u05/oradata/asm/orap_data_disk_10 /u05/oradata/asm/orap_data_disk_11 /u05/oradata/asm/orap_data_disk_12 /u06/oradata/asm/orap_data_disk_13 /u06/oradata/asm/orap_data_disk_14 /u06/oradata/asm/orap_data_disk_15 /u06/oradata/asm/orap_data_disk_16 ASMCMD>
Parameters setting for Data Guard on primary DB.
SQL> show parameter name NAME TYPE VALUE ------------------------------------ ----------- ------------------------------ cdb_cluster_name string cell_offloadgroup_name string db_file_name_convert string db_name string NTAP db_unique_name string NTAP_NY global_names boolean FALSE instance_name string NTAP lock_name_space string log_file_name_convert string pdb_file_name_convert string processor_group_name string NAME TYPE VALUE ------------------------------------ ----------- ------------------------------ service_names string NTAP_NY.internal.cloudapp.net SQL> sho parameter log_archive_dest NAME TYPE VALUE ------------------------------------ ----------- ------------------------------ log_archive_dest string log_archive_dest_1 string LOCATION=USE_DB_RECOVERY_FILE_ DEST VALID_FOR=(ALL_LOGFILES,A LL_ROLES) DB_UNIQUE_NAME=NTAP_ NY log_archive_dest_10 string log_archive_dest_11 string log_archive_dest_12 string log_archive_dest_13 string log_archive_dest_14 string log_archive_dest_15 string NAME TYPE VALUE ------------------------------------ ----------- ------------------------------ log_archive_dest_16 string log_archive_dest_17 string log_archive_dest_18 string log_archive_dest_19 string log_archive_dest_2 string SERVICE=NTAP_LA ASYNC VALID_FO R=(ONLINE_LOGFILES,PRIMARY_ROL E) DB_UNIQUE_NAME=NTAP_LA log_archive_dest_20 string log_archive_dest_21 string log_archive_dest_22 string -
Primary DB configuration.
SQL> select name, open_mode, log_mode from v$database; NAME OPEN_MODE LOG_MODE --------- -------------------- ------------ NTAP READ WRITE ARCHIVELOG SQL> show pdbs CON_ID CON_NAME OPEN MODE RESTRICTED ---------- ------------------------------ ---------- ---------- 2 PDB$SEED READ ONLY NO 3 NTAP_PDB1 READ WRITE NO 4 NTAP_PDB2 READ WRITE NO 5 NTAP_PDB3 READ WRITE NO SQL> select name from v$datafile; NAME -------------------------------------------------------------------------------- +DATA/NTAP/DATAFILE/system.257.1189724205 +DATA/NTAP/DATAFILE/sysaux.258.1189724249 +DATA/NTAP/DATAFILE/undotbs1.259.1189724275 +DATA/NTAP/86B637B62FE07A65E053F706E80A27CA/DATAFILE/system.266.1189725235 +DATA/NTAP/86B637B62FE07A65E053F706E80A27CA/DATAFILE/sysaux.267.1189725235 +DATA/NTAP/DATAFILE/users.260.1189724275 +DATA/NTAP/86B637B62FE07A65E053F706E80A27CA/DATAFILE/undotbs1.268.1189725235 +DATA/NTAP/2B1302C26E089A59E0630400000A4D5C/DATAFILE/system.272.1189726217 +DATA/NTAP/2B1302C26E089A59E0630400000A4D5C/DATAFILE/sysaux.273.1189726217 +DATA/NTAP/2B1302C26E089A59E0630400000A4D5C/DATAFILE/undotbs1.271.1189726217 +DATA/NTAP/2B1302C26E089A59E0630400000A4D5C/DATAFILE/users.275.1189726243 NAME -------------------------------------------------------------------------------- +DATA/NTAP/2B13047FB98B9AAFE0630400000AFA5F/DATAFILE/system.277.1189726245 +DATA/NTAP/2B13047FB98B9AAFE0630400000AFA5F/DATAFILE/sysaux.278.1189726245 +DATA/NTAP/2B13047FB98B9AAFE0630400000AFA5F/DATAFILE/undotbs1.276.1189726245 +DATA/NTAP/2B13047FB98B9AAFE0630400000AFA5F/DATAFILE/users.280.1189726269 +DATA/NTAP/2B13061057039B10E0630400000AA001/DATAFILE/system.282.1189726271 +DATA/NTAP/2B13061057039B10E0630400000AA001/DATAFILE/sysaux.283.1189726271 +DATA/NTAP/2B13061057039B10E0630400000AA001/DATAFILE/undotbs1.281.1189726271 +DATA/NTAP/2B13061057039B10E0630400000AA001/DATAFILE/users.285.1189726293 19 rows selected. SQL> select member from v$logfile; MEMBER -------------------------------------------------------------------------------- +DATA/NTAP/ONLINELOG/group_3.264.1189724351 +LOGS/NTAP/ONLINELOG/group_3.259.1189724361 +DATA/NTAP/ONLINELOG/group_2.263.1189724351 +LOGS/NTAP/ONLINELOG/group_2.257.1189724359 +DATA/NTAP/ONLINELOG/group_1.262.1189724351 +LOGS/NTAP/ONLINELOG/group_1.258.1189724359 +DATA/NTAP/ONLINELOG/group_4.286.1190297279 +LOGS/NTAP/ONLINELOG/group_4.262.1190297283 +DATA/NTAP/ONLINELOG/group_5.287.1190297293 +LOGS/NTAP/ONLINELOG/group_5.263.1190297295 +DATA/NTAP/ONLINELOG/group_6.288.1190297307 MEMBER -------------------------------------------------------------------------------- +LOGS/NTAP/ONLINELOG/group_6.264.1190297309 +DATA/NTAP/ONLINELOG/group_7.289.1190297325 +LOGS/NTAP/ONLINELOG/group_7.265.1190297327 14 rows selected. SQL> select name from v$controlfile; NAME -------------------------------------------------------------------------------- +DATA/NTAP/CONTROLFILE/current.261.1189724347 +LOGS/NTAP/CONTROLFILE/current.256.1189724347 -
dNFS configuration on primary DB.
SQL> select svrname, dirname from v$dnfs_servers; SVRNAME -------------------------------------------------------------------------------- DIRNAME -------------------------------------------------------------------------------- 10.0.2.39 /orap-u05 10.0.2.38 /orap-u04 10.0.2.38 /orap-u06 SVRNAME -------------------------------------------------------------------------------- DIRNAME -------------------------------------------------------------------------------- 10.0.2.37 /orap-u02 10.0.2.36 /orap-u03 10.0.2.36 /orap-u01 6 rows selected.
This completes the demonstration of a Data Guard setup for VLDB NTAP at the primary site on ANF with NFS/ASM.
Standby Oracle VLDB configuration for Data Guard
Details
Oracle Data Guard requires OS kernel configuration and Oracle software stacks including patch sets on standby DB server to match with primary DB server. For easy management and simplicity, the database storage configuration of the standby DB server ideally should match with the primary DB server as well, such as the database directory layout and sizes of NFS mount points.
Again, for detailed step by step procedures for setting up Oracle Data Guard standby on NFS with ASM, please refer to TR-5002 - Oracle Active Data Guard Cost Reduction with Azure NetApp Files and TR-4974 - Oracle 19c in Standalone Restart on AWS FSx/EC2 with NFS/ASM relevant sections. Following illustrates the detail of standby Oracle VLDB configuration on standby DB server in a Data Guard setting.
The standby Oracle DB server configuration at standby site in the demo lab.
oras.internal.cloudapp.net: resource group: ANFAVSRG Location: West US 2 size: Standard B4ms (4 vcpus, 16 GiB memory) OS: Linux (redhat 8.6) pub_ip: 172.179.119.75 pri_ip: 10.0.1.4 [oracle@oras ~]$ df -h Filesystem Size Used Avail Use% Mounted on devtmpfs 7.7G 0 7.7G 0% /dev tmpfs 7.8G 1.1G 6.7G 15% /dev/shm tmpfs 7.8G 25M 7.7G 1% /run tmpfs 7.8G 0 7.8G 0% /sys/fs/cgroup /dev/mapper/rootvg-rootlv 22G 17G 5.6G 75% / /dev/mapper/rootvg-usrlv 10G 2.3G 7.8G 23% /usr /dev/mapper/rootvg-varlv 8.0G 1.1G 7.0G 13% /var /dev/mapper/rootvg-homelv 2.0G 52M 2.0G 3% /home /dev/sda1 496M 181M 315M 37% /boot /dev/sda15 495M 5.8M 489M 2% /boot/efi /dev/mapper/rootvg-tmplv 12G 11G 1.8G 86% /tmp /dev/sdb1 32G 49M 30G 1% /mnt 10.0.3.36:/oras-u03 400G 282G 119G 71% /u03 10.0.3.36:/oras-u04 300G 282G 19G 94% /u04 10.0.3.36:/oras-u05 300G 282G 19G 94% /u05 10.0.3.36:/oras-u02 300G 282G 19G 94% /u02 10.0.3.36:/oras-u01 100G 21G 80G 21% /u01 10.0.3.36:/oras-u06 300G 282G 19G 94% /u06 [oracle@oras ~]$ cat /etc/oratab #Backup file is /u01/app/oracle/crsdata/oras/output/oratab.bak.oras.oracle line added by Agent # # This file is used by ORACLE utilities. It is created by root.sh # and updated by either Database Configuration Assistant while creating # a database or ASM Configuration Assistant while creating ASM instance. # A colon, ':', is used as the field terminator. A new line terminates # the entry. Lines beginning with a pound sign, '#', are comments. # # Entries are of the form: # $ORACLE_SID:$ORACLE_HOME:<N|Y>: # # The first and second fields are the system identifier and home # directory of the database respectively. The third field indicates # to the dbstart utility that the database should , "Y", or should not, # "N", be brought up at system boot time. # # Multiple entries with the same $ORACLE_SID are not allowed. # # +ASM:/u01/app/oracle/product/19.0.0/grid:N NTAP:/u01/app/oracle/product/19.0.0/NTAP:N # line added by Agent
Grid infrastructure configuration on standby DB server.
[oracle@oras ~]$ $GRID_HOME/bin/crsctl stat res -t -------------------------------------------------------------------------------- Name Target State Server State details -------------------------------------------------------------------------------- Local Resources -------------------------------------------------------------------------------- ora.DATA.dg ONLINE ONLINE oras STABLE ora.LISTENER.lsnr ONLINE ONLINE oras STABLE ora.LOGS.dg ONLINE ONLINE oras STABLE ora.asm ONLINE ONLINE oras Started,STABLE ora.ons OFFLINE OFFLINE oras STABLE -------------------------------------------------------------------------------- Cluster Resources -------------------------------------------------------------------------------- ora.cssd 1 ONLINE ONLINE oras STABLE ora.diskmon 1 OFFLINE OFFLINE STABLE ora.evmd 1 ONLINE ONLINE oras STABLE ora.ntap_la.db 1 ONLINE INTERMEDIATE oras Dismounted,Mount Ini tiated,HOME=/u01/app /oracle/product/19.0 .0/NTAP,STABLE -------------------------------------------------------------------------------- -
ASM disk groups configuration on standby DB server.
[oracle@oras ~]$ asmcmd ASMCMD> lsdg State Type Rebal Sector Logical_Sector Block AU Total_MB Free_MB Req_mir_free_MB Usable_file_MB Offline_disks Voting_files Name MOUNTED EXTERN N 512 512 4096 4194304 1146880 1136912 0 1136912 0 N DATA/ MOUNTED EXTERN N 512 512 4096 4194304 286720 284228 0 284228 0 N LOGS/ ASMCMD> lsdsk Path /u02/oradata/asm/oras_data_disk_01 /u02/oradata/asm/oras_data_disk_02 /u02/oradata/asm/oras_data_disk_03 /u02/oradata/asm/oras_data_disk_04 /u03/oralogs/asm/oras_logs_disk_01 /u03/oralogs/asm/oras_logs_disk_02 /u03/oralogs/asm/oras_logs_disk_03 /u03/oralogs/asm/oras_logs_disk_04 /u04/oradata/asm/oras_data_disk_05 /u04/oradata/asm/oras_data_disk_06 /u04/oradata/asm/oras_data_disk_07 /u04/oradata/asm/oras_data_disk_08 /u05/oradata/asm/oras_data_disk_09 /u05/oradata/asm/oras_data_disk_10 /u05/oradata/asm/oras_data_disk_11 /u05/oradata/asm/oras_data_disk_12 /u06/oradata/asm/oras_data_disk_13 /u06/oradata/asm/oras_data_disk_14 /u06/oradata/asm/oras_data_disk_15 /u06/oradata/asm/oras_data_disk_16
Parameters setting for Data Guard on standby DB.
SQL> show parameter name NAME TYPE VALUE ------------------------------------ ----------- ------------------------------ cdb_cluster_name string cell_offloadgroup_name string db_file_name_convert string db_name string NTAP db_unique_name string NTAP_LA global_names boolean FALSE instance_name string NTAP lock_name_space string log_file_name_convert string pdb_file_name_convert string processor_group_name string NAME TYPE VALUE ------------------------------------ ----------- ------------------------------ service_names string NTAP_LA.internal.cloudapp.net SQL> show parameter log_archive_config NAME TYPE VALUE ------------------------------------ ----------- ------------------------------ log_archive_config string DG_CONFIG=(NTAP_NY,NTAP_LA) SQL> show parameter fal_server NAME TYPE VALUE ------------------------------------ ----------- ------------------------------ fal_server string NTAP_NY
Standby DB configuration.
SQL> select name, open_mode, log_mode from v$database; NAME OPEN_MODE LOG_MODE --------- -------------------- ------------ NTAP MOUNTED ARCHIVELOG SQL> show pdbs CON_ID CON_NAME OPEN MODE RESTRICTED ---------- ------------------------------ ---------- ---------- 2 PDB$SEED MOUNTED 3 NTAP_PDB1 MOUNTED 4 NTAP_PDB2 MOUNTED 5 NTAP_PDB3 MOUNTED SQL> select name from v$datafile; NAME -------------------------------------------------------------------------------- +DATA/NTAP_LA/DATAFILE/system.261.1190301867 +DATA/NTAP_LA/DATAFILE/sysaux.262.1190301923 +DATA/NTAP_LA/DATAFILE/undotbs1.263.1190301969 +DATA/NTAP_LA/2B12C97618069248E0630400000AC50B/DATAFILE/system.264.1190301987 +DATA/NTAP_LA/2B12C97618069248E0630400000AC50B/DATAFILE/sysaux.265.1190302013 +DATA/NTAP_LA/DATAFILE/users.266.1190302039 +DATA/NTAP_LA/2B12C97618069248E0630400000AC50B/DATAFILE/undotbs1.267.1190302045 +DATA/NTAP_LA/2B1302C26E089A59E0630400000A4D5C/DATAFILE/system.268.1190302071 +DATA/NTAP_LA/2B1302C26E089A59E0630400000A4D5C/DATAFILE/sysaux.269.1190302099 +DATA/NTAP_LA/2B1302C26E089A59E0630400000A4D5C/DATAFILE/undotbs1.270.1190302125 +DATA/NTAP_LA/2B1302C26E089A59E0630400000A4D5C/DATAFILE/users.271.1190302133 NAME -------------------------------------------------------------------------------- +DATA/NTAP_LA/2B13047FB98B9AAFE0630400000AFA5F/DATAFILE/system.272.1190302137 +DATA/NTAP_LA/2B13047FB98B9AAFE0630400000AFA5F/DATAFILE/sysaux.273.1190302163 +DATA/NTAP_LA/2B13047FB98B9AAFE0630400000AFA5F/DATAFILE/undotbs1.274.1190302189 +DATA/NTAP_LA/2B13047FB98B9AAFE0630400000AFA5F/DATAFILE/users.275.1190302197 +DATA/NTAP_LA/2B13061057039B10E0630400000AA001/DATAFILE/system.276.1190302201 +DATA/NTAP_LA/2B13061057039B10E0630400000AA001/DATAFILE/sysaux.277.1190302229 +DATA/NTAP_LA/2B13061057039B10E0630400000AA001/DATAFILE/undotbs1.278.1190302255 +DATA/NTAP_LA/2B13061057039B10E0630400000AA001/DATAFILE/users.279.1190302263 19 rows selected. SQL> select name from v$controlfile; NAME -------------------------------------------------------------------------------- +DATA/NTAP_LA/CONTROLFILE/current.260.1190301831 +LOGS/NTAP_LA/CONTROLFILE/current.257.1190301833 SQL> select group#, type, member from v$logfile order by 2, 1; GROUP# TYPE MEMBER ---------- ------- -------------------------------------------------------------------------------- 1 ONLINE +DATA/NTAP_LA/ONLINELOG/group_1.280.1190302305 1 ONLINE +LOGS/NTAP_LA/ONLINELOG/group_1.259.1190302309 2 ONLINE +DATA/NTAP_LA/ONLINELOG/group_2.281.1190302315 2 ONLINE +LOGS/NTAP_LA/ONLINELOG/group_2.258.1190302319 3 ONLINE +DATA/NTAP_LA/ONLINELOG/group_3.282.1190302325 3 ONLINE +LOGS/NTAP_LA/ONLINELOG/group_3.260.1190302329 4 STANDBY +DATA/NTAP_LA/ONLINELOG/group_4.283.1190302337 4 STANDBY +LOGS/NTAP_LA/ONLINELOG/group_4.261.1190302339 5 STANDBY +DATA/NTAP_LA/ONLINELOG/group_5.284.1190302347 5 STANDBY +LOGS/NTAP_LA/ONLINELOG/group_5.262.1190302349 6 STANDBY +DATA/NTAP_LA/ONLINELOG/group_6.285.1190302357 GROUP# TYPE MEMBER ---------- ------- -------------------------------------------------------------------------------- 6 STANDBY +LOGS/NTAP_LA/ONLINELOG/group_6.263.1190302359 7 STANDBY +DATA/NTAP_LA/ONLINELOG/group_7.286.1190302367 7 STANDBY +LOGS/NTAP_LA/ONLINELOG/group_7.264.1190302369 14 rows selected. -
Validate the standby database recovery status. Notice the
recovery logmergerinAPPLYING_LOGaction.SQL> SELECT ROLE, THREAD#, SEQUENCE#, ACTION FROM V$DATAGUARD_PROCESS; ROLE THREAD# SEQUENCE# ACTION ------------------------ ---------- ---------- ------------ recovery logmerger 1 32 APPLYING_LOG recovery apply slave 0 0 IDLE RFS async 1 32 IDLE recovery apply slave 0 0 IDLE recovery apply slave 0 0 IDLE RFS ping 1 32 IDLE archive redo 0 0 IDLE managed recovery 0 0 IDLE archive redo 0 0 IDLE archive redo 0 0 IDLE recovery apply slave 0 0 IDLE ROLE THREAD# SEQUENCE# ACTION ------------------------ ---------- ---------- ------------ redo transport monitor 0 0 IDLE log writer 0 0 IDLE archive local 0 0 IDLE redo transport timer 0 0 IDLE gap manager 0 0 IDLE RFS archive 0 0 IDLE 17 rows selected.
dNFS configuration on standby DB.
SQL> select svrname, dirname from v$dnfs_servers; SVRNAME -------------------------------------------------------------------------------- DIRNAME -------------------------------------------------------------------------------- 10.0.3.36 /oras-u05 10.0.3.36 /oras-u04 10.0.3.36 /oras-u02 10.0.3.36 /oras-u06 10.0.3.36 /oras-u03
This completes the demonstration of a Data Guard setup for VLDB NTAP with managed standby recovery enabled at standby site.
Setup Data Guard Broker
Details
Oracle Data Guard broker is a distributed management framework that automates and centralizes the creation, maintenance, and monitoring of Oracle Data Guard configurations. Following section demonstrate how to setup Data Guard Broker to manage Data Guard environment.
Start data guard broker on both the primary and the standby databases with following command via sqlplus.
alter system set dg_broker_start=true scope=both; -
From primary database, connect to Data Guard Borker as SYSDBA.
[oracle@orap ~]$ dgmgrl sys@NTAP_NY DGMGRL for Linux: Release 19.0.0.0.0 - Production on Wed Dec 11 20:53:20 2024 Version 19.18.0.0.0 Copyright (c) 1982, 2019, Oracle and/or its affiliates. All rights reserved. Welcome to DGMGRL, type "help" for information. Password: Connected to "NTAP_NY" Connected as SYSDBA. DGMGRL>
Create and enable Data Guard Broker configuration.
DGMGRL> create configuration dg_config as primary database is NTAP_NY connect identifier is NTAP_NY; Configuration "dg_config" created with primary database "ntap_ny" DGMGRL> add database NTAP_LA as connect identifier is NTAP_LA; Database "ntap_la" added DGMGRL> enable configuration; Enabled. DGMGRL> show configuration; Configuration - dg_config Protection Mode: MaxPerformance Members: ntap_ny - Primary database ntap_la - Physical standby database Fast-Start Failover: Disabled Configuration Status: SUCCESS (status updated 3 seconds ago) -
Validate the database status within the Data Guard Broker management framework.
DGMGRL> show database db1_ny; Database - db1_ny Role: PRIMARY Intended State: TRANSPORT-ON Instance(s): db1 Database Status: SUCCESS DGMGRL> show database db1_la; Database - db1_la Role: PHYSICAL STANDBY Intended State: APPLY-ON Transport Lag: 0 seconds (computed 1 second ago) Apply Lag: 0 seconds (computed 1 second ago) Average Apply Rate: 2.00 KByte/s Real Time Query: OFF Instance(s): db1 Database Status: SUCCESS DGMGRL>
In the event of a failure, Data Guard Broker can be used to failover the primary database to the standby instantaniouly. If Fast-Start Failover is enabled, Data Guard Broker can failover the primary database to the standby when a failure is detected without an user intervention.
Clone standby database for other use cases via automation
Details
Following automation toolkit is specifically designed to create or refresh clones of an Oracle Data Guard standby DB deployed to ANF with NFS/ASM configuration for a complete clone lifecycle management.
git clone https://bitbucket.ngage.netapp.com/scm/ns-bb/na_oracle_clone_anf.git
The toolkit can only be accessed by NetApp internal user with bitbucket access at this moment. For interested external users, please request access from your account team or reach out to NetApp Solutions Engineering team. |
Where to find additional information
To learn more about the information described in this document, review the following documents and/or websites:
TR-5002: Oracle Active Data Guard Cost Reduction with Azure NetApp Files
TR-4974: Oracle 19c in Standalone Restart on AWS FSx/EC2 with NFS/ASM
Azure NetApp Files
Oracle Data Guard Concepts and Administration
