NetApp database solutions
TR-5006: High Throughput Oracle VLDB Implementation on Google Cloud NetApp Volumes with Data Guard
Contributors netapp-revathid kevin-hoke
The solution provides an overview and details for configuring high throughput Oracle Very Large Database (VLDB) on Google Cloud NetApp Volumes (GCNV) with Oracle Data Guard in Google cloud.
Purpose
High throughput and mission-critical Oracle VLDB put a heavy demand on backend database storage. To meet service level agreement (SLA), the database storage must deliver the required capacity and high input/output operations per second (IOPS) while maintaining sub milliseconds latency performance. This is particularly challenging when deploying such a database workload in the public cloud with a shared storage resources environment. Not all storage platforms are created equal. GCNV is a premium storage service offered by Google that can support mission-critical Oracle Database deployments in Google cloud requiring sustained IOPS and low-latency performance characteristics. The architecture accommodates OLTP and OLAP workloads, with configurable service tiers supporting various performance profiles. GCNV delivers blazing-fast performance with sub milliseconds latency, achieving up to 4.5 GiBps per volume throughput with mixed read/write workloads.
Leveraging the fast snapshot backup (seconds) and clone (minutes) feature of GCNV, full-size copies of the production database can be cloned from Physical Standby on the fly to serve many other use cases such as DEV, UAT, etc. You can do away with an Active Data Guard license and inefficient and complex Snapshot Standby. The cost savings can be substantial. For a nominal Oracle Data Guard setup with 64 cores CPUs on both primary and standby Oracle servers, just the Active Data Guard licensing cost saving amounts to $1,472,000 based on the latest Oracle price list.
In this documentation, we demonstrate how to set up an Oracle VLDB with Data Guard configuration on GCNVS storage with multiple NFS volumes and Oracle ASM for storage load balancing. The standby database volumes can be quickly backed up via snapshot and cloned for read/write access. NetApp Solutions Engineering team provides an automation toolkit to create and refresh clones with streamlined lifecycle management.
This solution addresses the following use cases:
  • Implementation of Oracle VLDB in a Data Guard setting on GCNV storage service across Google cloud regions.
  • Snapshot backup and clone the physical standby database to serve use cases such as reporting, dev, test, etc. via automation.
Audience
This solution is intended for the following people:
  • A DBA who sets up Oracle VLDB with Data Guard in Google cloud for high availability, data protection, and disaster recovery.
  • A database solution architect interested in Oracle VLDB with Data Guard configuration in the Google cloud.
  • A storage administrator who manages GCNV storage that supports Oracle database.
  • An application owner who likes to stand up Oracle VLDB with Data Guard in a Google cloud environment.
Solution test and validation environment
The testing and validation of this solution was performed in a Google cloud lab setting that might not match the actual user deployment environment. For more information, see the section Key factors for deployment consideration.
Architecture
This image provides a detailed picture of the Oracle Data Guard implementation in Google cloud on GCNV.
Hardware and software components
Hardware
Current service offered by Google
Two Storage Pools, Premium Service Level, Auto QoS
Google Compute Engine VMs for DB Servers
N1 (4 vcpus, 15 GiB memory)
Four DB VMs, primary DB server, standby DB server, clone DB server, and Data Guard observer.
Software
RedHat Linux
Red Hat Enterprise Linux 8.10 (Ootpa) - x86/64
RHEL Marketplace image, PAYG
Oracle Grid Infrastructure
Version 19.18
Applied RU patch p34762026_190000_Linux-x86-64.zip
Oracle Database
Version 19.18
Applied RU patch p34765931_190000_Linux-x86-64.zip
dNFS OneOff Patch
p32931941_190000_Linux-x86-64.zip
Applied to both grid and database
Oracle OPatch
Version 12.2.0.1.36
Latest patch p6880880_190000_Linux-x86-64.zip
Ansible
Version core 2.16.2
python version - 3.10.13
NFS
Version 3.0
dNFS enabled for Oracle
Oracle VLDB Data Guard configuration with a simulated NY to LA DR setup
Database
DB_UNIQUE_NAME
Oracle Net Service Name
Primary
NTAP_NY
NTAP_NY.cvs-pm-host-1p.internal
Standby
NTAP_LA
NTAP_LA.cvs-pm-host-1p.internal
  • Google Cloud NetApp Volumes Configuration. GCNV are allocated in the Google cloud as Storage Pools. In these tests and validations, we deployed an 2 TiB storage pool to host Oracle primary database at the East4 region and a 4 TiB storage pool to host standby database and DB clone at the West4 region. GCNV storage pool has four service levels: Flex, Standard, Premium, and Extreme. The IO capacity of ANF capacity pool is based on the size of the capacity pool and its service level. At a capacity pool creation, you set storage pool location, service level, availability zone, and capacity of storage pool. For Oracle Data Guard configuration, Zonal availability should be sufficient as the Data Guard provides the database failover protection due to a zone level failure.
  • Sizing the Database Volumes. For production deployment, NetApp recommends taking a full assessment of your Oracle database throughput requirement from Oracle AWR report. Take into consideration the database size, the throughput requirements, and service level when designing GCNV volumes layout for VLDB database. It is recommended to use only Premium or Extreme service for Oracle database. The bandwidth is guaranteed at 64 MiB/s per TiB volume capacity up to maximum of 4.5 GiBps for Premium service and 128 MiB/s per TiB volume capacity up to 4.5 GiBps for Extreme service. Higher throughput will need larger volume sizing to meet the requirement.
  • Multiple Volumes and Load Balancing. A single large volume can provide similar performance level as multiple volumes with same aggregate volume size as the QoS is strictly enforced based on the volume sizing and storage pool service level. It is recommended to implement multiple volumes (multiple NFS mount points) for Oracle VLDB to better utilize shared backend GCNV storage resource pool and to meet throughput requirement exceeding 4.5 GiBps. Implement Oracle ASM for IO load balancing on multiple NFS volumes.
  • Google Compute Engine VM Instance Consideration. In these tests and validations, we used Compute Engine VM - N1 with 4 vCPUs and 15 GiB memory. You need to choose the Compute Engine DB VM instance appropriately for Oracle VLDB with high throughput requirement. Besides the number of vCPUs and the amount of RAM, the VM network bandwidth (ingress and egress or NIC throughput limit) can become a bottleneck before database storage throughput is reached.
  • dNFS Configuration. By using dNFS, an Oracle database running on a Google Compute Engine VM with GCNV storage can drive significantly more I/O than the native NFS client. Ensure that Oracle dNFS patch p32931941 is applied to address potential bugs.
Solution deployment
The following section demonstrates the configuration for Oracle VLDB on GCNV in an Oracle Data Guard setting between a primary Oracle DB in Google cloud of East region with GCNV storage to a physical standby Oracle DB in Google cloud of West region with GCNV storage.
Prerequisites for deployment
Details
Deployment requires the following prerequisites.
  1. A Google cloud account has been set up and a project has been created within your Google account to deploy resources for setting up Oracle Data Guard.
  2. Create a VPC and subnets that span the regions that are desired for Data Guard. For a resilient DR setup, consider to place the primary and standby DBs in different geographic locations that can tolerate major diaster in a local region.
  3. From the Google cloud portal console, deploy four Google compute engine Linux VM instances, one as the primary Oracle DB server, one as the standby Oracle DB server, a clone target DB server, and an Oracle Data Guard observer. See the architecture diagram in the previous section for more details about the environment setup. Follow Google documentation Create a Linux VM instance in Compute Engine for detailed instructions.
    Note Ensure that you have allocated at least 50G in the Azure VMs root volume in order to have sufficient space to stage Oracle installation files. Google compute engine VMs are locked down at instance level by default. To enable communication between VMs, a specific firewall rules should be created to open the TCP port traffic flow such as typical Oracle port 1521.
  4. From the Google cloud portal console, deploy two GCNV storage pools to host Oracle database volumes. Referred to documentation Create a storage pool quickstart for step-by-step instructions. Following are some screen shots for quick reference.
    Screenshot showing GCNV environment configuration.
  5. Create database volumes in storage pools. Referred to documentation Create a volume quickstart for step-by-step instructions. Following are some screen shots for quick reference.
  6. The primary Oracle database should have been installed and configured in the primary Oracle DB server. On the other hand, in the standby Oracle DB server or the clone Oracle DB server, only Oracle software is installed and no Oracle databases are created. Ideally, the Oracle files directories layout should be exactly matching on all Oracle DB servers. Refer to TR-4974 for help on Oracle grid infrastructure and database installation and configuration with NFS/ASM. Although the solution is validated on AWS FSx/EC2 environment, it can be equally applied to Google GCNV/Compute Engine environment.
Primary Oracle VLDB configuration for Data Guard
Details
In this demonstration, we have setup a primary Oracle database called NTAP on the primary DB server with eight NFS mount points: /u01 for the Oracle binary, /u02, /u03, /u04, /u05, /u06, /u07 for the Oracle data files, and load balanced with Oracle ASM disk group +DATA; /u08 for the Oracle active logs, archived log files, and load balanced with Oracle ASM disk group +LOGS. Oracle control files are placed on both +DATA and +LOGS disk groups for redundancy. This setup serves as a reference configuration. Your actual deployment should take into consideration of your specific needs and requirements in terms of the storage pool sizing, the service level, the number of database volumes and the sizing of each volume.
For detailed step by step procedures for setting up Oracle Data Guard on NFS with ASM, please referred to TR-5002 - Oracle Active Data Guard Cost Reduction with Azure NetApp Files. Although the procedures in TR-5002 were validated on Azure ANF environment, they are equally applicable to Google GCNV environment.
Following illustrates the details of a primary Oracle VLDB in a Data Guard configuration in Google GCNV environment.
  1. The primary database NTAP in the primary compute engine DB server is deployed as a single instance database in a standalone Restart configuration on the GCNV storage with NFS protocol and ASM as database storage volume manager.
    orap.us-east4-a.c.cvs-pm-host-1p.internal:
    Zone: us-east-4a
    size: n1-standard-4 (4 vCPUs, 15 GB Memory)
    OS: Linux (redhat 8.10)
    pub_ip: 35.212.124.14
    pri_ip: 10.70.11.5
    [oracle@orap ~]$ df -h
    Filesystem                Size  Used Avail Use% Mounted on
    devtmpfs                  7.2G     0  7.2G   0% /dev
    tmpfs                     7.3G     0  7.3G   0% /dev/shm
    tmpfs                     7.3G  8.5M  7.2G   1% /run
    tmpfs                     7.3G     0  7.3G   0% /sys/fs/cgroup
    /dev/sda2                  50G   40G   11G  80% /
    /dev/sda1                 200M  5.9M  194M   3% /boot/efi
    10.165.128.180:/orap-u05  250G  201G   50G  81% /u05
    10.165.128.180:/orap-u08  400G  322G   79G  81% /u08
    10.165.128.180:/orap-u04  250G  201G   50G  81% /u04
    10.165.128.180:/orap-u07  250G  201G   50G  81% /u07
    10.165.128.180:/orap-u02  250G  201G   50G  81% /u02
    10.165.128.180:/orap-u06  250G  201G   50G  81% /u06
    10.165.128.180:/orap-u01  100G   21G   80G  21% /u01
    10.165.128.180:/orap-u03  250G  201G   50G  81% /u03
    [oracle@orap ~]$ cat /etc/oratab
    # This file is used by ORACLE utilities.  It is created by root.sh
    # and updated by either Database Configuration Assistant while creating
    # a database or ASM Configuration Assistant while creating ASM instance.
    # A colon, ':', is used as the field terminator.  A new line terminates
    # the entry.  Lines beginning with a pound sign, '#', are comments.
    # Entries are of the form:
    #   $ORACLE_SID:$ORACLE_HOME:<N|Y>:
    # The first and second fields are the system identifier and home
    # directory of the database respectively.  The third field indicates
    # to the dbstart utility that the database should , "Y", or should not,
    # "N", be brought up at system boot time.
    # Multiple entries with the same $ORACLE_SID are not allowed.
    +ASM:/u01/app/oracle/product/19.0.0/grid:N
    NTAP:/u01/app/oracle/product/19.0.0/NTAP:N
  2. Login to primary DB server as the oracle user. Validate grid configuration.
    $GRID_HOME/bin/crsctl stat res -t
    [oracle@orap ~]$ $GRID_HOME/bin/crsctl stat res -t
    Name           Target  State        Server                   State details
    Local Resources
    ora.DATA.dg
                   ONLINE  ONLINE       orap                     STABLE
    ora.LISTENER.lsnr
    ora.LOGS.dg
    ora.asm
                   ONLINE  ONLINE       orap                     Started,STABLE
    ora.ons
                   OFFLINE OFFLINE      orap                     STABLE
    Cluster Resources
    ora.cssd
          1        ONLINE  ONLINE       orap                     STABLE
    ora.diskmon
          1        OFFLINE OFFLINE                               STABLE
    ora.evmd
    ora.ntap.db
          1        ONLINE  ONLINE       orap                     Open,HOME=/u01/app/o
        /NTAP,STABLE
    [oracle@orap ~]$
  3. ASM disk group configuration.
    asmcmd
    [oracle@orap ~]$ asmcmd
    ASMCMD> lsdg
    State    Type    Rebal  Sector  Logical_Sector  Block       AU  Total_MB  Free_MB  Req_mir_free_MB  Usable_file_MB  Offline_disks  Voting_files  Name
    MOUNTED  EXTERN  N         512             512   4096  4194304   1228800  1219888                0         1219888              0             N  DATA/
    MOUNTED  EXTERN  N         512             512   4096  4194304    327680   326556                0          326556              0             N  LOGS/
    ASMCMD> lsdsk
    Path
    /u02/oradata/asm/orap_data_disk_01
    /u02/oradata/asm/orap_data_disk_02
    /u02/oradata/asm/orap_data_disk_03
    /u02/oradata/asm/orap_data_disk_04
    /u03/oradata/asm/orap_data_disk_05
    /u03/oradata/asm/orap_data_disk_06
    /u03/oradata/asm/orap_data_disk_07
    /u03/oradata/asm/orap_data_disk_08
    /u04/oradata/asm/orap_data_disk_09
    /u04/oradata/asm/orap_data_disk_10
    /u04/oradata/asm/orap_data_disk_11
    /u04/oradata/asm/orap_data_disk_12
    /u05/oradata/asm/orap_data_disk_13
    /u05/oradata/asm/orap_data_disk_14
    /u05/oradata/asm/orap_data_disk_15
    /u05/oradata/asm/orap_data_disk_16
    /u06/oradata/asm/orap_data_disk_17
    /u06/oradata/asm/orap_data_disk_18
    /u06/oradata/asm/orap_data_disk_19
    /u06/oradata/asm/orap_data_disk_20
    /u07/oradata/asm/orap_data_disk_21
    /u07/oradata/asm/orap_data_disk_22
    /u07/oradata/asm/orap_data_disk_23
    /u07/oradata/asm/orap_data_disk_24
    /u08/oralogs/asm/orap_logs_disk_01
    /u08/oralogs/asm/orap_logs_disk_02
    /u08/oralogs/asm/orap_logs_disk_03
    /u08/oralogs/asm/orap_logs_disk_04
    ASMCMD>
  4. Parameters setting for Data Guard on primary DB.
    SQL> show parameter name
    NAME                                 TYPE        VALUE
    cdb_cluster_name                     string
    cell_offloadgroup_name               string
    db_file_name_convert                 string
    db_name                              string      ntap
    db_unique_name                       string      ntap_ny
    global_names                         boolean     FALSE
    instance_name                        string      NTAP
    lock_name_space                      string
    log_file_name_convert                string
    pdb_file_name_convert                string
    processor_group_name                 string
    NAME                                 TYPE        VALUE
    service_names                        string      ntap_ny.cvs-pm-host-1p.interna
    SQL> sho parameter log_archive_dest
    NAME                                 TYPE        VALUE
    log_archive_dest                     string
    log_archive_dest_1                   string      LOCATION=USE_DB_RECOVERY_FILE_
                                                     DEST VALID_FOR=(ALL_LOGFILES,A
                                                     LL_ROLES) DB_UNIQUE_NAME=NTAP_
                                                     NY
    log_archive_dest_10                  string
    log_archive_dest_11                  string
    log_archive_dest_12                  string
    log_archive_dest_13                  string
    log_archive_dest_14                  string
    log_archive_dest_15                  string
    NAME                                 TYPE        VALUE
    log_archive_dest_16                  string
    log_archive_dest_17                  string
    log_archive_dest_18                  string
    log_archive_dest_19                  string
    log_archive_dest_2                   string      SERVICE=NTAP_LA ASYNC VALID_FO
                                                     R=(ONLINE_LOGFILES,PRIMARY_ROL
                                                     E) DB_UNIQUE_NAME=NTAP_LA
    log_archive_dest_20                  string
    log_archive_dest_21                  string
    log_archive_dest_22                  string
  5. Primary DB configuration.
    SQL> select name, open_mode, log_mode from v$database;
    NAME      OPEN_MODE            LOG_MODE
    NTAP      READ WRITE           ARCHIVELOG
    SQL> show pdbs
        CON_ID CON_NAME                       OPEN MODE  RESTRICTED
             2 PDB$SEED                       READ ONLY  NO
             3 NTAP_PDB1                      READ WRITE NO
             4 NTAP_PDB2                      READ WRITE NO
             5 NTAP_PDB3                      READ WRITE NO
    SQL> select name from v$datafile;
    NAME
    +DATA/NTAP/DATAFILE/system.257.1198026005
    +DATA/NTAP/DATAFILE/sysaux.258.1198026051
    +DATA/NTAP/DATAFILE/undotbs1.259.1198026075
    +DATA/NTAP/86B637B62FE07A65E053F706E80A27CA/DATAFILE/system.266.1198027075
    +DATA/NTAP/86B637B62FE07A65E053F706E80A27CA/DATAFILE/sysaux.267.1198027075
    +DATA/NTAP/DATAFILE/users.260.1198026077
    +DATA/NTAP/86B637B62FE07A65E053F706E80A27CA/DATAFILE/undotbs1.268.1198027075
    +DATA/NTAP/32639B76C9BC91A8E063050B460A2116/DATAFILE/system.272.1198028157
    +DATA/NTAP/32639B76C9BC91A8E063050B460A2116/DATAFILE/sysaux.273.1198028157
    +DATA/NTAP/32639B76C9BC91A8E063050B460A2116/DATAFILE/undotbs1.271.1198028157
    +DATA/NTAP/32639B76C9BC91A8E063050B460A2116/DATAFILE/users.275.1198028185
    NAME
    +DATA/NTAP/32639D40D02D925FE063050B460A60E3/DATAFILE/system.277.1198028187
    +DATA/NTAP/32639D40D02D925FE063050B460A60E3/DATAFILE/sysaux.278.1198028187
    +DATA/NTAP/32639D40D02D925FE063050B460A60E3/DATAFILE/undotbs1.276.1198028187
    +DATA/NTAP/32639D40D02D925FE063050B460A60E3/DATAFILE/users.280.1198028209
    +DATA/NTAP/32639E973AF79299E063050B460AFBAD/DATAFILE/system.282.1198028209
    +DATA/NTAP/32639E973AF79299E063050B460AFBAD/DATAFILE/sysaux.283.1198028209
    +DATA/NTAP/32639E973AF79299E063050B460AFBAD/DATAFILE/undotbs1.281.1198028209
    +DATA/NTAP/32639E973AF79299E063050B460AFBAD/DATAFILE/users.285.1198028229
    19 rows selected.
    SQL> select member from v$logfile;
    MEMBER
    +DATA/NTAP/ONLINELOG/group_3.264.1198026139
    +LOGS/NTAP/ONLINELOG/group_3.259.1198026147
    +DATA/NTAP/ONLINELOG/group_2.263.1198026137
    +LOGS/NTAP/ONLINELOG/group_2.258.1198026145
    +DATA/NTAP/ONLINELOG/group_1.262.1198026137
    +LOGS/NTAP/ONLINELOG/group_1.257.1198026145
    +DATA/NTAP/ONLINELOG/group_4.286.1198511423
    +LOGS/NTAP/ONLINELOG/group_4.265.1198511425
    +DATA/NTAP/ONLINELOG/group_5.287.1198511445
    +LOGS/NTAP/ONLINELOG/group_5.266.1198511447
    +DATA/NTAP/ONLINELOG/group_6.288.1198511459
    MEMBER
    +LOGS/NTAP/ONLINELOG/group_6.267.1198511461
    +DATA/NTAP/ONLINELOG/group_7.289.1198511477
    +LOGS/NTAP/ONLINELOG/group_7.268.1198511479
    14 rows selected.
    SQL> select name from v$controlfile;
    NAME
    +DATA/NTAP/CONTROLFILE/current.261.1198026135
    +LOGS/NTAP/CONTROLFILE/current.256.1198026135
  6. Oracle listener configuration.
    lsnrctl status listener
    [oracle@orap admin]$ lsnrctl status
    LSNRCTL for Linux: Version 19.0.0.0.0 - Production on 15-APR-2025 16:14:00
    Copyright (c) 1991, 2022, Oracle.  All rights reserved.
    Connecting to (ADDRESS=(PROTOCOL=tcp)(HOST=)(PORT=1521))
    STATUS of the LISTENER
    Alias                     LISTENER
    Version                   TNSLSNR for Linux: Version 19.0.0.0.0 - Production
    Start Date                14-APR-2025 19:44:21
    Uptime                    0 days 20 hr. 29 min. 38 sec
    Trace Level               off
    Security                  ON: Local OS Authentication
    SNMP                      OFF
    Listener Parameter File   /u01/app/oracle/product/19.0.0/grid/network/admin/listener.ora
    Listener Log File         /u01/app/oracle/diag/tnslsnr/orap/listener/alert/log.xml
    Listening Endpoints Summary...
      (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=orap.us-east4-a.c.cvs-pm-host-1p.internal)(PORT=1521)))
      (DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(KEY=EXTPROC1521)))
    Services Summary...
    Service "+ASM" has 1 instance(s).
      Instance "+ASM", status READY, has 1 handler(s) for this service...
    Service "+ASM_DATA" has 1 instance(s).
    Service "+ASM_LOGS" has 1 instance(s).
    Service "32639b76c9bc91a8e063050b460a2116.cvs-pm-host-1p.internal" has 1 instance(s).
      Instance "NTAP", status READY, has 1 handler(s) for this service...
    Service "32639d40d02d925fe063050b460a60e3.cvs-pm-host-1p.internal" has 1 instance(s).
    Service "32639e973af79299e063050b460afbad.cvs-pm-host-1p.internal" has 1 instance(s).
    Service "86b637b62fdf7a65e053f706e80a27ca.cvs-pm-host-1p.internal" has 1 instance(s).
    Service "NTAPXDB.cvs-pm-host-1p.internal" has 1 instance(s).
    Service "NTAP_NY_DGMGRL.cvs-pm-host-1p.internal" has 1 instance(s).
      Instance "NTAP", status UNKNOWN, has 1 handler(s) for this service...
    Service "ntap.cvs-pm-host-1p.internal" has 1 instance(s).
    Service "ntap_pdb1.cvs-pm-host-1p.internal" has 1 instance(s).
    Service "ntap_pdb2.cvs-pm-host-1p.internal" has 1 instance(s).
    Service "ntap_pdb3.cvs-pm-host-1p.internal" has 1 instance(s).
    The command completed successfully
  7. Flashback is enabled at primary database.
    SQL> select name, database_role, flashback_on from v$database;
    NAME      DATABASE_ROLE    FLASHBACK_ON
    NTAP      PRIMARY          YES
  8. dNFS configuration on primary DB.
    SQL> select svrname, dirname from v$dnfs_servers;
    SVRNAME
    DIRNAME
    10.165.128.180
    /orap-u04
    10.165.128.180
    /orap-u05
    10.165.128.180
    /orap-u07
    SVRNAME
    DIRNAME
    10.165.128.180
    /orap-u03
    10.165.128.180
    /orap-u06
    10.165.128.180
    /orap-u02
    SVRNAME
    DIRNAME
    10.165.128.180
    /orap-u08
    10.165.128.180
    /orap-u01
    8 rows selected.
This completes the demonstration of a Data Guard setup for VLDB NTAP at the primary site on GCNV with NFS/ASM.
Standby Oracle VLDB configuration for Data Guard
Details
Oracle Data Guard requires OS kernel configuration and Oracle software stacks including patch sets on standby DB server to match with primary DB server. For easy management and simplicity, the database storage configuration of the standby DB server ideally should match with the primary DB server as well, such as the database directory layout and sizes of NFS mount points.
Again, for detailed step by step procedures for setting up Oracle Data Guard standby on NFS with ASM, please refer to TR-5002 - Oracle Active Data Guard Cost Reduction with Azure NetApp Files and TR-4974 - Oracle 19c in Standalone Restart on AWS FSx/EC2 with NFS/ASM relevant sections. Following illustrates the detail of standby Oracle VLDB configuration on standby DB server in a Data Guard setting in Google GCNV environment.
  1. The standby Oracle DB server configuration at standby site in the demo lab.
    oras.us-west4-a.c.cvs-pm-host-1p.internal:
    Zone: us-west4-a
    pub_ip: 35.219.129.195
    pri_ip: 10.70.14.16
    [oracle@oras ~]$ df -h
    tmpfs                     7.3G  1.1G  6.2G  16% /dev/shm
    10.165.128.197:/oras-u07  250G  201G   50G  81% /u07
    10.165.128.197:/oras-u06  250G  201G   50G  81% /u06
    10.165.128.197:/oras-u02  250G  201G   50G  81% /u02
    10.165.128.196:/oras-u03  250G  201G   50G  81% /u03
    10.165.128.196:/oras-u01  100G   20G   81G  20% /u01
    10.165.128.197:/oras-u05  250G  201G   50G  81% /u05
    10.165.128.197:/oras-u04  250G  201G   50G  81% /u04
    10.165.128.197:/oras-u08  400G  317G   84G  80% /u08
    [oracle@oras ~]$ cat /etc/oratab
    #Backup file is  /u01/app/oracle/crsdata/oras/output/oratab.bak.oras.oracle line added by Agent
    NTAP:/u01/app/oracle/product/19.0.0/NTAP:N              # line added by Agent
  2. Grid infrastructure configuration on standby DB server.
    [oracle@oras ~]$ $GRID_HOME/bin/crsctl stat res -t
    Local Resources
    ora.DATA.dg
                   ONLINE  ONLINE       oras                     STABLE
    ora.LISTENER.lsnr
    ora.LOGS.dg
    ora.asm
                   ONLINE  ONLINE       oras                     Started,STABLE
    ora.ons
                   OFFLINE OFFLINE      oras                     STABLE
    Cluster Resources
    ora.cssd
          1        ONLINE  ONLINE       oras                     STABLE
    ora.diskmon
    ora.evmd
    ora.ntap_la.db
          1        ONLINE  INTERMEDIATE oras                     Dismounted,Mount Ini
        tiated,HOME=/u01/app
        .0/NTAP,STABLE
  3. ASM disk groups configuration on standby DB server.
    [oracle@oras ~]$ asmcmd
    ASMCMD> lsdg
    MOUNTED  EXTERN  N         512             512   4096  4194304   1228800  1228420                0         1228420              0             N  DATA/
    MOUNTED  EXTERN  N         512             512   4096  4194304    322336   322204                0          322204              0             N  LOGS/
    ASMCMD> lsdsk
    Path
    /u02/oradata/asm/oras_data_disk_01
    /u02/oradata/asm/oras_data_disk_02
    /u02/oradata/asm/oras_data_disk_03
    /u02/oradata/asm/oras_data_disk_04
    /u03/oradata/asm/oras_data_disk_05
    /u03/oradata/asm/oras_data_disk_06
    /u03/oradata/asm/oras_data_disk_07
    /u03/oradata/asm/oras_data_disk_08
    /u04/oradata/asm/oras_data_disk_09
    /u04/oradata/asm/oras_data_disk_10
    /u04/oradata/asm/oras_data_disk_11
    /u04/oradata/asm/oras_data_disk_12
    /u05/oradata/asm/oras_data_disk_13
    /u05/oradata/asm/oras_data_disk_14
    /u05/oradata/asm/oras_data_disk_15
    /u05/oradata/asm/oras_data_disk_16
    /u06/oradata/asm/oras_data_disk_17
    /u06/oradata/asm/oras_data_disk_18
    /u06/oradata/asm/oras_data_disk_19
    /u06/oradata/asm/oras_data_disk_20
    /u07/oradata/asm/oras_data_disk_21
    /u07/oradata/asm/oras_data_disk_22
    /u07/oradata/asm/oras_data_disk_23
    /u07/oradata/asm/oras_data_disk_24
    /u08/oralogs/asm/oras_logs_disk_01
    /u08/oralogs/asm/oras_logs_disk_02
    /u08/oralogs/asm/oras_logs_disk_03
    /u08/oralogs/asm/oras_logs_disk_04
    ASMCMD>
  4. Parameters setting for Data Guard on standby DB.
    NAME                                 TYPE        VALUE
    db_name                              string      NTAP
    db_unique_name                       string      NTAP_LA
    NAME                                 TYPE        VALUE
    service_names                        string      NTAP_LA.cvs-pm-host-1p.interna
                                                     l
    SQL> show parameter log_archive_config
    NAME                                 TYPE        VALUE
    log_archive_config                   string      DG_CONFIG=(NTAP_NY,NTAP_LA)
    SQL> show parameter fal_server
    NAME                                 TYPE        VALUE
    fal_server                           string      NTAP_NY
  5. Standby DB configuration.
    NTAP      MOUNTED              ARCHIVELOG
    SQL> show pdbs
             2 PDB$SEED                       MOUNTED
             3 NTAP_PDB1                      MOUNTED
             4 NTAP_PDB2                      MOUNTED
             5 NTAP_PDB3                      MOUNTED
    NAME
    +DATA/NTAP_LA/DATAFILE/system.261.1198520347
    +DATA/NTAP_LA/DATAFILE/sysaux.262.1198520373
    +DATA/NTAP_LA/DATAFILE/undotbs1.263.1198520399
    +DATA/NTAP_LA/32635CC1DCF58A60E063050B460AB746/DATAFILE/system.264.1198520417
    +DATA/NTAP_LA/32635CC1DCF58A60E063050B460AB746/DATAFILE/sysaux.265.1198520435
    +DATA/NTAP_LA/DATAFILE/users.266.1198520451
    +DATA/NTAP_LA/32635CC1DCF58A60E063050B460AB746/DATAFILE/undotbs1.267.1198520455
    +DATA/NTAP_LA/32639B76C9BC91A8E063050B460A2116/DATAFILE/system.268.1198520471
    +DATA/NTAP_LA/32639B76C9BC91A8E063050B460A2116/DATAFILE/sysaux.269.1198520489
    +DATA/NTAP_LA/32639B76C9BC91A8E063050B460A2116/DATAFILE/undotbs1.270.1198520505
    +DATA/NTAP_LA/32639B76C9BC91A8E063050B460A2116/DATAFILE/users.271.1198520513
    NAME
    +DATA/NTAP_LA/32639D40D02D925FE063050B460A60E3/DATAFILE/system.272.1198520517
    +DATA/NTAP_LA/32639D40D02D925FE063050B460A60E3/DATAFILE/sysaux.273.1198520533
    +DATA/NTAP_LA/32639D40D02D925FE063050B460A60E3/DATAFILE/undotbs1.274.1198520551
    +DATA/NTAP_LA/32639D40D02D925FE063050B460A60E3/DATAFILE/users.275.1198520559
    +DATA/NTAP_LA/32639E973AF79299E063050B460AFBAD/DATAFILE/system.276.1198520563
    +DATA/NTAP_LA/32639E973AF79299E063050B460AFBAD/DATAFILE/sysaux.277.1198520579
    +DATA/NTAP_LA/32639E973AF79299E063050B460AFBAD/DATAFILE/undotbs1.278.1198520595
    +DATA/NTAP_LA/32639E973AF79299E063050B460AFBAD/DATAFILE/users.279.1198520605
    19 rows selected.
    NAME
    +DATA/NTAP_LA/CONTROLFILE/current.260.1198520303
    +LOGS/NTAP_LA/CONTROLFILE/current.257.1198520305
    SQL> select group#, type, member from v$logfile order by 2, 1;
        GROUP# TYPE    MEMBER
             1 ONLINE  +DATA/NTAP_LA/ONLINELOG/group_1.280.1198520649
             1 ONLINE  +LOGS/NTAP_LA/ONLINELOG/group_1.259.1198520651
             2 ONLINE  +DATA/NTAP_LA/ONLINELOG/group_2.281.1198520659
             2 ONLINE  +LOGS/NTAP_LA/ONLINELOG/group_2.258.1198520661
             3 ONLINE  +DATA/NTAP_LA/ONLINELOG/group_3.282.1198520669
             3 ONLINE  +LOGS/NTAP_LA/ONLINELOG/group_3.260.1198520671
             4 STANDBY +DATA/NTAP_LA/ONLINELOG/group_4.283.1198520677
             4 STANDBY +LOGS/NTAP_LA/ONLINELOG/group_4.261.1198520679
             5 STANDBY +DATA/NTAP_LA/ONLINELOG/group_5.284.1198520687
             5 STANDBY +LOGS/NTAP_LA/ONLINELOG/group_5.262.1198520689
             6 STANDBY +DATA/NTAP_LA/ONLINELOG/group_6.285.1198520697
        GROUP# TYPE    MEMBER
             6 STANDBY +LOGS/NTAP_LA/ONLINELOG/group_6.263.1198520699
             7 STANDBY +DATA/NTAP_LA/ONLINELOG/group_7.286.1198520707
             7 STANDBY +LOGS/NTAP_LA/ONLINELOG/group_7.264.1198520709
    14 rows selected.
  6. Validate the standby database recovery status. Notice the recovery logmerger in APPLYING_LOG action.
    SQL> SELECT ROLE, THREAD#, SEQUENCE#, ACTION FROM V$DATAGUARD_PROCESS;
    ROLE                        THREAD#  SEQUENCE# ACTION
    post role transition              0          0 IDLE
    recovery apply slave              0          0 IDLE
    recovery logmerger                1         24 APPLYING_LOG
    managed recovery                  0          0 IDLE
    RFS ping                          1         24 IDLE
    archive redo                      0          0 IDLE
    gap manager                       0          0 IDLE
    archive local                     0          0 IDLE
    redo transport timer              0          0 IDLE
    RFS async                         1         24 IDLE
    redo transport monitor            0          0 IDLE
    log writer                        0          0 IDLE
    17 rows selected.
  7. Flashback is enabled at standby database.
    NTAP      PHYSICAL STANDBY YES
  8. dNFS configuration on standby DB.
SVRNAME
DIRNAME
10.165.128.197
/oras-u04
10.165.128.197
/oras-u05
10.165.128.197
/oras-u06
10.165.128.197
/oras-u07
10.165.128.197
/oras-u02
10.165.128.197
/oras-u08
10.165.128.196
/oras-u03
10.165.128.196
/oras-u01
8 rows selected.
This completes the demonstration of a Data Guard setup for VLDB NTAP with managed standby recovery enabled at standby site.
Setup Data Guard Broker and FSFO with an Observer
Details
Oracle Data Guard broker is a distributed management framework that automates and centralizes the creation, maintenance, and monitoring of Oracle Data Guard configurations. Following section demonstrate how to setup Data Guard Broker to manage Data Guard environment.
  1. Start data guard broker on both the primary and the standby databases with following command via sqlplus.
    alter system set dg_broker_start=true scope=both;
  2. From primary database, connect to Data Guard Borker as SYSDBA.
    [oracle@orap ~]$ dgmgrl sys@NTAP_NY
    DGMGRL for Linux: Release 19.0.0.0.0 - Production on Wed Dec 11 20:53:20 2024
    Version 19.18.0.0.0
    Copyright (c) 1982, 2019, Oracle and/or its affiliates.  All rights reserved.
    Welcome to DGMGRL, type "help" for information.
    Password:
    Connected to "NTAP_NY"
    Connected as SYSDBA.
    DGMGRL>
  3. Create and enable Data Guard Broker configuration.
    DGMGRL> create configuration dg_config as primary database is NTAP_NY connect identifier is NTAP_NY;
    Configuration "dg_config" created with primary database "ntap_ny"
    DGMGRL> add database NTAP_LA as connect identifier is NTAP_LA;
    Database "ntap_la" added
    DGMGRL> enable configuration;
    Enabled.
    DGMGRL> show configuration;
    Configuration - dg_config
      Protection Mode: MaxPerformance
      Members:
      ntap_ny - Primary database
        ntap_la - Physical standby database
    Fast-Start Failover:  Disabled
    Configuration Status:
    SUCCESS   (status updated 3 seconds ago)
  4. Validate the database status within the Data Guard Broker management framework.
    DGMGRL> show database ntap_ny;
    Database - ntap_ny
      Role:               PRIMARY
      Intended State:     TRANSPORT-ON
      Instance(s):
        NTAP
    Database Status:
    SUCCESS
    DGMGRL> show database ntap_la;
    Database - ntap_la
      Role:               PHYSICAL STANDBY
      Intended State:     APPLY-ON
      Transport Lag:      0 seconds (computed 0 seconds ago)
      Apply Lag:          0 seconds (computed 0 seconds ago)
      Average Apply Rate: 3.00 KByte/s
      Real Time Query:    OFF
      Instance(s):
        NTAP
    Database Status:
    SUCCESS
    DGMGRL>
In the event of a failure, Data Guard Broker can be used to failover the primary database to the standby instantaniouly. If Fast-Start Failover is enabled, Data Guard Broker can failover the primary database to the standby when a failure is detected without an user intervention.
Configure FSFO with an Observer
Details
Optionally, Fast Start Fail Over (FSFO) can be enabled for Data Guard Broker to failover the primary database to standby database in the event of a failure automatically. Following are the procedures to setup FSFO with an observer instance.
  1. Create a lightweight Google compute engine instance to run Observer in a different zone than primary or standby DB server. In the test case, we used a N1 instance with 2 vCPU with 7.5G memory. Have same version of Oracle installed on the host.
  2. Login in as oracle user and set oracle environment in the oracle user .bash_profile.
    vi ~/.bash_profile
    # .bash_profile
    # Get the aliases and functions
    if [ -f ~/.bashrc ]; then
            . ~/.bashrc
    fi
    # User specific environment and startup programs
    export ORACLE_HOME=/u01/app/oracle/product/19.0.0/NTAP
    export PATH=$ORACLE_HOME/bin:$PATH
  3. Add primary and standby DB TNS name entries to tnsname.ora file.
    vi $ORACLE_HOME/network/admin/tsnames.ora
    NTAP_NY =
      (DESCRIPTION =
        (ADDRESS = (PROTOCOL = TCP)(HOST = orap.us-east4-a.c.cvs-pm-host-1p.internal)(PORT = 1521))
        (CONNECT_DATA =
          (SERVER = DEDICATED)
          (SERVICE_NAME = NTAP_NY.cvs-pm-host-1p.internal)
          (UR=A)
    NTAP_LA =
      (DESCRIPTION =
        (ADDRESS = (PROTOCOL = TCP)(HOST = oras.us-west4-a.c.cvs-pm-host-1p.internal)(PORT = 1521))
        (CONNECT_DATA =
          (SERVICE_NAME = NTAP_LA.cvs-pm-host-1p.internal)
          (UR=A)
  4. Create and initialize wallet with a password.
    mkdir -p /u01/app/oracle/admin/NTAP/wallet
    mkstore -wrl /u01/app/oracle/admin/NTAP/wallet -create
    [oracle@orao NTAP]$ mkdir -p /u01/app/oracle/admin/NTAP/wallet
    [oracle@orao NTAP]$ mkstore -wrl /u01/app/oracle/admin/NTAP/wallet -create
    Oracle Secret Store Tool Release 19.0.0.0.0 - Production
    Version 19.4.0.0.0
    Copyright (c) 2004, 2022, Oracle and/or its affiliates. All rights reserved.
    Enter password:
    Enter password again:
    [oracle@orao NTAP]$
  5. Enable passwordless authentication for user sys of both primary and standby database. Enter sys password first, then wallet password from previous step.
    mkstore -wrl /u01/app/oracle/admin/NTAP/wallet -createCredential NTAP_NY sys
    mkstore -wrl /u01/app/oracle/admin/NTAP/wallet -createCredential NTAP_LA sys
    [oracle@orao NTAP]$ mkstore -wrl /u01/app/oracle/admin/NTAP/wallet -createCredential NTAP_NY sys
    Version 19.4.0.0.0
    Your secret/Password is missing in the command line
    Enter your secret/Password:
    Re-enter your secret/Password:
    Enter wallet password:
    [oracle@orao NTAP]$ mkstore -wrl /u01/app/oracle/admin/NTAP/wallet -createCredential NTAP_LA sys
    Version 19.4.0.0.0
    [oracle@orao NTAP]$
  6. Update sqlnet.ora with wallet location.
    vi $ORACLE_HOME/network/admin/sqlnet.ora
    WALLET_LOCATION =
       (SOURCE =
          (METHOD = FILE)
          (METHOD_DATA = (DIRECTORY = /u01/app/oracle/admin/NTAP/wallet))
    SQLNET.WALLET_OVERRIDE = TRUE
  7. Validate the crentials.
    mkstore -wrl /u01/app/oracle/admin/NTAP/wallet -listCredential
    sqlplus /@NTAP_LA as sysdba
    sqlplus /@NTAP_NY as sysdba
    [oracle@orao NTAP]$ mkstore -wrl /u01/app/oracle/admin/NTAP/wallet -listCredential
    Version 19.4.0.0.0
    List credential (index: connect_string username)
    2: NTAP_LA sys
    1: NTAP_NY sys
  8. Configure and enable Fast-Start Failover.
    mkdir /u01/app/oracle/admin/NTAP/fsfo
    dgmgrl
    DGMGRL> connect /@NTAP_NY
    Connected to "ntap_ny"
      Protection Mode: MaxAvailability
      Members:
    SUCCESS   (status updated 58 seconds ago)
    DGMGRL> enable fast_start failover;
    Enabled in Zero Data Loss Mode.
      Members:
        Warning: ORA-16819: fast-start failover observer not started
        ntap_la - (*) Physical standby database
    Fast-Start Failover: Enabled in Zero Data Loss Mode
    WARNING   (status updated 43 seconds ago)
  9. Start and validate observer.
    nohup dgmgrl /@NTAP_NY "start observer file='/u01/app/oracle/admin/NTAP/fsfo/fsfo.dat'" >> /u01/app/oracle/admin/NTAP/fsfo/dgmgrl.log &
    [oracle@orao NTAP]$ nohup dgmgrl /@NTAP_NY "start observer file='/u01/app/oracle/admin/NTAP/fsfo/fsfo.dat'" >> /u01/app/oracle/admin/NTAP/fsfo/dgmgrl.log &
    [1] 94957
    [oracle@orao fsfo]$ dgmgrl
    DGMGRL for Linux: Release 19.0.0.0.0 - Production on Wed Apr 16 21:12:09 2025
    Version 19.18.0.0.0
    DGMGRL> show configuration verbose;
      Members:
      (*) Fast-Start Failover target
      Properties:
        FastStartFailoverThreshold      = '30'
        OperationTimeout                = '30'
        TraceLevel                      = 'USER'
        FastStartFailoverLagLimit       = '30'
        CommunicationTimeout            = '180'
        ObserverReconnect               = '0'
        FastStartFailoverAutoReinstate  = 'TRUE'
        FastStartFailoverPmyShutdown    = 'TRUE'
        BystandersFollowRoleChange      = 'ALL'
        ObserverOverride                = 'FALSE'
        ExternalDestination1            = ''
        ExternalDestination2            = ''
        PrimaryLostWriteAction          = 'CONTINUE'
        ConfigurationWideServiceName    = 'ntap_CFG'
      Lag Limit:          30 seconds (not in use)
      Threshold:          30 seconds
      Active Target:      ntap_la
      Potential Targets:  "ntap_la"
        ntap_la    valid
      Observer:           orao
      Shutdown Primary:   TRUE
      Auto-reinstate:     TRUE
      Observer Reconnect: (none)
      Observer Override:  FALSE
    SUCCESS
    DGMGRL>
Note To achieve zero data loss, Oracle Data Guard protection mode needs to be set to MaxAvailability or MaxProtection mode. The default protection mode of MaxPerformance can be changed from the Data Guard Broker interface by editing the Data Guard configuration and changing LogXptMode from ASYNC to SYNC. The Oracle archive log destination log mode needs to be changed accordingly. When real-time log application is enabled for Data Guard as required for MaxAvailability, avoid rebooting the database automatically because automatic database reboot may inaverdently open the standby database in READ ONLY WITH APPLY mode, which requires an Active Data Guard license. Instead, boot the database manually to ensure it remains in a MOUNT state with managed recovery in real time.
Clone standby database for other use cases via automation
Details
Following automation toolkit is specifically designed to create or refresh clones of an Oracle Data Guard standby DB deployed to GCNV with NFS/ASM configuration for a complete clone lifecycle management.
https://bitbucket.ngage.netapp.com/projects/NS-BB/repos/na_oracle_clone_gcnv/browse
Note The toolkit can only be accessed by NetApp internal user with bitbucket access at this moment. For interested external users, please request access from your account team or reach out to NetApp Solutions Engineering team. Refer to Automated Oracle Clone Lifecycle on GCNV with ASM for usage instructions.
Where to find additional information
To learn more about the information described in this document, review the following documents and/or websites:
