Adding additional data volume partitions
Starting with SAP HANA 2.0 SPS4, you can configure additional data volume partitions, which allows you to configure two or more volumes for the data volume of an SAP HANA tenant database. You can also scale beyond the size and performance limits of a single volume.
Using two or more individual volumes for the data volume is available for SAP HANA single-host and multiple-host systems. You can add additional data volume partitions at any time, but doing so might require a restart of the SAP HANA database. |
Enabling additional data volume partitions
To enable additional data volume partitions, add the following entry within
global.ini
using SAP HANA Studio or Cockpit in the SYSTEMDB configuration.
[customizable_functionalities] persistence_datavolume_partition_multipath = true
Adding the parameter manually to the global.ini file requires the restart of the database.
Volume configuration for a single-host SAP HANA system
The layout of volumes for a single-host SAP HANA system with multiple partitions is like the layout for a system with one data volume partition, but with an additional data volume stored on a different aggregate as the log volume and the other data volume. The following table shows an example configuration of an SAP HANA single-host system with two data volume partitions.
Aggregate 1 at Controller A | Aggregate 2 at Controller A | Aggregate 1 at Controller B | Aggregate 2 at Controller b |
Data volume: SID_data_mnt00001 |
Shared volume: SID_shared |
Data volume: SID_data2_mnt00001 |
Log volume: SID_log_mnt00001 |
The following table shows an example of the mount point configuration for a single-host system with two data volume partitions.
Junction path | Directory | Mount point at HANA host |
SID_data_mnt00001 |
/hana/data/SID/mnt00001 |
/hana/data2/SID/mnt00001 |
SID_log_mnt00001 |
/hana/log/SID/mnt00001 |
SID_shared |
usr-sap |
/usr/sap/SID |
Create the new data volume and mount it to the namespace using either ONTAP System Manager or the ONTAP cluster command line interface.
Volume configuration for multiple-host SAP HANA system
The layout of volumes for a multiple-host SAP HANA system with multiple partitions is like the layout for a system with one data volume partition, but with an additional data volume stored on a different aggregate as the log volume and the other data volume. The following table shows an example configuration of an SAP HANA multiple-host system with two data volume partitions.
Purpose | Aggregate 1 at Controller A | Aggregate 2 at Controller A | Aggregate 1 at Controller B | Aggregate 2 at Controller B |
Data and log volumes for node 1 |
Data2 volume: SID_data2_mnt00001 |
Data and log volumes for node 2 |
Log volume: SID_log_mnt00002 |
Data2 volume: SID_data2_mnt00002 |
Data volume: SID_data_mnt00002 |
Data and log volumes for node 3 |
Data volume: SID_data_mnt00003 |
Data2 volume: SID_data2_mnt00003 |
Log volume: SID_log_mnt00003 |
Data and log volumes for node 4 |
Data2 volume: SID_data2_mnt00004 |
Log volume: SID_log_mnt00004 |
Data volume: SID_data_mnt00004 |
Shared volume for all hosts |
Junction path | Directory | Mount point at SAP HANA host | Note |
SID_data_mnt00001 |
Mounted at all hosts |
SID_log_mnt00001 |
SID_data_mnt00002 |
/hana/data/SID/mnt00002 |
/hana/data2/SID/mnt00002 |
SID_log_mnt00002 |
/hana/log/SID/mnt00002 |
SID_data_mnt00003 |
/hana/data/SID/mnt00003 |
/hana/data2/SID/mnt00003 |
SID_log_mnt00003 |
/hana/log/SID/mnt00003 |
SID_data_mnt00004 |
/hana/data/SID/mnt00004 |
/hana/data2/SID/mnt00004 |
SID_log_mnt00004 |
/hana/log/SID/mnt00004 |
SID_shared |
shared |
/hana/shared/SID |
SID_shared |
usr-sap-host1 |
/usr/sap/SID |
Mounted at host 1 |
SID_shared |
usr-sap-host2 |
/usr/sap/SID |
Mounted at host 2 |
SID_shared |
usr-sap-host3 |
/usr/sap/SID |
Mounted at host 3 |
SID_shared |
usr-sap-host4 |
/usr/sap/SID |
Mounted at host 4 |
SID_shared |
usr-sap-host5 |
/usr/sap/SID |
Mounted at host 5 |
Host configuration
In addition to the tasks described in the section “Host setup,” you must create the additional mount points and fstab entries for the new additional data volume(s), and you must mount the new volumes.
Create additional mount points:
For a single-host system, create mount points and set the permissions on the database host.
sapcc-hana-tst-06:/ # mkdir -p /hana/data2/SID/mnt00001 sapcc-hana-tst-06:/ # chmod –R 777 /hana/data2/SID
For a multiple-host system, create mount points and set the permissions on all worker and standby hosts. The following example commands are for a 2+1 multiple-host HANA system.
First worker host:
sapcc-hana-tst-06:~ # mkdir -p /hana/data2/SID/mnt00001 sapcc-hana-tst-06:~ # mkdir -p /hana/data2/SID/mnt00002 sapcc-hana-tst-06:~ # chmod -R 777 /hana/data2/SID
Second worker host:
sapcc-hana-tst-07:~ # mkdir -p /hana/data2/SID/mnt00001 sapcc-hana-tst-07:~ # mkdir -p /hana/data2/SID/mnt00002 sapcc-hana-tst-07:~ # chmod -R 777 /hana/data2/SID
Standby host:
Add the additional file systems to the
/etc/fstab
configuration file on all hosts. An example for a single-host system using NFSv4.1 is as follows:<storage-vif-data02>:/SID_data2_mnt00001 /hana/data2/SID/mnt00001 nfs rw,vers=4, minorversion=1,hard,timeo=600,rsize=1048576,wsize=266144,bg,noatime,lock 0 0
Use a different storage virtual interface for connecting to each data volume to make sure that different TCP sessions are used for each volume. You can also use the nconnect mount option if it is available for your OS. -
To mount the file systems, run the
mount –a
command.
Adding an additional data volume partition
Execute the following SQL statement against the tenant database to add an additional data volume partition to your tenant database. Use the path to additional volume(s):
ALTER SYSTEM ALTER DATAVOLUME ADD PARTITION PATH '/hana/data2/SID/';
