Host setup
All the steps described in this section are valid for both SAP HANA environments on physical servers and for SAP HANA running on VMware vSphere.
Configuration parameter for SUSE Linux Enterprise Server
Additional kernel and configuration parameters at each SAP HANA host must be adjusted for the workload generated by SAP HANA.
SUSE Linux Enterprise Server 12 and 15
Starting with SUSE Linux Enterprise Server (SLES) 12 SP1, the kernel parameter must be set in a configuration file in the /etc/sysctl.d
directory. For example, a configuration file with the name 91-NetApp-HANA.conf
must be created.
net.core.rmem_max = 16777216 net.core.wmem_max = 16777216 net.ipv4.tcp_rmem = 4096 131072 16777216 net.ipv4.tcp_wmem = 4096 16384 16777216 net.core.netdev_max_backlog = 300000 net.ipv4.tcp_slow_start_after_idle = 0 net.ipv4.tcp_no_metrics_save = 1 net.ipv4.tcp_moderate_rcvbuf = 1 net.ipv4.tcp_window_scaling = 1 net.ipv4.tcp_timestamps = 1 net.ipv4.tcp_sack = 1 sunrpc.tcp_max_slot_table_entries = 128
Saptune, which is included in SLES for SAP OS versions, can be used to set these values. See SAP Note 3024346 (requires SAP login). |
Configuration parameter for Red Hat Enterprise Linux 7.2 or later
You must adjust additional kernel and configuration parameters at each SAP HANA host for the workload generated by SAP HANA.
Starting with Red Hat Enterprise Linux 7.2, you must set the kernel parameters in a configuration file in the /etc/sysctl.d
must be created.
Since RedHat Enterprise Linux version 8.6, these settings can also be applied by using RHEL System Roles for SAP (Ansible). See SAP Note 3024346 (requires SAP login). |
Create subdirectories in /hana/shared volume
The examples show an SAP HANA database with SID=NF2. |
To create the required subdirectories, take one of the following actions:
For a single-host system, mount the
/hana/shared
volume and create theshared
andusr-sap
subdirectories.
sapcc-hana-tst-06:/mnt # mount <storage-hostname>:/NF2_shared /mnt/tmp sapcc-hana-tst-06:/mnt # cd /mnt/tmp sapcc-hana-tst-06:/mnt/tmp # mkdir shared sapcc-hana-tst-06:/mnt/tmp # mkdir usr-sap sapcc-hana-tst-06:mnt/tmp # cd .. sapcc-hana-tst-06:/mnt # umount /mnt/tmp
For a multiple-host system, mount the
/hana/shared
and theusr-sap
subdirectories for each host.The example commands show a 2+1 multiple-host HANA system.
sapcc-hana-tst-06:/mnt # mount <storage-hostname>:/NF2_shared /mnt/tmp sapcc-hana-tst-06:/mnt # cd /mnt/tmp sapcc-hana-tst-06:/mnt/tmp # mkdir shared sapcc-hana-tst-06:/mnt/tmp # mkdir usr-sap-host1 sapcc-hana-tst-06:/mnt/tmp # mkdir usr-sap-host2 sapcc-hana-tst-06:/mnt/tmp # mkdir usr-sap-host3 sapcc-hana-tst-06:/mnt/tmp # cd .. sapcc-hana-tst-06:/mnt # umount /mnt/tmp
Create mount points
To create the required mount point directories, take one of the following actions:
For a single-host system, create mount points and set the permissions on the database host.
sapcc-hana-tst-06:/ # mkdir -p /hana/data/NF2/mnt00001 sapcc-hana-tst-06:/ # mkdir -p /hana/log/NF2/mnt00001 sapcc-hana-tst-06:/ # mkdir -p /hana/shared sapcc-hana-tst-06:/ # mkdir -p /usr/sap/NF2 sapcc-hana-tst-06:/ # chmod –R 777 /hana/log/NF2 sapcc-hana-tst-06:/ # chmod –R 777 /hana/data/NF2 sapcc-hana-tst-06:/ # chmod -R 777 /hana/shared sapcc-hana-tst-06:/ # chmod -R 777 /usr/sap/NF2
For a multiple-host system, create mount points and set the permissions on all worker and standby hosts.
The following example commands are for a 2+1 multiple-host HANA system.
First worker host:
sapcc-hana-tst-06:~ # mkdir -p /hana/data/NF2/mnt00001 sapcc-hana-tst-06:~ # mkdir -p /hana/data/NF2/mnt00002 sapcc-hana-tst-06:~ # mkdir -p /hana/log/NF2/mnt00001 sapcc-hana-tst-06:~ # mkdir -p /hana/log/NF2/mnt00002 sapcc-hana-tst-06:~ # mkdir -p /hana/shared sapcc-hana-tst-06:~ # mkdir -p /usr/sap/NF2 sapcc-hana-tst-06:~ # chmod -R 777 /hana/log/NF2 sapcc-hana-tst-06:~ # chmod -R 777 /hana/data/NF2 sapcc-hana-tst-06:~ # chmod -R 777 /hana/shared sapcc-hana-tst-06:~ # chmod -R 777 /usr/sap/NF2
Second worker host:
sapcc-hana-tst-07:~ # mkdir -p /hana/data/NF2/mnt00001 sapcc-hana-tst-07:~ # mkdir -p /hana/data/NF2/mnt00002 sapcc-hana-tst-07:~ # mkdir -p /hana/log/NF2/mnt00001 sapcc-hana-tst-07:~ # mkdir -p /hana/log/NF2/mnt00002 sapcc-hana-tst-07:~ # mkdir -p /hana/shared sapcc-hana-tst-07:~ # mkdir -p /usr/sap/NF2 sapcc-hana-tst-07:~ # chmod -R 777 /hana/log/NF2 sapcc-hana-tst-07:~ # chmod -R 777 /hana/data/NF2 sapcc-hana-tst-07:~ # chmod -R 777 /hana/shared sapcc-hana-tst-07:~ # chmod -R 777 /usr/sap/NF2
Standby host:
sapcc-hana-tst-08:~ # mkdir -p /hana/data/NF2/mnt00001 sapcc-hana-tst-08:~ # mkdir -p /hana/data/NF2/mnt00002 sapcc-hana-tst-08:~ # mkdir -p /hana/log/NF2/mnt00001 sapcc-hana-tst-08:~ # mkdir -p /hana/log/NF2/mnt00002 sapcc-hana-tst-08:~ # mkdir -p /hana/shared sapcc-hana-tst-08:~ # mkdir -p /usr/sap/NF2 sapcc-hana-tst-08:~ # chmod -R 777 /hana/log/NF2 sapcc-hana-tst-08:~ # chmod -R 777 /hana/data/NF2 sapcc-hana-tst-08:~ # chmod -R 777 /hana/shared sapcc-hana-tst-08:~ # chmod -R 777 /usr/sap/NF2
Mount file systems
Different mount options are used depending on the NFS version and ONTAP release. The following file systems must be mounted to the hosts:
/hana/data/SID/mnt0000*
/hana/log/SID/mnt0000*
/hana/shared
/usr/sap/SID
The following table shows the NFS versions that must be used for the different file systems for single-host and multiple-host SAP HANA databases.
File systems | SAP HANA single host | SAP HANA multiple hosts |
/hana/data/SID/mnt0000* |
NFSv3 or NFSv4 |
NFSv4 |
/hana/log/SID/mnt0000* |
NFSv3 or NFSv4 |
NFSv4 |
/hana/shared |
NFSv3 or NFSv4 |
NFSv3 or NFSv4 |
/usr/sap/SID |
NFSv3 or NFSv4 |
NFSv3 or NFSv4 |
The following table shows the mount options for the various NFS versions and ONTAP releases. The common parameters are independent of the NFS and ONTAP versions.
SAP LaMa requires the /usr/sap/SID directory to be local. Therefore, do not mount an NFS volume for /usr/sap/SID if you are using SAP LaMa. |
For NFSv3, you must switch off NFS locking to avoid NFS lock cleanup operations if there is a software or server failure.
With ONTAP 9, the NFS transfer size can be configured up to 1MB. Specifically, with 40GbE or faster connections to the storage system, you must set the transfer size to 1MB to achieve the expected throughput values.
Common parameter | NFSv3 | NFSv4 | NFS transfer size with ONTAP 9 | NFS transfer size with ONTAP 8 |
rw, bg, hard, timeo=600, noatime, |
nfsvers=3,nolock, |
nfsvers=4.1,lock |
rsize=1048576,wsize=262144, |
rsize=65536,wsize=65536, |
To improve read performance with NFSv3, NetApp recommends that you use the nconnect=n mount option, which is available with SUSE Linux Enterprise Server 12 SP4 or later and RedHat Enterprise Linux (RHEL) 8.3 or later.
Performance tests show that nconnect=4 provides good read results especially for the data volumes. Log writes might benefit from a lower number of sessions, such as nconnect=2 . Shared volumes might benefit as well from using the 'nconnect' option. Be aware that the first mount from an NFS server (IP address) defines the amount of sessions being used. Further mounts to the same IP address do not change this even if a different value is used for nconnect.
Starting with ONTAP 9.8 and SUSE SLES15SP2 or RedHat RHEL 8.4 or higher, NetApp supports the nconnect option also for NFSv4.1. |
If nconnect is being used with NFSV4.x the amount of NFSv4.x session slots should be adjusted according to the following rule: Amount of session slots equals <nconnect value> x 64. At the host this will be adjuseted by echo options nfs max_session_slots=<calculated value> > /etc/modprobe.d/nfsclient.conf followed by a reboot. The server side value must be adjusted as well, set the number of session slots as described in NFS configuration for NFSv4. |
To mount the file systems during system boot with the /etc/fstab
configuration file, complete the following steps:
The following example shows a single host SAP HANA database with SID=NF2 using NFSv3 and an NFS transfer size of 1MB for reads and 256k for writes.
Add the required file systems to the
/etc/fstab
configuration file.sapcc-hana-tst-06:/ # cat /etc/fstab <storage-vif-data01>:/NF2_data_mnt00001 /hana/data/NF2/mnt00001 nfs rw,nfsvers=3,hard,timeo=600,nconnect=4,rsize=1048576,wsize=262144,bg,noatime,nolock 0 0 <storage-vif-log01>:/NF2_log_mnt00001 /hana/log/NF2/mnt00001 nfs rw,nfsvers=3,hard,timeo=600,nconnect=2,rsize=1048576,wsize=262144,bg,noatime,nolock 0 0 <storage-vif-data01>:/NF2_shared/usr-sap /usr/sap/NF2 nfs rw,nfsvers=3,hard,timeo=600,nconnect=4,rsize=1048576,wsize=262144,bg,noatime,nolock 0 0 <storage-vif-data01>:/NF2_shared/shared /hana/shared nfs rw,nfsvers=3,hard,timeo=600,nconnect=4,rsize=1048576,wsize=262144,bg,noatime,nolock 0 0
Run
mount –a
to mount the file systems on all hosts.
The next example shows a multiple-host SAP HANA database with SID=NF2 using NFSv4.1 for data and log file systems and NFSv3 for the /hana/shared
and /usr/sap/NF2
file systems. An NFS transfer size of 1MB for reads and 256k for writes is used.
/etc/fstab
configuration file on all hosts.The /usr/sap/NF2
file system is different for each database host. The following example shows/NF2_shared/usr-sap-host1
.sapcc-hana-tst-06:/ # cat /etc/fstab <storage-vif-data01>:/NF2_data_mnt00001 /hana/data/NF2/mnt00001 nfs rw,nfsvers=4.1,hard,timeo=600,nconnect=4,rsize=1048576,wsize=262144,bg,noatime,lock 0 0 <storage-vif-data02>:/NF2_data_mnt00002 /hana/data/NF2/mnt00002 nfs rw,nfsvers=4.1,hard,timeo=600,nconnect=4,rsize=1048576,wsize=262144,bg,noatime,lock 0 0 <storage-vif-log01>:/NF2_log_mnt00001 /hana/log/NF2/mnt00001 nfs rw,nfsvers=4.1,hard,timeo=600,nconnect=2,rsize=1048576,wsize=262144,bg,noatime,lock 0 0 <storage-vif-log02>:/NF2_log_mnt00002 /hana/log/NF2/mnt00002 nfs rw,nfsvers=4.1,hard,timeo=600,nconnect=2,rsize=1048576,wsize=262144,bg,noatime,lock 0 0 <storage-vif-data02>:/NF2_shared/usr-sap-host1 /usr/sap/NF2 nfs rw,nfsvers=3,hard,timeo=600,nconnect=4,rsize=1048576,wsize=262144,bg,noatime,nolock 0 0 <storage-vif-data02>:/NF2_shared/shared /hana/shared nfs rw,nfsvers=3,hard,timeo=600,nconnect=4,rsize=1048576,wsize=262144,bg,noatime,nolock 0 0
Run
mount –a
