SAP HANA software installation
This section describes the preparation necessary to install SAP HANA on single-host and multiple-host systems.
Installation on single-host system
SAP HANA software installation does not require any additional preparation for a single-host system.
Installation on multiple-host system
Before beginning the installation, create a global.ini
file to enable use of the SAP storage connector during the installation process. The SAP storage connector mounts the required file systems at the worker hosts during the installation process. The global.ini
file must be available in a file system that is accessible from all hosts, such as the /hana/shared
file system.
Before installing SAP HANA software on a multiple-host system, the following steps must be completed:
Add the following mount options for the data LUNs and the log LUNs to the
global.ini
file:-
relatime
andinode64
for the data and log file system
Add the WWIDs of the data and log partitions. The WWIDs must match the alias names configured in the
/etc/multipath.conf
file.The following output shows an example of a 2+1 multiple-host setup in which the system identifier (SID) is SS3.
stlrx300s8-6:~ # cat /hana/shared/global.ini [communication] listeninterface = .global [persistence] basepath_datavolumes = /hana/data/SS3 basepath_logvolumes = /hana/log/SS3 [storage] ha_provider = hdb_ha.fcClient partition_*_*__prtype = 5 partition_*_data__mountoptions = -o relatime,inode64 partition_*_log__mountoptions = -o relatime,inode64,nobarrier partition_1_data__wwid = hana-SS3_data_mnt00001 partition_1_log__wwid = hana-SS3_log_mnt00001 partition_2_data__wwid = hana-SS3_data_mnt00002 partition_2_log__wwid = hana-SS3_log_mnt00002 [system_information] usage = custom [trace] ha_fcclient = info stlrx300s8-6:~ #
If the Linux LVM is used, the required configuration is different. The following example shows a 2+1 multiple-host setup with SID=FC5.
sapcc-hana-tst-03:/hana/shared # cat global.ini [communication] listeninterface = .global [persistence] basepath_datavolumes = /hana/data/FC5 basepath_logvolumes = /hana/log/FC5 [storage] ha_provider = hdb_ha.fcClientLVM partition_*_*__prtype = 5 partition_*_data__mountOptions = -o relatime,inode64 partition_*_log__mountOptions = -o relatime,inode64 partition_1_data__lvmname = FC5_data_mnt00001-vol partition_1_log__lvmname = FC5_log_mnt00001-vol partition_2_data__lvmname = FC5_data_mnt00002-vol partition_2_log__lvmname = FC5_log_mnt00002-vol sapcc-hana-tst-03:/hana/shared # Using the SAP hdblcm installation tool, start the installation by running the following command at one of the worker hosts. Use the `addhosts` option to add the second worker (sapcc-hana-tst-04) and the standby host (sapcc-hana-tst-05).
The directory where the prepared global.ini
file is stored is included with thestorage_cfg
CLI option (-- storage_cfg=/hana/shared
).Depending on the OS version being used, it might be necessary to install Python 2.7 before installing the SAP HANA database. sapcc-hana-tst-03:/mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/HDB_LCM_LINUX_X86_64 # ./hdblcm --action=install --addhosts=sapcc-hana-tst-04:role=worker:storage_partion=2,sapcc-hana-tst-05:role:=standby --storage_cfg=/hana(shared/shared SAP HANA Lifecycle Management - SAP HANA Database 2.00.052.00.1599235305 ************************************************************************ Scanning software locations... Detected components: SAP HANA AFL (incl.PAL,BFL,OFL) (2.00.052.0000.1599259237) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/HDB_AFL_LINUX_X86_64/packages SAP HANA Database (2.00.052.00.1599235305) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/HDB_SERVER_LINUX_X86_64/server SAP HANA Database Client (2.5.109.1598303414) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/HDB_CLIENT_LINUX_X86_64/client SAP HANA Smart Data Access (2.00.5.000.0) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/SAP_HANA_SDA_20_LINUX_X86_64/packages SAP HANA Studio (2.3.54.000000) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/HDB_STUDIO_LINUX_X86_64/studio SAP HANA Local Secure Store (2.4.24.0) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/HANA_LSS_24_LINUX_X86_64/packages SAP HANA XS Advanced Runtime (1.0.130.519) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/XSA_RT_10_LINUX_X86_64/packages SAP HANA EML AFL (2.00.052.0000.1599259237) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/HDB_EML_AFL_10_LINUX_X86_64/packages SAP HANA EPM-MDS (2.00.052.0000.1599259237) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/SAP_HANA_EPM-MDS_10/packages GUI for HALM for XSA (including product installer) Version 1 (1.014.1) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/XSA_CONTENT_10/XSACALMPIUI14_1.zip XSAC FILEPROCESSOR 1.0 (1.000.85) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/XSA_CONTENT_10/XSACFILEPROC00_85.zip SAP HANA tools for accessing catalog content, data preview, SQL console, etc. (2.012.20341) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/XSAC_HRTT_20/XSACHRTT12_20341.zip XS Messaging Service 1 (1.004.10) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/XSA_CONTENT_10/XSACMESSSRV04_10.zip Develop and run portal services for customer apps on XSA (1.005.1) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/XSA_CONTENT_10/XSACPORTALSERV05_1.zip SAP Web IDE Web Client (4.005.1) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/XSAC_SAP_WEB_IDE_20/XSACSAPWEBIDE05_1.zip XS JOB SCHEDULER 1.0 (1.007.12) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/XSA_CONTENT_10/XSACSERVICES07_12.zip SAPUI5 FESV6 XSA 1 - SAPUI5 1.71 (1.071.25) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/XSA_CONTENT_10/XSACUI5FESV671_25.zip SAPUI5 SERVICE BROKER XSA 1 - SAPUI5 Service Broker 1.0 (1.000.3) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/XSA_CONTENT_10/XSACUI5SB00_3.zip XSA Cockpit 1 (1.001.17) in /mnt/sapcc-share/software/SAP/HANA2SP5-52/DATA_UNITS/XSA_CONTENT_10/XSACXSACOCKPIT01_17.zip SAP HANA Database version '2.00.052.00.1599235305' will be installed. Select additional components for installation: Index | Components | Description --------------------------------------------------------------------------------------------- 1 | all | All components 2 | server | No additional components 3 | client | Install SAP HANA Database Client version 2.5.109.1598303414 4 | lss | Install SAP HANA Local Secure Store version 2.4.24.0 5 | studio | Install SAP HANA Studio version 2.3.54.000000 6 | smartda | Install SAP HANA Smart Data Access version 2.00.5.000.0 7 | xs | Install SAP HANA XS Advanced Runtime version 1.0.130.519 8 | afl | Install SAP HANA AFL (incl.PAL,BFL,OFL) version 2.00.052.0000.1599259237 9 | eml | Install SAP HANA EML AFL version 2.00.052.0000.1599259237 10 | epmmds | Install SAP HANA EPM-MDS version 2.00.052.0000.1599259237 Enter comma-separated list of the selected indices [3]: 2,3 Enter Installation Path [/hana/shared]: Enter Local Host Name [sapcc-hana-tst-03]:
Verify that the installation tool installed all selected components at all worker and standby hosts.
