NetApp Solutions SAP
Automation example scripts
In this document, two scripts are used to further automate SnapCenter clone create and clone delete operations.
  • The script sc-system-refresh.sh is used for the system refresh and the system clone workflow to execute mount and unmount operations for the HANA data volume as well as for recovery and shutdown operations of the HANA database.
  • The script sc-mount-volume.sh is used for the system clone workflow to execute mount and unmount operations for the HANA shared volume.
Note The example scripts are provided as is and are not supported by NetApp. You can request the scripts via email to ng-sapcc@netapp.com.
Script sc-system-refresh.sh
The example script sc-system-refresh.sh is used to execute mount and unmount operations for SAP HANA data volumes as well as recovery and shutdown operations. The script is called with specific command-line options within the SnapCenter workflows clone create and clone delete, as shown in the following figure.
The script is generic and is configured with an SID-specific configuration file and environment variables, which are made available by SnapCenter when executing the script. The script and the configuration file must be available at the target host of the system refresh operation. If the script is used for multiple target hosts, you can provide an NFS share from which the script is made available to all target hosts.
Note The current version of the script supports single host systems with a single container, MDC single tenant, or MDC multiple tenant configurations. It does not support SAP HANA multiple-host systems.
Note The script supports HANA systems using NFS or Fibre Channel (FC) as a storage protocol.
Error: Missing Graphic Image
Supported tenant recovery operations
As described in the section “SAP HANA system refresh operation workflows using storage snapshot backups” the possible tenant recovery operations at the target system depend on the tenant configuration of the source system. The script sc-system-refresh.sh supports all tenant recovery operations, which are possible dependent on the source system configuration, as shown in the following table.
If a different tenant name is required at the target system, the tenant must be renamed manually after the recovery operation.
HANA System Tenant Configuration at Source System Tenant Configuration at Target System
Single container
NA
NA
MDC single tenant
Source tenant name equal to source SID
Target tenant name is equal to target SID
MDC single tenant
Source tenant name not equal to source SID
Target tenant name is equal to source tenant name
MDC multiple tenants
Any tenant names
Only the first tenant is recovered and has the same name as the source tenant.
This script uses a configuration file to configure a few target system-specific parameters. The configuration file must have an SID-specific file name sc-system-refresh- SID.cfg.
Note The database user, which is configured with the hdbuserstore key for the target system, must exist in the source database and must have the correct rights to allow database recovery.
The configuration file parameters are shown in the following table.
Parameter Description
KEY
For example:QS1KEY
SAP HANA hdbuserstore key, which should be used for the recovery operation of the target SAP HANA database. The key must be configured for the user <SID>adm on the target host.
PROTOCOL
NFS or FCP
Storage protocol, that is used to connect the HANA database data volume.
The following output shows an example configuration file for an SAP HANA system with SID=QS1.
ss1adm@hana-1:/mnt/sapcc-share/SAP-System-Refresh> cat sc-system-refresh-QS1.cfg
# Target database specific parameters
# hdbuserstore key, which should be used to connect to the target database
KEY="QS1KEY"
# Used storage protocol, NFS or FCP
PROTOCOL="NFS"
SnapCenter environment variables
SnapCenter provides a set of environment variables that are available within the script that is executed at the target host. The script uses these variables to determine relevant configuration settings.
  • The script variable HANA_ARCHITECTURE is used to determine the required recovery operation, either for single container or MDC systems.
    • Derived from HANA_DATABASE_TYPE environmental variable
    • For example: MDC\SS1_HANA_DATABASE_TYPE=MULTIPLE_CONTAINERS
  • the script variables TENANT_LIST, SOURCE_TENANT, and SOURCE_SID are used to determine the target tenant name for a recovery operation.
    • Derived from TENANT_DATABASE_NAMES environmental variable
    • For example: MDC\SM1_TENANT_DATABASE_NAMES=TENANT1,TENANT2
  • The script variable STORAGE, JUNCTION_PATH is used for the mount operation.
    • Derived from CLONED_VOLUMES_MOUNT_PATH environmental variable
    • For example:
CLONED_VOLUMES_MOUNT_PATH=192.168.175.117:/SS1_data_mnt00001_Clone_05112206115489411
Script sc-mount-volume.sh
The example script sc- mount-volume.sh is used to execute mount and unmount for any volume. The script is used to mount the HANA shared volume with the SAP HANA system clone operation. The script is called with specific command-line options within the SnapCenter workflows clone create and clone delete, as shown in the following figure.
Note The script supports HANA systems using NFS as a storage protocol.
    • Derived from CLONED_VOLUMES_MOUNT_PATH environment variable.
    • For example:
CLONED_VOLUMES_MOUNT_PATH=192.168.175.117:/SS1_shared_Clone_05112206115489411
Script to get SnapCenter environment variables
If the automation scripts should not be used and the steps should be executed manually, you need to know the storage system junction path of the FlexClone volume. The junction path is not visible within SnapCenter, so you need to either look up the junction path directly at the storage system, or you could use a simple script that provides the SnapCenter environment variables at the target host. This script needs to be added as a mount operation script within the SnapCenter clone create operation.
ss1adm@hana-1:/mnt/sapcc-share/SAP-System-Refresh> cat get-env.sh
#!/bin/bash
rm /tmp/env-from-sc.txt
env > /tmp/env-from-sc.txt
Within the env-from-sc.txt file, look for the variable CLONED_VOLUMES_MOUNT_PATH to get the storage system IP address and junction path of the FlexClone volume.
For example:
