NetApp Solutions SAP
Storage controller setup
Contributors netapp-mschoen kevin-hoke
This section describes the configuration of the NetApp storage system. You must complete the primary installation and setup according to the corresponding ONTAP setup and configuration guides.
Storage efficiency
Inline deduplication, cross- volume inline deduplication, inline compression, and inline compaction are supported with SAP HANA in an SSD configuration.
Enabling the storage efficiency features in an HDD configuration is not supported.
NetApp FlexGroup Volumes
The usage of NetApp FlexGroup Volumes is not supported for SAP HANA. Due to the architecture of SAP HANA the usage of FlexGroup Volumes does not provide any benefit and may results in performance issues.
NetApp Volume and Aggregate Encryption
The use of NetApp Volume Encryption (NVE) and NetApp Aggregate Encryption (NAE) are supported with SAP HANA.
Quality of Service
QoS can be used to limit the storage throughput for specific SAP HANA systems or non-SAP applications on a shared controller.
Production and Dev/Test
One use case would be to limit the throughput of development and test systems so that they cannot influence production systems in a mixed setup.
During the sizing process, you should determine the performance requirements of a nonproduction system. Development and test systems can be sized with lower performance values, typically in the range of 20% to 50% of a production-system KPI as defined by SAP.
Large write I/O has the biggest performance effect on the storage system. Therefore, the QoS throughput limit should be set to a percentage of the corresponding write SAP HANA storage performance KPI values in the data and log volumes.
Shared Environments
Another use case is to limit the throughput of heavy write workloads, especially to avoid that these workloads have an impact on other latency sensitive write workloads.
In such environments it is best practice to apply a non-shared throughput ceiling QoS group-policy to each LUN within each Storage Virtual Machine (SVM) to restrict the max throughput of each individual storage object to the given value. This reduces the possibility that a single workload can negatively influence other workloads.
To do so, a group-policy needs to be created using the CLI of the ONTAP cluster for each SVM:
qos policy-group create -policy-group <policy-name> -vserver <vserver name> -max-throughput 1000MB/s -is-shared false
and applied to each LUN within the SVM. Below is an example to apply the policy group to all existing LUNs within an SVM:
lun modify -vserver <vserver name>  -path * -qos-policy-group  <policy-name>
This needs to be done for every SVM. The name of the QoS police group for each SVM needs to be different.
For new LUNs, the policy can be applied directly:
lun create -vserver <vserver_name> -path  /vol/<volume_name>/<lun_name>   -size <size> -ostype <e.g. linux>  -qos-policy-group <policy-name>
It is recommended to use 1000MB/s as maximum throughput for a given LUN. If an application requires more throughput, multiple LUNs with LUN striping shall be used to provide the needed bandwidth. This guide provides an example for SAP HANA based on Linux LVM in section Host Setup.
Note The limit applies also to reads. Therefore use enough LUNs to fulfil the required SLAs for SAP HANA database startup time and for backups.
NetApp FabricPool
NetApp FabricPool technology must not be used for active primary file systems in SAP HANA systems. This includes the file systems for the data and log area as well as the /hana/shared file system. Doing so results in unpredictable performance, especially during the startup of an SAP HANA system.
Using the “snapshot-only” tiering policy is possible as well as using FabricPool in general at a backup target such as SnapVault or SnapMirror destination.
Note Using FabricPool for tiering Snapshot copies at primary storage or using FabricPool at a backup target changes the required time for the restore and recovery of a database or other tasks such as creating system clones or repair systems. Take this into consideration for planning your overall lifecycle- management strategy, and check to make sure that your SLAs are still being met while using this function.
FabricPool is a good option for moving log backups to another storage tier. Moving backups affects the time needed to recover an SAP HANA database. Therefore, the option “tiering-minimum-cooling-days” should be set to a value that places log backups, which are routinely needed for recovery, on the local fast storage tier.
Configure storage
The following overview summarizes the required storage configuration steps. Each step is covered in more detail in the subsequent sections. Before initiating these steps, complete the storage hardware setup, the ONTAP software installation, and the connection of the storage FCP ports to the SAN fabric.
  1. Check the correct disk shelf configuration, as described in Disk shelf connection.
  2. Create and configure the required aggregates, as described in Aggregate configuration.
  3. Create a storage virtual machine (SVM), as described in Storage virtual machine configuration.
  4. Create logical interfaces (LIFs), as described in Logical interface configuration.
  5. Create initiator groups (igroups) with worldwide names (WWNs) of HANA servers as described in the section link:saphana_fas_fc_storage_controller_setup.html#initiator-groups Initiator groups.
  6. Create volumes and LUNs within the aggregates as described in the section Volume and LUN configuration for SAP HANA single-host systems and Volume and LUN configuration for SAP HANA multiple-host systems
  7. Create initiator groups, volumes, and LUNs within the aggregates, as described in Creating LUNs, volumes, and mapping LUNs to initiator groups .
With HDDs, a maximum of two DS2246 disk shelves or four DS224C disk shelves can be connected to one SAS stack to provide the required performance for the SAP HANA hosts, as shown in the following figure. The disks within each shelf must be distributed equally to both controllers of the HA pair.
Figure showing input/output dialog or representing written content
With SSDs, a maximum of one disk shelf can be connected to one SAS stack to provide the required performance for the SAP HANA hosts, as shown in the following figure. The disks within each shelf must be distributed equally to both controllers of the HA pair. With the DS224C disk shelf, quad-path SAS cabling can also be used but is not required.
NVMe (100GbE) disk shelves
Each NS224 NVMe disk shelf is connected with two 100GbE ports per controller, as shown in the following figure. The disks within each shelf must be distributed equally to both controllers of the HA pair.
MVMe disk shelf connections
In general, you must configure two aggregates per controller, independent of which disk shelf or disk technology (SSD or HDD) is used. This step is necessary so that you can use all available controller resources. For FAS 2000 series systems, one data aggregate is sufficient.
Aggregate configuration with HDDs
The following figure shows a configuration for eight SAP HANA hosts. Four SAP HANA hosts are attached to each storage controller. Two separate aggregates, one at each storage controller, are configured. Each aggregate is configured with 4 × 10 = 40 data disks (HDDs).
Aggregate configuration with SDD-only systems
In general, two aggregates per controller must be configured, independently of which disk shelf or disk technology (SSDs or HDDs) is used.
The following figure shows a configuration of 12 SAP HANA hosts running on a 12Gb SAS shelf configured with ADPv2. Six SAP HANA hosts are attached to each storage controller. Four separate aggregates, two at each storage controller, are configured. Each aggregate is configured with 11 disks with nine data and two parity disk partitions. For each controller, two spare partitions are available.
Multiple-host SAP landscapes with SAP HANA databases can use a single SVM. An SVM can also be assigned to each SAP landscape if necessary in case they are managed by different teams within a company. The screenshots and command outputs in this document use an SVM named hana.
Within the storage cluster configuration, one network interface (LIF) must be created and assigned to a dedicated FCP port. If, for example, four FCP ports are required for performance reasons, four LIFs must be created. The following figure shows a screenshot of the eight LIFs that were configured on the SVM.
Overview of Logical Interfaces
During SVM creation with ONTAP 9 System Manager, all the required physical FCP ports can be selected, and one LIF per physical port is created automatically.
The following figure depicts the creation of SVM and LIFs with ONTAP System Manager.
SVM creation
Initiator groups
An igroup can be configured for each server or for a group of servers that require access to a LUN. The igroup configuration requires the worldwide port names (WWPNs) of the servers.
Using the sanlun tool, run the following command to obtain the WWPNs of each SAP HANA host:
stlrx300s8-6:~ # sanlun fcp show adapter
/sbin/udevadm
/sbin/udevadm
host0 ...... WWPN:2100000e1e163700
host1 ...... WWPN:2100000e1e163701
Note The sanlun tool is part of the NetApp Host Utilities and must be installed on each SAP HANA host. More details can be found in section Host setup.
The initiator groups can be created using the CLI of the ONTAP Cluster.
lun igroup create -igroup <igroup name> -protocol fcp -ostype linux -initiator <list of initiators> -vserver <SVM name>
The following figure shows the volume configuration of four single-host SAP HANA systems. The data and log volumes of each SAP HANA system are distributed to different storage controllers. For example, volume SID1_data_mnt00001 is configured on controller A and volume SID1_log_mnt00001 is configured on controller B. Within each volume, a single LUN is configured.
Note If only one storage controller of a high-availability (HA) pair is used for the SAP HANA systems, data volumes and log volumes can also be stored on the same storage controller.
For each SAP HANA host, a data volume, a log volume, and a volume for /hana/shared are configured. The following table shows an example configuration with four SAP HANA single-host systems.
Purpose Aggregate 1 at Controller A Aggregate 2 at Controller A Aggregate 1 at Controller B Aggregate 2 at Controller B
Data, log, and shared volumes for system SID1
Data volume: SID1_data_mnt00001
Shared volume: SID1_shared
Log volume: SID1_log_mnt00001
Data, log, and shared volumes for system SID2
Log volume: SID2_log_mnt00001
Data volume: SID2_data_mnt00001
Shared volume: SID2_shared
Data, log, and shared volumes for system SID3
Shared volume: SID3_shared
Data volume: SID3_data_mnt00001
Log volume: SID3_log_mnt00001
Data, log, and shared volumes for system SID4
Log volume: SID4_log_mnt00001
Shared volume: SID4_shared
Data volume: SID4_data_mnt00001
The next table shows an example of the mount point configuration for a single-host system.
LUN Mount point at HANA host Note
SID1_data_mnt00001
/hana/data/SID1/mnt00001
Mounted using /etc/fstab entry
SID1_log_mnt00001
/hana/log/SID1/mnt00001
SID1_shared
/hana/shared/SID1
Note With the described configuration, the /usr/sap/SID1 directory in which the default home directory of user SID1adm is stored, is on the local disk. In a disaster recovery setup with disk-based replication, NetApp recommends creating an additional LUN within the SID1_shared volume for the /usr/sap/SID1 directory so that all file systems are on the central storage.
Volume and LUN configuration for SAP HANA single-host systems using Linux LVM
The Linux LVM can be used to increase performance and to address LUN size limitations. The different LUNs of an LVM volume group should be stored within a different aggregate and at a different controller. The following table shows an example for two LUNs per volume group.
Note It is not necessary to use LVM with multiple LUNs to fulfil the SAP HANA KPIs. A single LUN setup fulfils the required KPIs.
Data, log, and shared volumes for LVM based system
Log2 volume: SID1_log2_mnt00001
Data2 volume: SID1_data2_mnt00001
At the SAP HANA host, volume groups and logical volumes must be created and mounted. The next table lists the mount points for single-host systems using LVM.
Logical volume/LUN Mount point at SAP HANA host Note
LV: SID1_data_mnt0000-vol
LV: SID1_log_mnt00001-vol
LUN: SID1_shared
/hana/shared/SID1
The following figure shows the volume configuration of a 4+1 multiple-host SAP HANA system. The data volumes and log volumes of each SAP HANA host are distributed to different storage controllers. For example, the volume SID_data_mnt00001 is configured on controller A and the volume SID_log_mnt00001 is configured on controller B. One LUN is configured within each volume.
The /hana/shared volume must be accessible by all HANA hosts and is therefore exported by using NFS. Even though there are no specific performance KPIs for the /hana/shared file system, NetApp recommends using a 10Gb Ethernet connection.
Note If only one storage controller of an HA pair is used for the SAP HANA system, data and log volumes can also be stored on the same storage controller.
For each SAP HANA host, a data volume and a log volume are created. The /hana/shared volume is used by all hosts of the SAP HANA system. The following figure shows an example configuration for a 4+1 multiple-host SAP HANA system.
Data and log volumes for node 1
Data volume: SID_data_mnt00001
Log volume: SID_log_mnt00001
Data and log volumes for node 2
Log volume: SID_log_mnt00002
Data volume: SID_data_mnt00002
Data and log volumes for node 3
Data volume: SID_data_mnt00003
Log volume: SID_log_mnt00003
Data and log volumes for node 4
Log volume: SID_log_mnt00004
Data volume: SID_data_mnt00004
Shared volume for all hosts
Shared volume: SID_shared
The next table shows the configuration and the mount points of a multiple-host system with four active SAP HANA hosts.
LUN or Volume Mount point at SAP HANA host Note
LUN: SID_data_mnt00001
/hana/data/SID/mnt00001
Mounted using storage connector
LUN: SID_log_mnt00001
/hana/log/SID/mnt00001
LUN: SID_data_mnt00002
/hana/data/SID/mnt00002
LUN: SID_log_mnt00002
/hana/log/SID/mnt00002
LUN: SID_data_mnt00003
/hana/data/SID/mnt00003
LUN: SID_log_mnt00003
/hana/log/SID/mnt00003
LUN: SID_data_mnt00004
/hana/data/SID/mnt00004
LUN: SID_log_mnt00004
/hana/log/SID/mnt00004
Volume: SID_shared
/hana/shared/SID
Mounted at all hosts using NFS and /etc/fstab entry
Note With the described configuration, the /usr/sap/SID directory in which the default home directory of user SIDadm is stored is on the local disk for each HANA host. In a disaster recovery setup with disk-based replication, NetApp recommends creating four additional subdirectories in the SID_shared volume for the /usr/sap/SID file system so that each database host has all its file systems on the central storage.
Volume and LUN configuration for SAP HANA multiple-host systems using Linux LVM
The Linux LVM can be used to increase performance and to address LUN size limitations. The different LUNs of an LVM volume group should be stored within a different aggregate and at a different controller. The following table shows an example for two LUNs per volume group for a 2+1 SAP HANA multiple host system.
Note It is not necessary to use LVM to combine several LUN to fulfil the SAP HANA KPIs. A single LUN setup fulfils the required KPIs.
Log2 volume: SID_log2_mnt00001
Data2 volume: SID_data2_mnt00001
Log2 volume: SID_log2_mnt00002
Data2 volume: SID_data2_mnt00002
At the SAP HANA host, volume groups and logical volumes need to be created and mounted:
Logical volume (LV) or volume Mount point at SAP HANA host Note
LV: SID_data_mnt00001-vol
LV: SID_log_mnt00001-vol
LV: SID_data_mnt00002-vol
LV: SID_log_mnt00002-vol
Volume: SID_shared
/hana/shared
Note With the described configuration, the /usr/sap/SID directory in which the default home directory of user SIDadm is stored, is on the local disk for each HANA host. In a disaster recovery setup with disk-based replication, NetApp recommends creating four additional subdirectories in the SID_shared volume for the /usr/sap/SID file system so that each database host has all its file systems on the central storage.
Volume options
The volume options listed in the following table must be verified and set on all SVMs.
Action ONTAP 9
Disable automatic Snapshot copies
vol modify –vserver <vserver-name> -volume <volname> -snapshot-policy none
Disable visibility of Snapshot directory
vol modify -vserver <vserver-name> -volume <volname> -snapdir-access false
You can use NetApp ONTAP System Manager to create storage volumes and LUNs and the map them to the igroups of the servers and the ONTAP CLI. This guide describes the usage of the CLI.
Creating LUNs, volumes, and mapping LUNs to igroups using the CLI
This section shows an example configuration using the command line with ONTAP 9 for a 2+1 SAP HANA multiple host system with SID FC5 using LVM and two LUNs per LVM volume group.
  1. Create all necessary volumes.
    vol create -volume FC5_data_mnt00001 -aggregate aggr1_1 -size 1200g  -snapshot-policy none -foreground true -encrypt false  -space-guarantee none
    vol create -volume FC5_log_mnt00002  -aggregate aggr2_1 -size 280g  -snapshot-policy none -foreground true -encrypt false  -space-guarantee none
    vol create -volume FC5_log_mnt00001  -aggregate aggr1_2 -size 280g -snapshot-policy none -foreground true -encrypt false -space-guarantee none
    vol create -volume FC5_data_mnt00002  -aggregate aggr2_2 -size 1200g -snapshot-policy none -foreground true -encrypt false -space-guarantee none
    vol create -volume FC5_data2_mnt00001 -aggregate aggr1_2 -size 1200g -snapshot-policy none -foreground true -encrypt false -space-guarantee none
    vol create -volume FC5_log2_mnt00002  -aggregate aggr2_2 -size 280g -snapshot-policy none -foreground true -encrypt false -space-guarantee none
    vol create -volume FC5_log2_mnt00001  -aggregate aggr1_1 -size 280g -snapshot-policy none -foreground true -encrypt false  -space-guarantee none
    vol create -volume FC5_data2_mnt00002  -aggregate aggr2_1 -size 1200g -snapshot-policy none -foreground true -encrypt false -space-guarantee none
    vol create -volume FC5_shared -aggregate aggr1_1 -size 512g -state online -policy default -snapshot-policy none -junction-path /FC5_shared -encrypt false  -space-guarantee none
  2. Create all LUNs.
    lun create -path  /vol/FC5_data_mnt00001/FC5_data_mnt00001   -size 1t -ostype linux -space-reserve disabled -space-allocation disabled -class regular
    lun create -path /vol/FC5_data2_mnt00001/FC5_data2_mnt00001 -size 1t -ostype linux -space-reserve disabled -space-allocation disabled -class regular
    lun create -path /vol/FC5_data_mnt00002/FC5_data_mnt00002 -size 1t -ostype linux -space-reserve disabled -space-allocation disabled -class regular
    lun create -path /vol/FC5_data2_mnt00002/FC5_data2_mnt00002 -size 1t -ostype linux -space-reserve disabled -space-allocation disabled -class regular
    lun create -path /vol/FC5_log_mnt00001/FC5_log_mnt00001 -size 260g -ostype linux -space-reserve disabled -space-allocation disabled -class regular
    lun create -path /vol/FC5_log2_mnt00001/FC5_log2_mnt00001 -size 260g -ostype linux -space-reserve disabled -space-allocation disabled -class regular
    lun create -path /vol/FC5_log_mnt00002/FC5_log_mnt00002 -size 260g -ostype linux -space-reserve disabled -space-allocation disabled -class regular
    lun create -path /vol/FC5_log2_mnt00002/FC5_log2_mnt00002 -size 260g -ostype linux -space-reserve disabled -space-allocation disabled -class regular
  3. Create the igroup for all servers belonging to system FC5.
    lun igroup create -igroup HANA-FC5 -protocol fcp -ostype linux -initiator 10000090fadcc5fa,10000090fadcc5fb, 10000090fadcc5c1,10000090fadcc5c2,  10000090fadcc5c3,10000090fadcc5c4 -vserver hana
  4. Map all LUNs to the created igroup.
    lun map -path  /vol/FC5_data_mnt00001/FC5_data_mnt00001    -igroup HANA-FC5
    lun map -path /vol/FC5_data2_mnt00001/FC5_data2_mnt00001  -igroup HANA-FC5
    lun map -path /vol/FC5_data_mnt00002/FC5_data_mnt00002  -igroup HANA-FC5
    lun map -path /vol/FC5_data2_mnt00002/FC5_data2_mnt00002  -igroup HANA-FC5
    lun map -path /vol/FC5_log_mnt00001/FC5_log_mnt00001  -igroup HANA-FC5
    lun map -path /vol/FC5_log2_mnt00001/FC5_log2_mnt00001  -igroup HANA-FC5
    lun map -path /vol/FC5_log_mnt00002/FC5_log_mnt00002  -igroup HANA-FC5
    lun map -path /vol/FC5_log2_mnt00002/FC5_log2_mnt00002  -igroup HANA-FC5
