SAP LaMa provisioning workflow - clone system
The following figure highlights the main steps executed with the system clone workflow.
![Workflow diagram containing the steps Storage Cloning, Prepare System, Activate Isolation, and Start System.](./../media/lama-ansible-image17.png)
In this section, we go through the complete SAP LaMa system cloning workflow based on the source SAP system HN9 with HANA database H09. The following picture gives an overview of the steps executed during the workflow.
![This image depicts the steps executed during the workflow, including Create Cloned System Configuration, Create Storage Snapshot and Clone, Create Mount Point Configuration, Set Custom Properties, and Prepare and start system.](./../media/lama-ansible-image18.png)
To start the cloning workflow, open Provisioning in the menu tree and select the source system (in our example HN9). Then start the Clone System wizard.
Enter the requested values. Screen 1 of the wizard asks for the pool name for the cloned system. This step specifies the instances (virtual or physical) on which the cloned system will be started. The default is to clone the system into the same pool as the target system.
Screen 2 of the wizard asks for the target hosts that the new SAP instances are started on. The target hosts for this instance(s) can be selected out of the host pool specified in the previous screen. Each instance or service can be started on a different host. In our example, all three services run on the same host.
Provide the information requested in screen 3, which asks for virtual host names and networks. Typically, the host names are maintained in DNS, so the IP addresses are prepopulated accordingly.
In screen 4, the custom clone operations are listed. A clone and a SnapPostfix name are provided, which are used during the storage clone operation for the FlexClone volume and Snapshot name, respectively. If you leave these fields empty, the default value configured in the variable section of the provider script
netapp_clone.sh
is used. -
In screen 5, the database consistency option is selected. In our example, we selected Online: Clone running DB.
In screen 6, input is only required if you perform a tenant clone.
In screen 7, system isolation can be configured.
In screen 8, a summary page contains all the settings for final confirmation before the workflow is started. Click Execute to start the workflow.
SAP LaMa now performs all the actions indicated in the configuration. These actions include creating the storage volume clones and exports, mounting them to the target host, adding the firewall rules for isolation, and starting the HANA database and SAP services.
You can monitor the progress of the clone workflow under the Monitoring menu.
Within the detailed log, the operations Clone Volume and Modify Mountpoints and add Custom Properties are executed at the Ansible node, the
sap-jump
host. These steps are executed for each service, the HANA database, the SAP central services, and the SAP AS service. -
By selecting the Clone Volumes task the detailed log for that step is displayed and the execution of the Ansible Playbook is shown here. You can see, that the Ansible playbook
netapp_lama_CloneVolumes.yml
is executed for each HANA database volume, data, log, and shared. -
In the details view of the step Modify Mountpoints and add Custom Properties, you can find information about the mount points and the custom properties handed over by the execution script.
After the workflow has been completed, the cloned SAP system is prepared, started, and ready for use.
