The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
SAP HANA data volume size
PDF of this doc site
Backup, Restore and Disaster Recovery
Creating your file...
Your file is ready
As the default, SAP HANA uses only one data volume per SAP HANA service. Due to the maximum file size limitation of the file system, NetApp recommends limiting the maximum data volume size.
To do so automatically, set the following parameter in global.ini
in the section [persistence]
datavolume_striping = true datavolume_striping_size_gb = 8000
This creates a new data volume after the 8,000GB limit is reached. SAP note 240005 question 15 provides more information.
