Storage controller setup
This section describes the configuration of the NetApp storage system. You must complete the primary installation and setup according to the corresponding ONTAP setup and configuration guides.
Storage efficiency
Inline deduplication, cross-volume inline deduplication, inline compression, and inline compaction are supported with SAP HANA in an SSD configuration.
NetApp FlexGroup Volumes
The usage of NetApp FlexGroup Volumes is not supported for SAP HANA. Due to the architecture of SAP HANA the usage of FlexGroup Volumes does not provide any benefit and may results in performance issues.
NetApp Volume and Aggregate Encryption
The use of NetApp Volume Encryption (NVE) and NetApp Aggregate Encryption (NAE) are supported with SAP HANA.
Quality of Service
QoS can be used to limit the storage throughput for specific SAP HANA systems or other applications on a shared-use controller. One use case would be to limit the throughput of development and test systems so that they cannot influence production systems in a mixed setup.
During the sizing process, you should determine the performance requirements of a nonproduction system. Development and test systems can be sized with lower performance values, typically in the range of 20% to 50% of a production- system KPI as defined by SAP.
Starting with ONTAP 9, QoS is configured on the storage volume level and uses maximum values for throughput (MBps) and the amount of I/O (IOPS).
Large write I/O has the biggest performance effect on the storage system. Therefore, the QoS throughput limit should be set to a percentage of the corresponding write SAP HANA storage performance KPI values in the data and log volumes.
NetApp FabricPool
NetApp FabricPool technology must not be used for active primary file systems in SAP HANA systems. This includes the file systems for the data and log area as well as the /hana/shared
file system. Doing so results in unpredictable performance, especially during the startup of an SAP HANA system.
Using the “snapshot-only” tiering policy is possible as well as using FabricPool in general at a backup target such as a NetApp SnapVault or SnapMirror destination.
Using FabricPool for tiering Snapshot copies at primary storage or using FabricPool at a backup target changes the required time for the restore and recovery of a database or other tasks such as creating system clones or repair systems. Take this into consideration for planning your overall lifecycle-management strategy and check to make sure that your SLAs are still being met while using this function. |
FabricPool is a good option for moving log backups to another storage tier. Moving backups affects the time needed to recover an SAP HANA database. Therefore, the option “tiering-minimum-cooling-days” should be set to a value that places log backups, which are routinely needed for recovery, on the local fast storage tier.
Storage configuration
The following overview summarizes the required storage configuration steps. Each step is covered in detail in the subsequent sections. In this section, we assume that the storage hardware is set up and that the ONTAP software is already installed. Also, the connections between the storage ports (10GbE or faster) and the network must already be in place.
Check the correct disk shelf configuration as described in "Disk shelf connection."
Create and configure the required aggregates as described in "Aggregate configuration."
Create a storage virtual machine (SVM) as described in "SVM configuration."
Create LIFs as described in "LIF configuration."
Create volumes within the aggregates as described in "[Volume configuration for SAP HANA single host systems]" and "[Volume configuration for SAP HANA multiple host systems]."
Set the required volume options as described in "Volume options."
Set the required options for NFSv3 as described in "NFS configuration for NFSv3" or for NFSv4 as described in "NFS configuration for NFSv4."
Mount the volumes to namespace and set export policies as described in "Mount volumes to namespace and set export policies."
SAS disk shelves
A maximum of one disk shelf can be connected to one SAS stack to provide the required performance for the SAP HANA hosts, as shown in the following figure. The disks within each shelf must be distributed equally to both controllers of the HA pair. ADPv2 is used with ONTAP 9 and the DS224C disk shelves.
With the DS224C disk shelf, quad-path SAS cabling can also be used but is not required. |
NVMe (100GbE) disk shelves
Each NS224 NVMe disk shelf is connected using two 100GbE ports per controller. The disks within each shelf must be distributed equally to both controllers of the HA pair. ADPv2, as described in the aggregate configuration chapter, is also used for the NS224 disk shelf. The following figure depicts the disk shelf connection with an NVMe drive.
In general, you must configure two aggregates per controller, independent of the disk shelf or drive technology (SAS SSDs or NVMe SSDs) that is used. This step is necessary so that you can use all available controller resources. For AFF A200 series systems, one data aggregate is enough.
The following image shows a configuration of 12 SAP HANA hosts running on a 12Gb SAS shelf configured with ADPv2. Six SAP HANA hosts are attached to each storage controller. Four separate aggregates, two at each storage controller, are configured. Each aggregate is configured with 11 disks with nine data and two parity disk partitions. For each controller, two spare partitions are available.
SVM configuration
Multiple SAP landscapes with SAP HANA databases can use a single SVM. An SVM can also be assigned to each SAP landscape, if necessary, in case they are managed by different teams within a company.
If there is a QoS profile automatically created and assigned while creating a new SVM, remove this automatically created profile from the SVM to enable the required performance for SAP HANA:
vserver modify -vserver <svm-name> -qos-policy-group none
LIF configuration
For SAP HANA production systems, you must use different LIFs to mount the data volume and the log volume from the SAP HANA host. Therefore at least two LIFs are required.
The data and log volume mounts of different SAP HANA hosts can share a physical storage network port by either using the same LIFs or by using individual LIFs for each mount.
The maximum amount of data and log volume mounts per physical interface are shown in the following table.
Ethernet port speed | 10GbE | 25GbE | 40GbE | 100GeE |
Maximum number of log or data volume mounts per physical port |
2 |
6 |
12 |
24 |
Sharing one LIF between different SAP HANA hosts might require a remount of data or log volumes to a different LIF. This change avoids performance penalties if a volume is moved to a different storage controller. |
Development and test systems can use more data and volume mounts or LIFs on a physical network interface.
For production, development, and test systems, the /hana/shared
file system can use the same LIF as the data or log volume.
Volume configuration for SAP HANA single-host systems
The following figure shows the volume configuration of four single-host SAP HANA systems. The data and log volumes of each SAP HANA system are distributed to different storage controllers. For example, volume SID1_data_mnt00001
is configured on controller A, and volume SID1_log_mnt00001
is configured on controller B.
If only one storage controller of an HA pair is used for the SAP HANA systems, data and log volumes can also be stored on the same storage controller. |
If the data and log volumes are stored on the same controller, access from the server to the storage must be performed with two different LIFs: one LIF to access the data volume and the other to access the log volume. |
For each SAP HANA host, a data volume, a log volume, and a volume for /hana/shared
are configured. The following table shows an example configuration for single-host SAP HANA systems.
Purpose | Aggregate 1 at Controller A | Aggregate 2 at Controller A | Aggregate 1 at Controller B | Aggregate 2 at Controller b |
Data, log, and shared volumes for system SID1 |
Data volume: SID1_data_mnt00001 |
Shared volume: SID1_shared |
Log volume: SID1_log_mnt00001 |
Data, log, and shared volumes for system SID2 |
Log volume: SID2_log_mnt00001 |
Data volume: SID2_data_mnt00001 |
Shared volume: SID2_shared |
Data, log, and shared volumes for system SID3 |
Shared volume: SID3_shared |
Data volume: SID3_data_mnt00001 |
Log volume: SID3_log_mnt00001 |
Data, log, and shared volumes for system SID4 |
Log volume: SID4_log_mnt00001 |
Shared volume: SID4_shared |
Data volume: SID4_data_mnt00001 |
The following table shows an example of the mount point configuration for a single-host system. To place the home directory of the sidadm
user on the central storage, the /usr/sap/SID
file system should be mounted from the SID_shared
volume.
Junction path | Directory | Mount point at HANA host |
SID_data_mnt00001 |
/hana/data/SID/mnt00001 |
SID_log_mnt00001 |
/hana/log/SID/mnt00001 |
SID_shared |
usr-sap |
/usr/sap/SID |
Volume configuration for SAP HANA multiple-host systems
The following figure shows the volume configuration of a 4+1 SAP HANA system. The data and log volumes of each SAP HANA host are distributed to different storage controllers. For example, volume SID1_data1_mnt00001
is configured on controller A, and volume SID1_log1_mnt00001
If only one storage controller of an HA pair is used for the SAP HANA system, the data and log volumes can also be stored on the same storage controller. |
If the data and log volumes are stored on the same controller, access from the server to the storage must be performed with two different LIFs: one LIF to access the data volume and one to access the log volume. |
For each SAP HANA host, a data volume and a log volume are created. The /hana/shared
volume is used by all hosts of the SAP HANA system. The following table shows an example configuration for a multiple-host SAP HANA system with four active hosts.
Purpose | Aggregate 1 at controller A | Aggregate 2 at controller A | Aggregate 1 at controller B | Aggregate 2 at controller B |
Data and log volumes for node 1 |
Data volume: SID_data_mnt00001 |
Log volume: SID_log_mnt00001 |
Data and log volumes for node 2 |
Log volume: SID_log_mnt00002 |
Data volume: SID_data_mnt00002 |
Data and log volumes for node 3 |
Data volume: SID_data_mnt00003 |
Log volume: SID_log_mnt00003 |
Data and log volumes for node 4 |
Log volume: SID_log_mnt00004 |
Data volume: SID_data_mnt00004 |
Shared volume for all hosts |
Shared volume: SID_shared |
The following table shows the configuration and the mount points of a multiple-host system with four active SAP HANA hosts. To place the home directories of the sidadm
user of each host on the central storage, the /usr/sap/SID
file systems are mounted from the SID_shared
volume.
Junction path | Directory | Mount point at SAP HANA host | Note |
SID_data_mnt00001 |
Mounted at all hosts |
SID_log_mnt00001 |
SID_data_mnt00002 |
/hana/data/SID/mnt00002 |
SID_log_mnt00002 |
/hana/log/SID/mnt00002 |
SID_data_mnt00003 |
/hana/data/SID/mnt00003 |
SID_log_mnt00003 |
/hana/log/SID/mnt00003 |
SID_data_mnt00004 |
/hana/data/SID/mnt00004 |
SID_log_mnt00004 |
/hana/log/SID/mnt00004 |
SID_shared |
shared |
/hana/shared/SID |
SID_shared |
usr-sap-host1 |
/usr/sap/SID |
Mounted at host 1 |
SID_shared |
usr-sap-host2 |
/usr/sap/SID |
Mounted at host 2 |
SID_shared |
usr-sap-host3 |
/usr/sap/SID |
Mounted at host 3 |
SID_shared |
usr-sap-host4 |
/usr/sap/SID |
Mounted at host 4 |
SID_shared |
usr-sap-host5 |
/usr/sap/SID |
Mounted at host 5 |
Volume options
You must verify and set the volume options listed in the following table on all SVMs. For some of the commands, you must switch to the advanced privilege mode within ONTAP.
Action | Command |
Disable visibility of Snapshot directory |
vol modify -vserver <vserver-name> -volume <volname> -snapdir-access false |
Disable automatic Snapshot copies |
vol modify –vserver <vserver-name> -volume <volname> -snapshot-policy none |
Disable access time update, except of the SID_shared volume |
set advanced |
The NFS options listed in the following table must be verified and set on all storage controllers. For some of the commands shown in this table, you must switch to the advanced privilege mode.
Action | Command |
Enable NFSv3 |
nfs modify -vserver <vserver-name> v3.0 enabled |
ONTAP 9: |
set advanced |
ONTAP 8: |
set advanced |
The NFS options listed in the following table must be verified and set on all SVMs.
For some of the commands in this table, you must switch to the advanced privilege mode.
Action | Command |
Enable NFSv4 |
nfs modify -vserver <vserver-name> -v4.1 enabled |
ONTAP 9: |
set advanced |
ONTAP 8: |
set advanced |
Disable NFSv4 access control lists (ACLs) |
nfs modify -vserver <vserver_name> -v4.1-acl disabled |
Set NFSv4 domain ID |
nfs modify -vserver <vserver_name> -v4-id-domain <domain-name> |
Disable NFSv4 read delegation |
nfs modify -vserver <vserver_name> -v4.1-read-delegation disabled |
Disable NFSv4 write delegation |
nfs modify -vserver <vserver_name> -v4.1-write-delegation disabled |
Disable NFSv4 numeric ids |
nfs modify -vserver <vserver_name> -v4-numeric-ids disabled |
Change amount of NFSv4.x session slots |
set advanced |
Please note that disabling numeric ids requires user management, as described in the section “SAP HANA installation preparations for NFSv4.” |
The NFSv4 domain ID must be set to the same value on all Linux servers (/etc/idmapd.conf ) and SVMs, as described in the section “SAP HANA installation preparations for NFSv4.”
If you are using NFSV4.1, then pNFS can be enabled and used. |
If SAP HANA multiple-host systems with host auto-failover are being used, the failover parameters need to be adjusted within nameserver.ini
as shown in the following table.
Keep the default retry interval of 10 seconds within these sections..
Section within nameserver.ini | Parameter | Value |
failover |
normal_retries |
9 |
distributed_watchdog |
deactivation_retries |
11 |
takeover_retries |
9 |
When a volume is created, the volume must be mounted to the namespace. In this document, we assume that the junction path name is the same as the volume name. By default, the volume is exported with the default policy. The export policy can be adapted if required.
