Protect VCF workload domains with NVMe over TCP storage and SnapCenter plug-in for VMware vSphere
Use SnapCenter Plug-in for VMware vSphere to protect VCF workload domains with NVMe. This procedure includes setting up the plug-in, configuring NVMe over TCP for optimal performance, and performing backup, restore, or cloning operations.
NVMe (Non-Volatile Memory Express) over TCP is a cutting-edge network protocol that facilitates high-speed data transfer between VMware Cloud Foundation ESXi servers and NetApp storage, including All Flash FAS (AFF) and All SAN Array (ASA).
Introduction
Leveraging NVMe over TCP provides low latency and high throughput for demanding workloads. The integration of NVMe over TCP with NetApp SnapCenter Plug-in for VMware vSphere (SCV) offers a powerful combination for efficient data management, enhancing backup, restore, and cloning operations within VMware environments.
Benefits of NVMe over TCP
High Performance: Delivers exceptional performance with low latency and high data transfer rates. This is crucial for demanding applications and large-scale data operations.
Scalability: Supports scalable configurations, allowing IT administrators to expand their infrastructure seamlessly as data requirements grow.
Efficiency: Enables faster backup and restore operations, reducing downtime and improving overall system availability.
This document provides steps on deploying and managing SCV in VMware Cloud Foundation (VCF) environments, with a focus on leveraging NVMe over TCP for optimal performance.
Audience
Solution architects or storage administrators ensuring data protection and disaster recovery for VMware VCF workload domains.
Architecture overview
SCV is a powerful tool designed to facilitate fast, space-efficient, crash-consistent, and VM-consistent backup and restore operations for VMs, datastores, and files and folders in VMware environments. SCV is deployed as a Linux virtual appliance using an OVA file and leverages a remote plug-in architecture.
SCV deployment architecture
Virtual Appliance Deployment: SCV is deployed as a Linux virtual appliance using an OVA file. This deployment method ensures a streamlined and efficient setup process.
Remote Plug-in Architecture: SCV uses a remote plug-in architecture, allowing for scalability and flexibility in managing multiple instances.
One-to-One Relationship: Each VCF domain requires a dedicated SCV instance, ensuring isolated and efficient backup and restore operations.
With ONTAP 9.10.1 and later versions, NetApp AFF and ASA support NVMe over TCP. Data that is on AFF, or ASA primary systems and can replicate to ONTAP AFF, or ASA secondary systems. SCV also works with SnapCenter Server to support application-based backup and restore operations in VMware environments for SnapCenter application-specific plug-ins. For more information check, SnapCenter Plug-in for VMware vSphere documentation and Protect Workloads with SnapCenter
The 3-2-1 backup rule is a data protection strategy that involves making three copies of data, storing them on two different types of media, and keeping one copy off-site. NetApp Backup and Recovery is a cloud based tool for data management that provides a single control plane for a wide range of backup and recovery operations across both on-premises and cloud environments. For more details, check NetApp Backup and Recovery Documentation.
SCV for VCF on NVMe deployment steps
The ONTAP tools for VMware vSphere (OTV) provides a powerful and efficient solution for managing NetApp storage in VMware environments. By integrating directly with the vCenter Server, OTV simplifies storage management, enhances data protection, and optimizes performance. While optional, deploying OTV can significantly improve the management capabilities and overall efficiency of VMware environments.
Restore VM, datastore, virtual disk and files or folders
SCV provides comprehensive backup and restore capabilities for VMware environments. For VMFS environments, SCV uses clone and mount operations in conjunction with Storage VMotion to perform restore operations. This ensures efficient and seamless restoration of data. For more details check how the restore operations are performed.
VM restore
You can restore the VM to its original host within the same vCenter Server or to an alternate ESXi host managed by the same vCenter Server.-
Right click a VM and select SnapCenter Plug-in for VMware vSphere in the drop-down list, and then select Restore in the secondary drop-down list to start the wizard.
In the Restore wizard, select the backup Snapshot that you want to restore and select Entire virtual machine in the Restore scope field, select the restore location, and then enter the destination information where the backup should be mounted. On the Select Location page, select the location for the restored datastore. Review the Summary page and click Finish.
Mount a datastore
You can mount a traditional datastore from a backup if you want to access files in the backup. You can either mount the backup to the same ESXi host where the backup was created or to an alternate ESXi host that has the same type of VM and host configurations. You can mount a datastore multiple times on a host.-
Right-click a datastore and select select SnapCenter Plug-in for VMware vSphere > Mount Backup.
On the Mount Datastore page, select a backup and a backup location (primary or secondary), and then click Mount.
Attach a virtual disk
You can attach one or more VMDKs from a backup to the parent VM, or to an alternate VM on the same ESXi host, or to an alternate VM on an alternate ESXi host managed by the same vCenter or a different vCenter in linked mode.-
Right click a VM, select SnapCenter Plug-in for VMware vSphere > Attach virtual disk(s).
On the Attach Virtual Disk window, select a backup and select one or more disks you want to attach and the location you want to attach from (primary or secondary). By default, the selected virtual disks are attached to the parent VM. To attach the selected virtual disks to an alternate VM in the same ESXi host, select Click here to attach to alternate VM and specify the alternate VM. Click Attach.
Files and folders restore steps
Individual files and folders can be restored in a guest file restore session, which attaches a backup copy of a virtual disk and then restores the selected files or folders. Files and folders can also be restored. More details check SnapCenter file and folder restore.-
When you a virtual attach disk for guest file or folder restore operations, the target VM for the attach must have credentials configured before you restore. From SnapCenter Plug-in for VMware vSphere under plug-ins, select Guest File Restore and Run As Credentials section, enter the User credentials. For Username, you must enter "Administrator".
Right-click on the VM from the vSphere client and select SnapCenter Plug-in for VMware vSphere > Guest File Restore. On the Restore Scope page, specify Backup Name, VMDK virtual disk and Location – primary or secondary. Click Summery to confirm.
Monitor and report
SCV provides robust monitoring and reporting capabilities to help administrators manage backup and restore operations efficiently.
You can view status information, monitor jobs, download job logs, access reports, for more details check SnapCenter plug-in for VMware vSphere Monitor and Report.
By harnessing the power of NVMe over TCP and NetApp SnapCenter Plug-in for VMware vSphere, organizations can achieve high-performance data protection and disaster recovery for VMware Cloud Foundation workload domains. This approach ensures rapid, reliable backup and restore operations, minimizing downtime and safeguarding critical data.
