Create SVM and LIFs for iSCSI vVols datastores in a VCF workload domain
Contributors netapp-jsnyder sureshthoppay netapp-lhalbert
Create a Storage Virtual Machine (SVM) and multiple logical interfaces (LIFs) on an ONTAP system to support iSCSI traffic for vVols datastores in a VMware Cloud Foundation workload domain. You'll add a new SVM, enable iSCSI, configure LIFs, and optionally enable the Storage VM Administration account.
To add new LIFs to an existing SVM, refer to the ONTAP documentation: Create ONTAP LIFs.
Steps
  1. From ONTAP System Manager navigate to Storage VMs in the left-hand menu and click + Add to start.
    Show example
    Click +Add to start creating SVM
  2. In the Add Storage VM wizard, provide a Name for the SVM, select the IP Space and then, under Access Protocol, click the iSCSI tab and check the box to Enable iSCSI.
    Show example
    Add storage VM wizard - enable iSCSI
  3. In the Network Interface section fill in the IP address, Subnet Mask, and Broadcast Domain and Port for the first LIF. For subsequent LIFs, you can either use individual settings or enable the checkbox to use common settings across all remaining LIFs.
    Note For multipathing and failover across multiple paths, create a minimum of two LIFs per storage node in separate Ethernet networks for all SVMs in iSCSI configurations.
    Show example
    Fill out network info for LIFs
  4. Choose whether to enable the Storage VM Administration account (for multi-tenancy environments) and then click Save to create the SVM.
    Show example
    Enable SVM account and Finish
What's next?
After you create the SVM and LIFs, configure networking for iSCSI on vSphere hosts.
