Create SVM and LIFs for NFS vVols datastores in a VCF workload domain
Create a Storage Virtual Machine (SVM) and multiple logical interfaces (LIFs) on an ONTAP system to support NFS traffic for vVols datastores in a VMware Cloud Foundation workload domain.
To add new LIFs to an existing SVM, refer to the ONTAP documentation: Create ONTAP LIFs.
In ONTAP System Manager, navigate to Storage VMs in the left-hand menu and click on + Add to start.
Show example
In the Add Storage VM wizard, provide a Name for the SVM, select the IP Space and then, under Access Protocol, click the SMB/CIFS, NFS, S3 tab and check the box to Enable NFS.
Show example
You don't need to check the Allow NFS client access checkbox. ONTAP tools for VMware vSphere will be used to automate the datastore deployment process, which includes providing client access for the vSphere hosts. -
In the Network Interface section, fill in the IP address, Subnet Mask, and Broadcast Domain and Port for the first LIF. For subsequent LIFs, you can either use individual settings or enable the checkbox to use common settings across all remaining LIFs.
Show example
Choose whether to enable the Storage VM Administration account (for multi-tenancy environments) and click Save to create the SVM.
Show example
What's next?
After creating the SVM and LIFs, configure networking for NFS on vSphere hosts.
