Deployment requirements for NVMe/TCP datastore in a VMware Cloud Foundation workload domain
Review the recommended network design and infrastructure requirements to deploy NVMe/TCP datastore in a VMware Cloud Foundation workload domain. You need a fully configured ONTAP AFF or ASA storage system, a deployed VCF management domain, and an existing workload domain.
Infrastructure requirements
An ONTAP AFF or ASA storage system with physical data ports on Ethernet switches dedicated to storage traffic.
VCF management domain deployment is complete and the vSphere client is accessible.
A workload domain has been previously deployed.
Recommended NVMe/TCP network design
NetApp recommends fully redundant network designs for NVMe/TCP. The following diagram illustrates an example of a redundant configuration, providing fault tolerance for storage systems, switches, networks adapters and host systems.
For multipathing and failover across multiple paths, configure a minimum of two LIFs per storage node in separate Ethernet networks for all SVMs in NVMe/TCP configurations.
What's next?
After reviewing the deployment requirements, create the SVM and LIFs.
