Networking requirements for Cloud Manager
You must set up your networking so that Cloud Manager can deploy Cloud Volumes ONTAP systems in AWS or in Microsoft Azure. The most important step is ensuring outbound internet access to various endpoints.
If your network uses a proxy server for all communication to the internet, Cloud Manager prompts you to specify the proxy during setup. You can also specify the proxy server from the Settings page. Refer to Configuring Cloud Manager to use a proxy server. |
Connection to target networks
Cloud Manager requires a network connection to the AWS VPCs and Azure VNets in which you want to deploy Cloud Volumes ONTAP.
For example, if you install Cloud Manager in your corporate network, then you must set up a VPN connection to the AWS VPC or Azure VNet in which you launch Cloud Volumes ONTAP.
Outbound internet access
Cloud Manager requires outbound internet access to deploy and manage Cloud Volumes ONTAP. Outbound internet access is also required when accessing Cloud Manager from your web browser and when running the Cloud Manager installer on a Linux host.
The following sections identify the specific endpoints.
- Outbound internet access to manage Cloud Volumes ONTAP in AWS
Cloud Manager requires outbound internet access to contact the following endpoints when deploying and managing Cloud Volumes ONTAP in AWS:
Endpoints Purpose AWS services (amazonaws.com):
CloudFormation
Elastic Compute Cloud (EC2)
Key Management Service (KMS)
Security Token Service (STS)
Simple Storage Service (S3)
The exact endpoint depends on the region in which you deploy Cloud Volumes ONTAP. Refer to AWS documentation for details.
Enables Cloud Manager to deploy and manage Cloud Volumes ONTAP in AWS.
https://api.services.cloud.netapp.com:443
API requests to NetApp Cloud Central.
https://cloud.support.netapp.com.s3.us-west-1.amazonaws.com
Provides access to software images, manifests, and templates.
https://cognito-idp.us-east-1.amazonaws.com
https://cognito-identity.us-east-1.amazonaws.comEnables Cloud Manager to access and download manifests, templates, and Cloud Volumes ONTAP upgrade images.
https://kinesis.us-east-1.amazonaws.com
Enables NetApp to stream data from audit records.
https://cloudmanager.cloud.netapp.com
Communication with the Cloud Manager service, which includes Cloud Central accounts.
https://netapp-cloud-account.auth0.com
Communication with NetApp Cloud Central for centralized user authentication.
https://support.netapp.com/aods/asupmessage
https://support.netapp.com/asupprod/post/1.0/postAsupCommunication with NetApp AutoSupport.
https://support.netapp.com/svcgw
https://support.netapp.com/ServiceGW/entitlementCommunication with NetApp for licensing and support registration.
https://packages.cloud.google.com/yum
https://github.com/NetApp/trident/releases/download/Required to connect Cloud Volumes ONTAP systems with a Kubernetes cluster. The endpoints enable installation of NetApp Trident.
Various third-party locations, for example:
https://repo1.maven.org/maven2
https://oss.sonatype.org/content/repositories
https://repo.typesafe.org
Third-party locations are subject to change.
During upgrades, Cloud Manager downloads the latest packages for third-party dependencies.
- Outbound internet access to manage Cloud Volumes ONTAP in Azure
Cloud Manager requires outbound internet access to contact the following endpoints when deploying and managing Cloud Volumes ONTAP in Microsoft Azure:
Endpoints Purpose https://management.azure.com
https://login.microsoftonline.comEnables Cloud Manager to deploy and manage Cloud Volumes ONTAP in most Azure regions.
https://management.microsoftazure.de
https://login.microsoftonline.deEnables Cloud Manager to deploy and manage Cloud Volumes ONTAP in the Azure Germany regions.
https://management.usgovcloudapi.net
https://login.microsoftonline.comEnables Cloud Manager to deploy and manage Cloud Volumes ONTAP in the Azure US Gov regions.
https://sts.amazonaws.comEnables Cloud Manager to access and download manifests, templates, and Cloud Volumes ONTAP upgrade images.
https://mysupport.netapp.com
- Outbound internet access from your web browser
Users must access Cloud Manager from a web browser. The machine running the web browser must have connections to the following endpoints:
Endpoints Purpose The Cloud Manager host
You must enter the host's IP address from a web browser to load the Cloud Manager console.
Depending on your connectivity to your cloud provider, you can use the private IP or a public IP assigned to the host:
A private IP works if you have a VPN and direct connect access to your virtual network
A public IP works in any networking scenario
In any case, you should secure network access by ensuring that security group rules allow access from only authorized IPs or subnets.
https://auth0.com
https://cdn.auth0.com
https://services.cloud.netapp.comYour web browser connects to these endpoints for centralized user authentication through NetApp Cloud Central.
https://widget.intercom.io
For in-product chat that enables you to talk to NetApp cloud experts.
- Outbound internet access to install Cloud Manager on a Linux host
The Cloud Manager installer must access the following URLs during the installation process:
http://dev.mysql.com/get/mysql-community-release-el7-5.noarch.rpm
https://dl.fedoraproject.org/pub/epel/epel-release-latest-7.noarch.rpm
https://s3.amazonaws.com/aws-cli/awscli-bundle.zip
Ports and security groups
If you deploy Cloud Manager from Cloud Central or from the marketplace images, refer to the following:
If you install Cloud Manager on an existing Linux host, see Cloud Manager host requirements.
