Go to the docs for the latest release.
Default configuration for Cloud Volumes ONTAP
Understanding how Cloud Volumes ONTAP is configured by default can help you set up and administer your systems, especially if you are familiar with ONTAP because the default setup for Cloud Volumes ONTAP is different than ONTAP.
Defaults
Cloud Volumes ONTAP is available as a single-node system in AWS, Azure, and GCP, and as an HA pair in AWS and Azure.
Cloud Manager creates one data-serving storage VM when it deploys Cloud Volumes ONTAP. Some configurations support additional storage VMs. Learn more about managing storage VMs.
Cloud Manager automatically installs the following ONTAP feature licenses on Cloud Volumes ONTAP:
CIFS
FlexCache
FlexClone
iSCSI
NetApp Volume Encryption (only for BYOL or registered PAYGO systems)
NFS
SnapMirror
SnapRestore
SnapVault
Several network interfaces are created by default:
A cluster management LIF
An intercluster LIF
An SVM management LIF on HA systems in Azure, single node systems in AWS, and optionally on HA systems in multiple AWS Availability Zones
A node management LIF
An iSCSI data LIF
A CIFS and NFS data LIF
LIF failover is disabled by default for Cloud Volumes ONTAP due to EC2 requirements. Migrating a LIF to a different port breaks the external mapping between IP addresses and network interfaces on the instance, making the LIF inaccessible.
Cloud Volumes ONTAP sends configuration backups to the Connector using HTTPS.
The backups are accessible from https://ipaddress/occm/offboxconfig/ where ipaddress is the IP address of the Connector host.
Cloud Manager sets a few volume attributes differently than other management tools (System Manager or the CLI, for example).
The following table lists the volume attributes that Cloud Manager sets differently from the defaults:
Attribute Value set by Cloud Manager Autosize mode
grow
Maximum autosize
1,000 percent
The Account Admin can modify this value from the Settings page. Security style
NTFS for CIFS volumes
UNIX for NFS volumesSpace guarantee style
none
UNIX permissions (NFS only)
777
See the volume create man page for information about these attributes.
Boot and root data for Cloud Volumes ONTAP
In addition to the storage for user data, Cloud Manager also purchases cloud storage for boot and root data on each Cloud Volumes ONTAP system.
AWS
Two disks per node for boot and root data:
9.7: 160 GB io1 disk for boot data and a 220 GB gp2 disk for root data
9.6: 93 GB io1 disk for boot data and a 140 GB gp2 disk for root data
9.5: 45 GB io1 disk for boot data and a 140 GB gp2 disk for root data
One EBS snapshot for each boot disk and root disk
For HA pairs, one EBS volume for the Mediator instance, which is approximately 8 GB
Azure (single node)
Three Premium SSD disks:
One 10 GB disk for boot data
One 140 GB disk for root data
One 128 GB disk for NVRAM
If the virtual machine that you chose for Cloud Volumes ONTAP supports Ultra SSDs, then the system uses an Ultra SSD for NVRAM, rather than a Premium SSD.
One 1024 GB Standard HDD disk for saving cores
One Azure snapshot for each boot disk and root disk
Azure (HA pairs)
Two 10 GB Premium SSD disks for the boot volume (one per node)
Two 140 GB Premium Storage page blobs for the root volume (one per node)
Two 1024 GB Standard HDD disks for saving cores (one per node)
Two 128 GB Premium SSD disks for NVRAM (one per node)
GCP
One 10 GB Standard persistent disk for boot data
One 64 GB Standard persistent disk for root data
One 500 GB Standard persistent disk for NVRAM
One 216 GB Standard persistent disk for saving cores
One GCP snapshot each for the boot disk and root disk
Where the disks reside
Cloud Manager lays out the storage as follows:
Boot data resides on a disk attached to the instance or virtual machine.
This disk, which contains the boot image, is not available to Cloud Volumes ONTAP.
Root data, which contains the system configuration and logs, resides in aggr0.
The storage virtual machine (SVM) root volume resides in aggr1.
Data volumes also reside in aggr1.
Encryption
Boot and root disks are always encrypted in Azure and Google Cloud Platform because encryption is enabled by default in those cloud providers.
When you enable data encryption in AWS using the Key Management Service (KMS), the boot and root disks for Cloud Volumes ONTAP are encrypted, as well. This includes the boot disk for the mediator instance in an HA pair. The disks are encrypted using the CMK that you select when you create the working environment.
